Code generation [message #1769907] |
Fri, 04 August 2017 21:28  |
I wanted to test a very simple model for code generation.
I created a profile with a stereotype that the stereotype has three attributes: a, b and c
Next, I created a model instance of that profile such that a class of instance model has an operation on a, b and c.
If I try to generate the code out of the model instance by right click-->Designer--> generate java code, the generated code is not correct. Can any one help me and explain how i can generate the code properly? I attach the simple profile and the model instance.
Thanks.
FUDForum. Page generated in 0.05238 seconds
