Home » Eclipse Projects » GEF » Runtime Workbench Hangs
Runtime Workbench Hangs [message #176709] |
Mon, 11 April 2005 16:32  |
Originally posted by: binti.ksu.edu
Hi All,
I have a strange problem. When I run my plugin to test it in the runtime
workbench, it hangs when ever I pull out a pop-up menu or right click to
perform any action? Why is this so? When I hit alt+tab and come to the
workbench it works fine. This only happens when my file is open. If no file
is open, it works fine?
Is there a problem with my plugin?
Kindly Help.
Binti.
Re: Runtime Workbench Hangs [message #176874 is a reply to message #176709] |
Tue, 12 April 2005 09:32   |
I know now where the problem occurs - in my diagram figure. I am including
the source here. Kindly look at it and let me know what to do.
public class SequenceDiagramFigure extends FreeformLayer
EditableLabel nameLabel;
public SequenceDiagramFigure(EditableLabel name)
nameLabel = name;
setOpaque(true);
protected void paintFigure(Graphics g)
add(nameLabel); --------------------------------------- THIS IS WHERE THE
PROBLEM IS.........
Rectangle r = getBounds().getCopy();
int DELTA = 20;
r.translate(DELTA, DELTA);
Insets inset = new Insets(DELTA, DELTA, DELTA, DELTA);
MarginBorder border = new MarginBorder(inset);
setBorder(border);
g.drawRectangle(r.x, r.y, r.width - 2*DELTA, r.height - 2*DELTA);
If I add the nameLabel in the constructor, it only shows up after any
movement or addition to the canvas, but not when the editor opens up. If I
add it in the paintFigure(), it freezes the workbench on opening any
pop-ups. Why does it not show initially if I add it in the constructor? If I
do not add it at all, the workbench behaves fine.
Kindly look into this and let me know what to do, thanks a lot in advance.
Binti.
"Binti Sepaha" <binti@ksu.edu> wrote in message
news:d3en89$v0$1@news.eclipse.org...
> Hi All,
> file is open, it works fine?
> Kindly Help.
> Binti.
Re: Runtime Workbench Hangs [message #176906 is a reply to message #176898] |
Tue, 12 April 2005 10:23   |
Hey Randy, I debggued it and found where the problem is. Just posted it.
Kindly review it and let me know what to do.
Binti
"Randy Hudson" <none@us.ibm.com> wrote in message
news:d3gldj$fsg$1@news.eclipse.org...
> If the workbench hangs, you can usually invoke a thread dump by pressing
> CTRL+BREAK on windows. Or, if you are launching a runtime workbench from
> within eclipse, do it in debug mode and then inspect the threads in hte
> debugger. Let us know what you find.
>> Hi All,
>> Kindly Help.
>> Thanks,
>> Binti.
Re: Runtime Workbench Hangs [message #176914 is a reply to message #176874] |
Tue, 12 April 2005 11:01   |
Right, so you can't do all those things in the paintFigure() method. You
should only do painting in there. When you add a child to a figure (or set
the border), that figure will automatically request a revalidate, which will
cause a repaint. So, you basically get a cycle. I would have thought that
you'd run into a problem sooner than when you right-click.
You should add those children and the set the border in the constructor. If
it's not showing up initially, you're not setting it up properly (maybe not
setting the constraints). Hard to say what you're doing wrong without
looking at the code.
news:d3gj00$c03$1@news.eclipse.org...
> nameLabel = name;
> setOpaque(true);
THE
> PROBLEM IS.........
> int DELTA = 20;
> setBorder(border);
I
I
> Binti.
> > Hi All,
> > Kindly Help.
> > Thanks,
> > Binti.
Re: Runtime Workbench Hangs - Solved [message #176923 is a reply to message #176914] |
Tue, 12 April 2005 11:18  |
Thanks, that solved my problem.
I put the setBorder and adding the label in the constructor and everything
works fine. I was being silly. Thanks a lot.
Binti.
"Pratik Shah" <ppshah@us.ibm.com> wrote in message
news:d3go7r$kjh$1@news.eclipse.org...
> set
> will
> that
> If
> not
>> Hi,
>> including
>> nameLabel = name;
>> setOpaque(true);
> THE
>> PROBLEM IS.........
>> int DELTA = 20;
>> setBorder(border);
> I
>> If
> I
>> advance.
>> Binti.
>> > Hi All,
>> > runtime
>> > to
>> > Kindly Help.
>> > Thanks,
>> > Binti.
Current Time: Sat Jul 19 09:57:45 EDT 2025
Powered by FUDForum. Page generated in 0.03290 seconds
