Home » Newcomers » Newcomers » Eclipse Installer fails on Window 7, unable to install.(The Eclipse Installer executable launcher was unable to locate its companion shared library.)
Eclipse Installer fails on Window 7, unable to install. [message #1768439] Tue, 18 July 2017 14:06 Go to next message
I'm trying to install the latest release of Eclipse using the Eclipse Installer for Windows (eclipse-inst-win64.exe). Whenever I run the installer, I receive the following error:
Eclipse Installer
Everything I can find online mentions this error after Eclipse has been installed, but I can't even get to step 3 on the find out more page of the Eclipse Packages page.
Has anyone else encountered this issue or know how to fix it?
Re: Eclipse Installer fails on Window 7, unable to install. [message #1768446 is a reply to message #1768439] Tue, 18 July 2017 15:54 Go to previous messageGo to next message
The eclipse-inst-win64.exe is a native executable. There is no companion shared library. It should just run. In the worst case, download a zip from https://www.eclipse.org/downloads/eclipse-packages/ and unzip that.
Re: Eclipse Installer fails on Window 7, unable to install. [message #1768514 is a reply to message #1768439] Wed, 19 July 2017 11:46 Go to previous messageGo to next message
I'm with a similar problem, but i don't receive any error message. It appears the work-space box to select and then it just stop working. Windows show (not responding).
I try with Eclipse Mars 2 and Luna. When i try with oxygen, a grey box appears and the same happen, the program stop running.
Please, any advice?
Re: Eclipse Installer fails on Window 7, unable to install. [message #1768523 is a reply to message #1768446] Wed, 19 July 2017 12:44 Go to previous messageGo to next message
Ed Merks wrote on Tue, 18 July 2017 19:54
Yeah, that's exactly why I'm so confused.
After unzipping and running, I get the same error (except this time it references Eclipse itself). I can run the launcher.jar file specified in the config.ini file, and Eclipse will start; however, running eclipse.exe always fails with that error.
Re: Eclipse Installer fails on Window 7, unable to install. [message #1768524 is a reply to message #1768523] Wed, 19 July 2017 13:04 Go to previous messageGo to next message
Where are you putting these executables and then trying to run them?
Re: Eclipse Installer fails on Window 7, unable to install. [message #1768537 is a reply to message #1768524] Wed, 19 July 2017 14:53 Go to previous message
Nitin Dahyabhai wrote on Wed, 19 July 2017 17:04
It doesn't seem to matter, but I've tried running them out from:
  • Downloads
  • C:\
  • Home (C:\Users\<username>)
  • Desktop
Previous Topic:Neon 4.6.3 flickering on Mac
Next Topic:Java syntax highlighting does not persist on IDE restart
Current Time: Sun Jul 20 09:11:21 EDT 2025
Powered by FUDForum. Page generated in 0.31625 seconds
