Home » Newcomers » Newcomers » question on Eclipse error: "could not find java 2 run time environment"
question on Eclipse error: "could not find java 2 run time environment" [message #176768] Thu, 26 October 2006 12:26 Go to next message
Originally posted by: qu.duan.qwest.com
I suddenly get the above error (subject line) when I run Eclipse (with
MyEclipse) after a XP reboot. I did not see any change except I trying to
install and uninstall Oracle Client.
If anyone has clue to fix this error, please let me know.
Qu
Re: question on Eclipse error: "could not find java 2 run time environment" [message #176775 is a reply to message #176768] Thu, 26 October 2006 12:51 Go to previous messageGo to next message
qu wrote:
Assuming you use Windows, I'd check your eclipse shortcut and see where
Eclipse.exe is placed.
Then open a commandline and swich to that directory.
In there type "java -version"
I guess that the Oracle thingy may have installed some java and thus
modified some Java settings in your registry.
After uninstalling it, the java it installed is now gone. But the
"pointer" in registry not reset.
But that is only a guess
Regards Henrik.
Re: question on Eclipse error: "could not find java 2 run time environment" [message #176782 is a reply to message #176775] Thu, 26 October 2006 13:17 Go to previous messageGo to next message
Thanks.
I am trying to locate the registry and think how do I know the original
value and change it back. Now i have to run eclipse from command line.
eclipse -vm "c:\Program Files\Java\jdk1.5.0_08|jre\bin\javaw"
Qu
Re: question on Eclipse error: "could not find java 2 run time environment" [message #176851 is a reply to message #176768] Thu, 26 October 2006 15:48 Go to previous messageGo to next message
Originally posted by: wharley.bea.com
"qu" <qu.duan@qwest.com> wrote in message
news:ee26e0279f6d4d91822ddc920e8d8de1$1@www.eclipse.org...
The Oracle client is notorious for installing out-of-date Java versions at
the head of the path.
Re: question on Eclipse error: "could not find java 2 run time environment" [message #177386 is a reply to message #176782] Mon, 30 October 2006 09:48 Go to previous message
Originally posted by: eclipse4.rizzoweb.com
qu wrote:
> Thanks.
> Qu
Yes, Oracle has messed up your PC path.
Anyway, it is best to run Eclipse with a -vm parameter. You can also
specify it in the eclipse.ini file, which I have just written about in
another thread a few minutes ago.
Hope this helps,
Eric
Previous Topic:mevenide vs. m2eclipse
Next Topic:Entering Code
Current Time: Sat Jul 19 14:54:36 EDT 2025
Powered by FUDForum. Page generated in 0.09138 seconds
