[SOLVED] Workbench: Could not run processor [message #1767936] |
Wed, 12 July 2017 05:22  |
I'm trying to build a true E4 application (based on http://www.vogella.com/tutorials/EclipseTycho/article.html#exercise-tycho-build-for-plug-ins and other vogella tutorials) and have run into the stack trace below on starting up the product which I think may point at a problem with the compatibility layer/the app not being true E4 (which I hoped I can make it).
The line from PrefUtil stuck out, and it seems the uiCallback is null, but at the moment I'm stuck for a solution.
Here's the relevant PrefUtil code:
* Returns the API preference store.
* @return the API preference store
public static IPreferenceStore getAPIPreferenceStore() {
if (uiPreferenceStore == null) {
Assert.isNotNull(uiCallback);
uiPreferenceStore = uiCallback.getPreferenceStore();
return uiPreferenceStore;
I've had a look at quite a few similar error reports, but none of the solutions there alleviate this problem, so I'd be thankful for any pointers. Thanks!
!ENTRY org.eclipse.e4.ui.workbench 2 0 2017-07-12 11:13:15.196
!MESSAGE Could not run processor
!STACK 0
org.eclipse.e4.core.di.InjectionException: org.eclipse.core.runtime.AssertionFailedException: null argument:
at org.eclipse.e4.core.internal.di.MethodRequestor.execute(MethodRequestor.java:65)
at org.eclipse.e4.core.internal.di.InjectorImpl.invokeUsingClass(InjectorImpl.java:282)
at org.eclipse.e4.core.internal.di.InjectorImpl.invoke(InjectorImpl.java:259)
at org.eclipse.e4.core.contexts.ContextInjectionFactory.invoke(ContextInjectionFactory.java:107)
at org.eclipse.e4.ui.internal.workbench.ModelAssembler.runProcessor(ModelAssembler.java:335)
at org.eclipse.e4.ui.internal.workbench.ModelAssembler.runProcessors(ModelAssembler.java:297)
at org.eclipse.e4.ui.internal.workbench.ModelAssembler.processModel(ModelAssembler.java:94)
at org.eclipse.e4.ui.internal.workbench.ResourceHandler.loadMostRecentModel(ResourceHandler.java:197)
at org.eclipse.e4.ui.internal.workbench.swt.E4Application.loadApplicationModel(E4Application.java:377)
at org.eclipse.e4.ui.internal.workbench.swt.E4Application.createE4Workbench(E4Application.java:252)
at org.eclipse.e4.ui.internal.workbench.swt.E4Application.start(E4Application.java:148)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:673)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:610)
at org.eclipse.equinox.launcher.Main.run(Main.java:1519)
at org.eclipse.equinox.launcher.Main.main(Main.java:1492)
Caused by: org.eclipse.core.runtime.AssertionFailedException: null argument:
at org.eclipse.core.runtime.Assert.isNotNull(Assert.java:85)
at org.eclipse.core.runtime.Assert.isNotNull(Assert.java:73)
at org.eclipse.ui.internal.util.PrefUtil.getAPIPreferenceStore(PrefUtil.java:70)
at org.eclipse.ui.PlatformUI.getPreferenceStore(PlatformUI.java:194)
at org.eclipse.ui.internal.keys.BindingPersistence.readActiveScheme(BindingPersistence.java:379)
at org.eclipse.ui.internal.keys.BindingPersistence.reRead(BindingPersistence.java:1377)
at org.eclipse.ui.internal.keys.BindingPersistence.read(BindingPersistence.java:1281)
at org.eclipse.ui.internal.BindingToModelProcessor.process(BindingToModelProcessor.java:65)
at org.eclipse.e4.core.internal.di.MethodRequestor.execute(MethodRequestor.java:55)
... 23 more
[Updated on: Wed, 12 July 2017 05:58] by Moderator
FUDForum. Page generated in 0.03954 seconds
