Home » Eclipse Projects » Sirius » Hide the "Style" and "Apperance" tabs in Properties View
Hide the "Style" and "Apperance" tabs in Properties View [message #1769604] Wed, 02 August 2017 03:48 Go to next message
I need to hide the "Style" and "Apperance" tabs in Properties View.
How?
Thanks.
Martin
Re: Hide the "Style" and "Apperance" tabs in Properties View [message #1769611 is a reply to message #1769604] Wed, 02 August 2017 04:16 Go to previous messageGo to next message
Hi Martin,
you need to implement a TabDescriptorFilter.
See https://www.eclipse.org/sirius/doc/specifier/properties/Properties_View_Description.html#tab_filtering
HTH
Axel
[Updated on: Wed, 02 August 2017 04:20] by Moderator
Re: Hide the "Style" and "Apperance" tabs in Properties View [message #1770089 is a reply to message #1769611] Tue, 08 August 2017 05:10 Go to previous message
thank you very much for your answer.
I implemented the IEEFTabDescriptorFilter interface and added extension point org.eclipse.eef.properties.ui.eefTabDescriptorFilter.
However, when I run my RCP application and open Properties View, there are a lot of exceptions that do not work with VSM (Invalid featrues of name).
I use the Eclipse 4.5.2 and Sirius 4.1.1 platforms. I think this can only be used in Sirius 5.
Thanks.
Martin
Previous Topic:Error override
Next Topic:Bordered Nodes rearrangement.
Current Time: Sun Jul 20 14:01:20 EDT 2025
Powered by FUDForum. Page generated in 0.04752 seconds
