Home » Language IDEs » Java Development Tools (JDT) » Moving a Project to another Machine
Moving a Project to another Machine [message #176679] Mon, 06 September 2004 06:31 Go to next message
Originally posted by: dummy.dummy.net
What is the best way to move a project from one workspace on
machine A to another workspace on machine B (using Eclipse 3) ?
I searched in the doc, but didn't find a topic about this issue.
Thanks in advance for your help.
Zaack
Re: Moving a Project to another Machine [message #176688 is a reply to message #176679] Mon, 06 September 2004 06:52 Go to previous messageGo to next message
Originally posted by: hcs33.egon.gyaloglo.hu
If you don't use absolute paths (e.g in the classpath) you can simply copy
your project directory into another workspace, start Eclipse using the
target workspace and use File>Import>Existing project into workspace.
(if you use a version control system then checking all files in and check
out the whole project in the another workspace is a better way I think)
HTH,
Csaba
"Zaack" <dummy@dummy.net> wrote in message news:chhe3b$mvh$1@eclipse.org...
> Hello,
> Zaack
Re: Moving a Project to another Machine [message #176712 is a reply to message #176688] Mon, 06 September 2004 07:58 Go to previous message
I just wanted to add to that, that if you have linux AND windows
computers, sharing a project among several linux AND windows machines by
means of sharing the underlying filesystem is a very bad idea.
It is very likely it will mess your files with CR/LF problems.
Hope this helps,
Jean
Horváth, Csaba wrote:
> HTH,
> Regards,
> Csaba
>>Hello,
>>Zaack
Previous Topic:What is the package of a class??
Next Topic:Speed with very large codebases in eclipse
Current Time: Sat Jul 19 22:35:32 EDT 2025
Powered by FUDForum. Page generated in 0.05022 seconds
