Home » Modeling » TMF (Xtext) » Adding a library to an Xbase DSL
Adding a library to an Xbase DSL [message #1767309] Tue, 04 July 2017 10:49 Go to next message
Hello everyone,
I want to add a library to an Xbase-DSL to provide some additional functions / classes.
I already did this in a non-Xbase-DSL, following the approach suggested in the book "Implementing Domain-Specific Languages with Xtext and Xtend" (great read btw!) and it worked out of the box.
It suggests to added a lib.mydsl-file into the source folder of the x.y.mydsl-Plugin and the content of this file (e.g. some pre-defined functions or classes /entities) will be available at runtime.
However, when I do this, using Xbase, it does not work and I dont know why (maybe it is not indexed / added to the scope?) and where to start looking for a solution.
What I did so far:
Using the domainmodel-example i created a file lib.dmodel with the following content:
entity a{}
and added it to the package "org.eclipse.xtext.example.domainmodel" ( the package is exported by the plugin by default).
Then I started a runtime-eclipse-application and created a test plugin-project and added a dependency to the org.eclipse.xtext.example.domainmodel plugin.
But when i create a test.dmodel file, entity a is not available.
entity b extends a //Missing supertype a
How can I make this work in Xbase?
Or is there a better way to provide some library functions / library types for an Xbase DSL?
Marco
Re: Adding a library to an Xbase DSL [message #1767311 is a reply to message #1767309] Tue, 04 July 2017 10:59 Go to previous messageGo to next message
i cannot reproduce this
are you sure you did it right?
you need to add a dependency from the project (plugin) that contains the entity b to the plugin (i assume this is org.eclipse.xtext.example.domainmodel)
btw i would create a separate plugin like org.eclipse.xtext.example.domainmodel.lib for that purpose
Re: Adding a library to an Xbase DSL [message #1767312 is a reply to message #1767311] Tue, 04 July 2017 11:10 Go to previous messageGo to next message
Hi Christian,
thank you for your help! (:
I will add it to a library-plugin as soon as I get it working that way.
I think I got it right (I simply added the file and the dependencies as mentioned above).
Did I missed a step?
Here are the Manifest.MF`s
of the org.eclipse.xtext.example.domainmodel-Plugin (the DSL-Plugin)
Manifest-Version: 1.0
Bundle-ManifestVersion: 2
Bundle-Name: Xtext Domainmodel Example
Bundle-Vendor: Eclipse Xtext
Bundle-Version: 2.12.0.qualifier
Bundle-SymbolicName: org.eclipse.xtext.example.domainmodel; singleton:=true
Bundle-ActivationPolicy: lazy
Require-Bundle: org.eclipse.xtext,
 org.eclipse.xtext.xbase,
 org.eclipse.equinox.common;bundle-version="3.5.0",
 org.eclipse.emf.ecore,
 org.eclipse.xtext.xbase.lib,
 org.antlr.runtime,
 org.eclipse.xtext.util,
 org.eclipse.xtend.lib,
 org.eclipse.emf.common,
 org.eclipse.xtext.common.types,
 org.objectweb.asm;bundle-version="[5.0.1,6.0.0)";resolution:=optional
Bundle-RequiredExecutionEnvironment: JavaSE-1.8
Export-Package: dmodel.lang,
 org.eclipse.xtext.example.domainmodel,
 org.eclipse.xtext.example.domainmodel.domainmodel,
 org.eclipse.xtext.example.domainmodel.domainmodel.impl,
 org.eclipse.xtext.example.domainmodel.domainmodel.util,
 org.eclipse.xtext.example.domainmodel.formatting2,
 org.eclipse.xtext.example.domainmodel.jvmmodel,
 org.eclipse.xtext.example.domainmodel.parser.antlr,
 org.eclipse.xtext.example.domainmodel.parser.antlr.internal,
 org.eclipse.xtext.example.domainmodel.scoping,
 org.eclipse.xtext.example.domainmodel.serializer,
 org.eclipse.xtext.example.domainmodel.services,
 org.eclipse.xtext.example.domainmodel.validation
Import-Package: org.apache.log4j
And the runtime-plugin (DmodelTest):
Bundle-Name: DmodelTest
Bundle-SymbolicName: DmodelTest
Bundle-Version: 1.0.0.qualifier
Require-Bundle: org.eclipse.xtext.xbase.lib;bundle-version="2.12.0",
 org.eclipse.xtext.example.domainmodel;bundle-version="2.12.0"
Re: Adding a library to an Xbase DSL [message #1767313 is a reply to message #1767312] Tue, 04 July 2017 11:18 Go to previous messageGo to next message
yes this looks fine. maybe eclipse does some wired caching of the domain model plugin. can you delete your runtime workspace folder and try again?
Re: Adding a library to an Xbase DSL [message #1767341 is a reply to message #1767313] Tue, 04 July 2017 15:00 Go to previous messageGo to next message
Deleting the runtime-workspace did the trick!
Thank you Christian!
But entity a is missing in the generated java code, is this a common behavior?
Do I have to create entity a manually in the inferrer?
I expected that entity a would now be part of the EMF-Modelinstance and would be handeled like entity b.
Re: Adding a library to an Xbase DSL [message #1767343 is a reply to message #1767341] Tue, 04 July 2017 15:05 Go to previous message
no,
it will be filtered in org.eclipse.xtext.builder.BuilderParticipant.getRelevantDeltas(IBuildContext)
=> you would need to subclass BuilderParticipant, adapt that method, and bind the subclass as IXtextBuilderParticipant
Previous Topic:Ambiguous grammar
Next Topic:Using linked .jar libraries in code generator
Current Time: Sun Jul 20 13:07:28 EDT 2025
Powered by FUDForum. Page generated in 0.03731 seconds
