jetty upgrade problem [message #1771211] |
Wed, 23 August 2017 00:58  |
I am trying to upgrade from jetty6 to jetty9 and getting below error on app start.
Can you please advise, why Jetty is not able to read rt.jar? It is in classpath.
Also how i can enable more logging .
I am using JAVA8, Jetty 9.4.5
INFO log - Logging initialized @2562ms to org.eclipse.jetty.util.log.Slf4jLog
INFO ContextRepositorySelector - Registering org.apache.log4j.Hierarchy@7586beff for context startJarLoader@4e7dc304
INFO Server - jetty-9.4.5.v20170502
INFO AbstractNCSARequestLog - Opened C:\myhome\jetty\jetty-bb\instance-bulsim\logs\request.log.2017_08_23
INFO ScanningAppProvider - Deployment monitor [file:///C:/myhome/jetty/jetty-bb/instance-bulsim/contexts/] at interval 1
INFO IndividualTimeoutUserCache - IndividualTimeoutUserCache initalised with timeout [10] minutes
INFO indoniSybDriver - Registered com.bmh.gunsulting.indoni.sybase.indoniSybDriver[com.sybase.jdbc4.jdbc.SybDriver@25df00a0]
INFO DatabaseLoginRealm - New realm <Bulk Payment Service> @ jdbc:indoni-sybase:Tds:bd_syb_BSDEV1.macbank:20003
INFO ContextRepositorySelector - Created org.apache.log4j.Hierarchy@5a37d3ed from file:/C:/myhome/jetty/jetty-bb/instance-bulsim/resources/log4j.prop
erties for context WebAppClassLoader=1188401255@46d59067
INFO AnnotationConfiguration - Scanning elapsed time=2484ms
WARN WebAppContext - Failed startup of context o.e.j.w.WebAppContext@5db6b9cd{/trillion-ballarat,file:///C:/myhome/jetty/jetty-bb/instance-bulsim/work
/jetty-trillion-1.0.0-SNAPSHOT.war-_trillion-ballarat-any-/webapp/,UNAVAILABLE}{/trillion-1.0.0-SNAPSHOT.war}
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:57)
at java.lang.reflect.Method.invoke(Method.java:491)
at org.eclipse.jetty.webapp.IterativeDescriptorProcessor.visit(IterativeDescriptorProcessor.java:83)
at org.eclipse.jetty.webapp.IterativeDescriptorProcessor.process(IterativeDescriptorProcessor.java:70)
at org.eclipse.jetty.webapp.MetaData.resolve(MetaData.java:408)
at org.eclipse.jetty.webapp.WebAppContext.startContext(WebAppContext.java:1461)
at org.eclipse.jetty.server.handler.ContextHandler.doStart(ContextHandler.java:785)
at org.eclipse.jetty.servlet.ServletContextHandler.doStart(ServletContextHandler.java:261)
at org.eclipse.jetty.webapp.WebAppContext.doStart(WebAppContext.java:545)
at org.eclipse.jetty.util.component.AbstractLifeCycle.start(AbstractLifeCycle.java:68)
at org.eclipse.jetty.deploy.bindings.StandardStarter.processBinding(StandardStarter.java:41)
at org.eclipse.jetty.deploy.AppLifeCycle.runBindings(AppLifeCycle.java:188)
at org.eclipse.jetty.deploy.DeploymentManager.requestAppGoal(DeploymentManager.java:502)
at org.eclipse.jetty.deploy.DeploymentManager.addApp(DeploymentManager.java:150)
at org.eclipse.jetty.deploy.providers.ScanningAppProvider.fileAdded(ScanningAppProvider.java:180)
at org.eclipse.jetty.deploy.providers.WebAppProvider.fileAdded(WebAppProvider.java:453)
at org.eclipse.jetty.deploy.providers.ScanningAppProvider$1.fileAdded(ScanningAppProvider.java:64)
at org.eclipse.jetty.util.Scanner.reportAddition(Scanner.java:610)
at org.eclipse.jetty.util.Scanner.reportDifferences(Scanner.java:529)
at org.eclipse.jetty.util.Scanner.scan(Scanner.java:392)
at org.eclipse.jetty.util.Scanner.doStart(Scanner.java:313)
at org.eclipse.jetty.deploy.providers.ScanningAppProvider.doStart(ScanningAppProvider.java:150)
at org.eclipse.jetty.deploy.DeploymentManager.startAppProvider(DeploymentManager.java:564)
at org.eclipse.jetty.deploy.DeploymentManager.doStart(DeploymentManager.java:239)
at org.eclipse.jetty.util.component.ContainerLifeCycle.start(ContainerLifeCycle.java:131)
at org.eclipse.jetty.server.Server.start(Server.java:452)
at org.eclipse.jetty.util.component.ContainerLifeCycle.doStart(ContainerLifeCycle.java:113)
at org.eclipse.jetty.server.handler.AbstractHandler.doStart(AbstractHandler.java:113)
at org.eclipse.jetty.server.Server.doStart(Server.java:419)
at org.eclipse.jetty.xml.XmlConfiguration$1.run(XmlConfiguration.java:1511)
at org.eclipse.jetty.xml.XmlConfiguration$1.run(XmlConfiguration.java:1438)
at org.eclipse.jetty.xml.XmlConfiguration.main(XmlConfiguration.java:1437)
at org.eclipse.jetty.start.Main.invokeMain(Main.java:221)
at org.eclipse.jetty.start.Main.start(Main.java:499)
at org.eclipse.jetty.start.Main.main(Main.java:78)
Caused by: java.lang.ClassNotFoundException: java.net.url
at java.net.URLClassLoader$1.run(URLClassLoader.java:365)
at java.net.URLClassLoader$1.run(URLClassLoader.java:354)
at java.net.URLClassLoader.findClass(URLClassLoader.java:353)
at java.lang.ClassLoader.loadClass(ClassLoader.java:423)
at java.lang.ClassLoader.loadClass(ClassLoader.java:356)
at org.eclipse.jetty.webapp.WebAppClassLoader.loadClass(WebAppClassLoader.java:560)
at org.eclipse.jetty.server.handler.ContextHandler.loadClass(ContextHandler.java:1735)
at org.eclipse.jetty.plus.webapp.PlusDescriptorProcessor.visitResourceRef(PlusDescriptorProcessor.java:252)
... 46 more
INFO Server - Started @7722ms
FUDForum. Page generated in 0.24489 seconds
