Home » Eclipse Projects » Kura » Why git auth failed?
Why git auth failed? [message #1766673] Sat, 24 June 2017 22:15 Go to next message
undle org.eclipse.oomph.setup.workingsets 1.7.0.v20170104-1401, build=2932, branch=cc66c993507ade50e4b3a824a3adb4e94c4ac25f
Performing Git Clone git@github.com:eclipse/kura.git (develop)
Cloning Git repo git@github.com:eclipse/kura.git to F:\OpenIOT\Kura\iot-kura-develop3\git\kura
java.lang.Exception: org.eclipse.jgit.api.errors.TransportException: git@github.com:eclipse/kura.git: Auth fail
at org.eclipse.oomph.setup.git.impl.GitCloneTaskImpl.perform(GitCloneTaskImpl.java:882)
Re: Why git auth failed? [message #1767042 is a reply to message #1766673] Thu, 29 June 2017 18:45 Go to previous message
I believe the git option only works if you have used Eclipse to connect to Github repos in the past. Under "Eclipse Kura Git Repository" , please try one of the HTTPS entries. For example, mine is:
https://dwoodard1@github.com/eclipse/kura.git
Also, it looks like you are on a Windows system. The build will likely not work for Windows. I would recommend setting up a Linux VM if you plan on working with Kura source code.
--Dave
Previous Topic:Publish data to the cloud
Next Topic:Kura GPIO example
Current Time: Sun Jul 20 10:45:09 EDT 2025
Powered by FUDForum. Page generated in 0.03151 seconds
