Home » Modeling » TMF (Xtext) » Class not found exception in packaged plug-in. Xtext file .ui generate
Class not found exception in packaged plug-in. Xtext file .ui generate [message #1076896] Wed, 31 July 2013 21:42 Go to next message
Hello
I'm package a plugin made for me called mView. I create my plug in using xtext and it generate 2 files more than my original project (mView.test and mView.ui) I have a problem with deploying of my packaged plug-in (i.e., when it is not started in a runtime workbench).
The error is:
Plug-in mView.ui was unable to load class org.xtext.example.mydsl.ui.MViewExecutableExtensionFactory.
org.eclipse.core.runtime.CoreException: Plug-in mView.ui was unable to load class org.xtext.example.mydsl.ui.MViewExecutableExtensionFactory. at org.eclipse.core.internal.registry.osgi.RegistryStrategyOSGI.throwException(RegistryStrategyOSGI.java:194) at org.eclipse.core.internal.registry.osgi.RegistryStrategyOSGI.createExecutableExtension(RegistryStrategyOSGI.java:176) at org.eclipse.core.internal.registry.ExtensionRegistry.createExecutableExtension(ExtensionRegistry.java:905) at ..... Caused by: java.lang.ClassNotFoundException: org.xtext.example.mydsl.ui.MViewExecutableExtensionFactory at org.eclipse.osgi.internal.loader.BundleLoader.findClassInternal(BundleLoader.java:501) at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:421) at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:412) ....
I already ensure of the jdk and jre compatibility and all its ok. In the part of the MANIFIEST of the plug-in I already check the jar file that contains the plug-in classes and be listed in the Bundle-ClassPath. In the dependency's of the plug-in appears xtext and in the file built.properties is check the source folder in SourceBuild and BinaryBuild, but I can't find it more to do, I would greatly appreciate your help.
sorry for my English. Thank You!
PD: just for information. I package my plug-in following this turorial: http: //www.vogella.com/ articles/ EclipsePlugIn/ article.html#p2deployplugin_overview
Re: Class not found exception in packaged plug-in. Xtext file .ui generate [message #1076922 is a reply to message #1076896] Wed, 31 July 2013 22:40 Go to previous messageGo to next message
Hi can you please share your code
Need training, onsite consulting or any other kind of help for Xtext?
Go visit http://xtext.itemis.com or send a mail to xtext at itemis dot de
Re: Class not found exception in packaged plug-in. Xtext file .ui generate [message #1077387 is a reply to message #1076922] Thu, 01 August 2013 12:16 Go to previous messageGo to next message
I already fix it. The proyects that xtext generate mView.test and mView.ui dont have the built.properties file. I copy this file of the principal proyect, paste and modify in each project. And it works!... Thank You Smile
Re: Class not found exception in packaged plug-in. Xtext file .ui generate [message #1766746 is a reply to message #1076922] Mon, 26 June 2017 13:09 Go to previous messageGo to next message
Hi Christian,
I got the same issue within my project (on branch master):
https://github.com/marc-christian-schulze/structs4java
Could you please have a look at the sources?
I already checked the build.properties files but they seem to be ok.
Best regards
Christian
[Updated on: Mon, 26 June 2017 13:11] by Moderator
Re: Class not found exception in packaged plug-in. Xtext file .ui generate [message #1766747 is a reply to message #1766746] Mon, 26 June 2017 13:25 Go to previous messageGo to next message
for me it looks like the complete maven config is broken (config of source folders etc ...)
this might be caused by not checking in .classpath /.project files
Re: Class not found exception in packaged plug-in. Xtext file .ui generate [message #1766748 is a reply to message #1766747] Mon, 26 June 2017 14:08 Go to previous messageGo to next message
i just built with pure maven and not importing anything into eclipse and it worked fine after installing into a eclipse.
Re: Class not found exception in packaged plug-in. Xtext file .ui generate [message #1766924 is a reply to message #1766748] Wed, 28 June 2017 14:24 Go to previous messageGo to next message
Seems I found my mistakes:
1. Eclipse Configuration not generated by m2e-Connector:
My assumption was that the m2e plugin has a connector to configure Eclipse properly for the xtext plugin but it didn't.
But copying the example configuration from your github project resolved almost all error markers:
https://github.com/xtext/maven-xtext-example
2. Forgot to install the MWE 2 language SDK:
After copying the Eclipse configuration only the following error message was left:
"Bundle org.eclipse.emf.mwe2.launch cannot be resolved"
After some web crawling I read in the following article that I missed to install the "MWE 2 language SDK" plugin:
https://www.eclipse.org/forums/index.php/t/164527/
But after that Eclipse gladly runs my plugin in the debugger. :)
Best regards
Christian
Re: Class not found exception in packaged plug-in. Xtext file .ui generate [message #1766925 is a reply to message #1766748] Wed, 28 June 2017 14:24 Go to previous messageGo to next message
Best regards
Christian
Re: Class not found exception in packaged plug-in. Xtext file .ui generate [message #1766926 is a reply to message #1766748] Wed, 28 June 2017 14:25 Go to previous messageGo to next message
Best regards
Christian
Re: Class not found exception in packaged plug-in. Xtext file .ui generate [message #1766927 is a reply to message #1766748] Wed, 28 June 2017 14:25 Go to previous message
Best regards
Christian
Previous Topic:Problem with external ecore model
Next Topic:X-Text Linking Services
Current Time: Sun Jul 20 12:48:39 EDT 2025
Powered by FUDForum. Page generated in 0.25686 seconds
