Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc)  » [Edapt] DiagnosticException while migrating
[Edapt] DiagnosticException while migrating [message #1767030] Thu, 29 June 2017 13:21 Go to next message
Hi all,
I am looking for help to sovle a DiagnosticException while migrating the first time my existing ecode model files to a new version.
I had already an ecore model before starting with edapt. I need to change my ecore model and would like to use edapt to automatic migrate from the existing ecore model to the new model.
Following the documentation I need to create a initial "history" from the existing model, then do my modification and create a release. All I have done but when I invoke the migration code I get a DiagnosticException which I can not interpret.
org.eclipse.emf.edapt.migration.MigrationException: org.eclipse.emf.edapt.internal.migration.DiagnosticException: Model inconsistent
The 'validContainment' constraint is violated on 'Instance of type "Railml"'
The 'validContainment' constraint is violated on 'Instance of type "EStringToStringMapEntry"'
My ecore model was generated from a xsd and has a DocumentRoot class, I belive it has some thing todo with it but cant figure out what to do.
index.php/fa/29820/0/
Attached you can find the ecore and history file as well as the file I need to upgrade.
Any help is appreciated!
Martin
PS: I am using Eclipse 4.6 IDE with edapt record feature 1.2.2 while my target edapt version is still 1.2.1
[Updated on: Fri, 30 June 2017 10:06] by Moderator
Re: [Edapt] DiagnosticException while migrating [message #1767077 is a reply to message #1767030] Fri, 30 June 2017 08:23 Go to previous messageGo to next message
The screenshot shows that there is also a second .ecore involved. When creating the initial history for opnengine.ecore the Edapt tooling should ask you if you want track valuetable.ecore as well. Please do so and try the migration again.
If this does not help, could you share the second ecore as well? Otherwise I can't try this.
Kind regards
Johannes
Re: [Edapt] DiagnosticException while migrating [message #1767087 is a reply to message #1767077] Fri, 30 June 2017 10:20 Go to previous messageGo to next message
Hi Johannes,
thanks for your feedback. The migration fails also in case of the included history of valuetable.ecore.
I added the valuetable.ecore and valuetable.genmodel is attached to this post
In the meantime I was further investigating. I belive the main issue is the DocumentRoot Object is expected as root element of the resource set. This is tested in
org.eclipse.emf.edapt.spi.migration.util.MigrationValidator::validate_validContainment(Instance instance)
		if (instance.isProxy()) {
			return true;
		// number of instances in which the instance is contained
		int container = 0;
		for (final ReferenceSlot referenceSlot : instance.getReferences()) {
			if (referenceSlot.getEReference().isContainment()) {
				container++;
		// number of resources of which the instance is a root element
		int resources = 0;
		final Model model = instance.getType().getModel();
		for (final ModelResource modelResource : model.getResources()) {
			if (modelResource.getRootInstances().contains(instance)) {
				resources++;
		final boolean valid = container == 1 && resources <= 1 || resources == 1 && container <= 1;
		return valid;
Our XML document root XML-Element is <railml> and not <DocumentRoot>.
Does this makes sense to you?
Re: [Edapt] DiagnosticException while migrating [message #1767183 is a reply to message #1767087] Mon, 03 July 2017 05:53 Go to previous messageGo to next message
thanks for the additional files. I managed to get a bit further, however I can still not reproduce your issue.
Loading of your provided file fails for me, because the rollingstockID feature can't be found. I can't see references in the ecore or history as well.
Probably there is custom stuff going on with the serialization?
Just as a hint, it is possible to provide the right resource/resourceset for loading the file with the
org.eclipse.emf.edapt.migration.execution.Migrator.setResourceSetFactory(IResourceSetFactory)
method.
Currently I can't see why not being contained in a DocumentRoot could cause this. Unless a document root is somehow created on the run by custom de/serialization code. Maybe a runnable example would help.
In the code you posted, it would be interesting to know why it is not valid, so how many containers/resources are there? What and how many root instances are there?
Johannes
Re: [Edapt] DiagnosticException while migrating [message #1767196 is a reply to message #1767183] Mon, 03 July 2017 08:54 Go to previous messageGo to next message
Hi Johannes,
Oh yah there are some additional attribues from an much earlier implementation. These are ignored by seeting XMLResource.OPTION_RECORD_UNKNOWN_FEATUR to true
package de.bahntechnik.dd.opn.engine.util;
     * Creates an instance of the resource. <!-- begin-user-doc --> <!--
     * end-user-doc -->
     * @generated NOT
    public Resource createResource(URI uri) {
        XMLResource result = (XMLResource) createResourceGen(uri);
        result.getDefaultSaveOptions()
                .put(XMLResource.OPTION_KEEP_DEFAULT_CONTENT, Boolean.TRUE);
        result.getDefaultLoadOptions()
                .put(XMLResource.OPTION_RECORD_UNKNOWN_FEATURE, Boolean.TRUE);
        return result;
     * end-user-doc -->
     * @generated
    public Resource createResourceGen(URI uri) {
        XMLResource result = new OpnengineResourceImpl(uri);
                .put(XMLResource.OPTION_EXTENDED_META_DATA, Boolean.TRUE);
        result.getDefaultSaveOptions().put(XMLResource.OPTION_SCHEMA_LOCATION,
                Boolean.TRUE);
        result.getDefaultLoadOptions().put(
                XMLResource.OPTION_USE_ENCODED_ATTRIBUTE_STYLE, Boolean.TRUE);
                .put(XMLResource.OPTION_USE_LEXICAL_HANDLER, Boolean.TRUE);
        return result;
Regarding the validate_validContainment.
instance is "Instance of Railml"
container == 0
resources == 0
I belive this is because the root of the EMF model is DocumentRoot and the root of the XML is <railml>.
We do not use a own ResourceSetFactory or ResourceSet implementation.
We currently try to remove the DocumentRoot from our EMF model but this is not jet finished. As we need to make sure we still can read existing files withour problem.
thanks for your thoughts, Martin
Re: [Edapt] DiagnosticException while migrating [message #1767267 is a reply to message #1767196] Tue, 04 July 2017 07:39 Go to previous messageGo to next message
Hi Martin,
this works and now I get it. The XMLResource itself is creating the DocumentRoot and thus is causing the problem. So yes, you are right.
You can suppress this with
resource.getDefaultLoadOptions().put(XMIResource.OPTION_SUPPRESS_DOCUMENT_ROOT, Boolean.TRUE);
If you can't add this to your actuall Resource(Factory)Implementation you can use above mentioned #setResourceSetFactory method to use a slightly adjusted resource factory.
migrator.setResourceSetFactory(new IResourceSetFactory() {
	public ResourceSet createResourceSet() {
		MyCustomResourceSetFactoryForMigrytion factory = new MyCustomResourceSetFactoryForMigrytion(); //this add the additional load option
		ResourceSetImpl resourceSetImpl = new ResourceSetImpl();
		resourceSetImpl.getResourceFactoryRegistry().getExtensionToFactoryMap().put("*", factory);
		return resourceSetImpl;
Hope this helps
Johannes
Re: [Edapt] DiagnosticException while migrating [message #1767287 is a reply to message #1767267] Tue, 04 July 2017 09:06 Go to previous messageGo to next message
Hi Johannes,
I have set the load option
but got a NPE during migration.
	at org.eclipse.emf.edapt.internal.migration.internal.MaterializingBackwardConverter.resolveEClassifier(MaterializingBackwardConverter.java:36)
	at org.eclipse.emf.edapt.internal.migration.internal.MaterializingBackwardConverter.resolveEClass(MaterializingBackwardConverter.java:28)
	at org.eclipse.emf.edapt.internal.migration.internal.BackwardConverter.createObjects(BackwardConverter.java:79)
	at org.eclipse.emf.edapt.internal.migration.internal.BackwardConverter.initObjects(BackwardConverter.java:72)
	at org.eclipse.emf.edapt.internal.migration.internal.BackwardConverter.convert(BackwardConverter.java:61)
	at org.eclipse.emf.edapt.migration.execution.Migrator.migrateAndLoad(Migrator.java:223)
	at de.bahntechnik.dd.opn.engine.presentation.OpnengineEditor$14.run(OpnengineEditor.java:1987)
	at org.eclipse.jface.operation.ModalContext.runInCurrentThread(ModalContext.java:437)
	at org.eclipse.jface.operation.ModalContext.run(ModalContext.java:353)
	at org.eclipse.jface.dialogs.ProgressMonitorDialog.run(ProgressMonitorDialog.java:481)
	at de.bahntechnik.dd.opn.engine.presentation.OpnengineEditor.performMigration(OpnengineEditor.java:2002)
	at de.bahntechnik.dd.opn.engine.presentation.OpnengineEditor.checkMigration(OpnengineEditor.java:1969)
	at de.bahntechnik.dd.opn.engine.presentation.OpnengineEditor.createModel(OpnengineEditor.java:963)
	at de.bahntechnik.dd.opn.engine.presentation.OpnengineEditor.createPages(OpnengineEditor.java:1051)
	at org.eclipse.ui.part.MultiPageEditorPart.createPartControl(MultiPageEditorPart.java:363)
	at org.eclipse.ui.internal.e4.compatibility.CompatibilityPart.createPartControl(CompatibilityPart.java:150)
	at org.eclipse.ui.internal.e4.compatibility.CompatibilityEditor.createPartControl(CompatibilityEditor.java:99)
	at org.eclipse.ui.internal.e4.compatibility.CompatibilityPart.create(CompatibilityPart.java:340)
	at org.eclipse.e4.core.internal.di.MethodRequestor.execute(MethodRequestor.java:55)
	at org.eclipse.e4.core.internal.di.InjectorImpl.processAnnotated(InjectorImpl.java:966)
	at org.eclipse.e4.core.internal.di.InjectorImpl.processAnnotated(InjectorImpl.java:931)
	at org.eclipse.e4.core.internal.di.InjectorImpl.inject(InjectorImpl.java:151)
	at org.eclipse.e4.core.internal.di.InjectorImpl.internalMake(InjectorImpl.java:375)
	at org.eclipse.e4.core.internal.di.InjectorImpl.make(InjectorImpl.java:294)
	at org.eclipse.e4.core.contexts.ContextInjectionFactory.make(ContextInjectionFactory.java:162)
	at org.eclipse.e4.ui.internal.workbench.ReflectionContributionFactory.createFromBundle(ReflectionContributionFactory.java:105)
	at org.eclipse.e4.ui.internal.workbench.ReflectionContributionFactory.doCreate(ReflectionContributionFactory.java:74)
	at org.eclipse.e4.ui.internal.workbench.ReflectionContributionFactory.create(ReflectionContributionFactory.java:56)
	at org.eclipse.e4.ui.workbench.renderers.swt.ContributedPartRenderer.createWidget(ContributedPartRenderer.java:129)
	at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.createWidget(PartRenderingEngine.java:975)
	at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.safeCreateGui(PartRenderingEngine.java:651)
	at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.safeCreateGui(PartRenderingEngine.java:757)
	at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.access$0(PartRenderingEngine.java:728)
	at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$2.run(PartRenderingEngine.java:722)
	at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.createGui(PartRenderingEngine.java:706)
	at org.eclipse.e4.ui.internal.workbench.PartServiceImpl$1.handleEvent(PartServiceImpl.java:104)
	at org.eclipse.e4.ui.services.internal.events.UIEventHandler$1.run(UIEventHandler.java:40)
	at org.eclipse.swt.widgets.Synchronizer.syncExec(Synchronizer.java:233)
	at org.eclipse.ui.internal.UISynchronizer.syncExec(UISynchronizer.java:145)
	at org.eclipse.swt.widgets.Display.syncExec(Display.java:4821)
	at org.eclipse.e4.ui.internal.workbench.swt.E4Application$1.syncExec(E4Application.java:211)
	at org.eclipse.e4.ui.services.internal.events.UIEventHandler.handleEvent(UIEventHandler.java:36)
	at org.eclipse.equinox.internal.event.EventHandlerWrapper.handleEvent(EventHandlerWrapper.java:201)
	at org.eclipse.equinox.internal.event.EventHandlerTracker.dispatchEvent(EventHandlerTracker.java:197)
	at org.eclipse.equinox.internal.event.EventHandlerTracker.dispatchEvent(EventHandlerTracker.java:1)
	at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:230)
	at org.eclipse.osgi.framework.eventmgr.ListenerQueue.dispatchEventSynchronous(ListenerQueue.java:148)
	at org.eclipse.equinox.internal.event.EventAdminImpl.dispatchEvent(EventAdminImpl.java:135)
	at org.eclipse.equinox.internal.event.EventAdminImpl.sendEvent(EventAdminImpl.java:78)
	at org.eclipse.equinox.internal.event.EventComponent.sendEvent(EventComponent.java:39)
	at org.eclipse.e4.ui.services.internal.events.EventBroker.send(EventBroker.java:94)
	at org.eclipse.e4.ui.internal.workbench.UIEventPublisher.notifyChanged(UIEventPublisher.java:60)
	at org.eclipse.emf.common.notify.impl.BasicNotifierImpl.eNotify(BasicNotifierImpl.java:374)
	at org.eclipse.e4.ui.model.application.ui.impl.ElementContainerImpl.setSelectedElement(ElementContainerImpl.java:173)
	at org.eclipse.e4.ui.internal.workbench.ModelServiceImpl.showElementInWindow(ModelServiceImpl.java:617)
	at org.eclipse.e4.ui.internal.workbench.ModelServiceImpl.bringToTop(ModelServiceImpl.java:581)
	at org.eclipse.e4.ui.internal.workbench.PartServiceImpl.delegateBringToTop(PartServiceImpl.java:770)
	at org.eclipse.e4.ui.internal.workbench.PartServiceImpl.bringToTop(PartServiceImpl.java:401)
	at org.eclipse.e4.ui.internal.workbench.PartServiceImpl.showPart(PartServiceImpl.java:1214)
	at org.eclipse.ui.internal.WorkbenchPage.busyOpenEditor(WorkbenchPage.java:3261)
	at org.eclipse.ui.internal.WorkbenchPage.access$25(WorkbenchPage.java:3176)
	at org.eclipse.ui.internal.WorkbenchPage$10.run(WorkbenchPage.java:3158)
	at org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPage.java:3153)
	at org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPage.java:3117)
	at org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPage.java:3107)
	at org.eclipse.ui.ide.IDE.openEditor(IDE.java:563)
	at org.eclipse.ui.ide.IDE.openEditor(IDE.java:518)
	at org.eclipse.ui.actions.OpenFileAction.openFile(OpenFileAction.java:100)
	at org.eclipse.ui.actions.OpenSystemEditorAction.run(OpenSystemEditorAction.java:97)
	at org.eclipse.ui.actions.RetargetAction.run(RetargetAction.java:225)
	at org.eclipse.ui.navigator.CommonNavigatorManager$2.open(CommonNavigatorManager.java:191)
	at org.eclipse.ui.OpenAndLinkWithEditorHelper$InternalListener.open(OpenAndLinkWithEditorHelper.java:46)
	at org.eclipse.jface.viewers.StructuredViewer$2.run(StructuredViewer.java:855)
	at org.eclipse.ui.internal.JFaceUtil$1.run(JFaceUtil.java:50)
	at org.eclipse.jface.util.SafeRunnable.run(SafeRunnable.java:173)
	at org.eclipse.jface.viewers.StructuredViewer.fireOpen(StructuredViewer.java:852)
	at org.eclipse.jface.viewers.StructuredViewer.handleOpen(StructuredViewer.java:1169)
	at org.eclipse.ui.navigator.CommonViewer.handleOpen(CommonViewer.java:451)
	at org.eclipse.jface.util.OpenStrategy.fireOpenEvent(OpenStrategy.java:278)
	at org.eclipse.jface.util.OpenStrategy.access$2(OpenStrategy.java:272)
	at org.eclipse.jface.util.OpenStrategy$1.handleEvent(OpenStrategy.java:313)
	at org.eclipse.swt.widgets.Display.sendEvent(Display.java:4418)
	at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1079)
	at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.java:4236)
	at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3824)
	at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$4.run(PartRenderingEngine.java:1121)
	at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.run(PartRenderingEngine.java:1022)
	at org.eclipse.e4.ui.internal.workbench.E4Workbench.createAndRunUI(E4Workbench.java:150)
	at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:693)
	at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:610)
	at org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:138)
	at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:673)
	at org.eclipse.equinox.launcher.Main.basicRun(Main.java:610)
	at org.eclipse.equinox.launcher.Main.run(Main.java:1519)
	at org.eclipse.equinox.launcher.Main.main(Main.java:1492)
Any idea how to solve this?
I have not yet tried to set the ResourceSetFactoryForMigration ....
Re: [Edapt] DiagnosticException while migrating [message #1767295 is a reply to message #1767287] Tue, 04 July 2017 09:41 Go to previous message
Hi Johannes,
it was my fault. After regenerating the EMF code all works well!
Thank you very much for your help, Martin
[Updated on: Tue, 04 July 2017 10:42] by Moderator
Previous Topic:Distinguishing "logical" Ecore elements from additional "technical" ones
Next Topic:StackOverflowError on EPackageRegistryImpl
Current Time: Sun Jul 20 17:36:44 EDT 2025
Powered by FUDForum. Page generated in 0.07134 seconds
