Home » Newcomers » Newcomers » Neon.3 crashes after Linux update(Neon.3 crashes at start after Linux kernel update)
Neon.3 crashes after Linux update [message #1766851] Wed, 28 June 2017 04:26 Go to next message
Eclipse Neon.3 refuses to start after Kubuntu 14.04LTS kernel was updated from version 3.13.0-119 to version 3.13.0-121. The crash occurs so early in the start sequence that there are no log entries and no JVM crash message.
The only message is on a console start:
tauno@ubuntu:~$ tauno@ubuntu:~$ cd ide-latest-released/
tauno@ubuntu:~/ide-latest-released$ eclipse/eclipse -consoleLog
Segmentation fault (core dumped)
How and where to trace the problem?
Update: The same happens on Kubuntu 16.04LTS with kernel update from 4.4.0.77 to 4.4.0.81.
It seems that the crash is related to the recent security update of the kernel.
[Updated on: Wed, 28 June 2017 14:34] by Moderator
Re: Neon.3 crashes after Linux update [message #1767597 is a reply to message #1766851] Fri, 07 July 2017 06:59 Go to previous messageGo to next message
I just checked. I run 4.4.0-83 on Linux Mint (Ubuntu 16.04 LTS). No problems whatsoever.
Re: Neon.3 crashes after Linux update (SOLVED) [message #1767617 is a reply to message #1767597] Fri, 07 July 2017 12:42 Go to previous message
You're right. The current kernel updates, 4.4.0-83 for 16.04 and 3.13.0-123 do work.
It seems to me that the previous kernel update (-81 and -121) was fishy.
Case closed.
[Updated on: Fri, 07 July 2017 12:43] by Moderator
Previous Topic:outline view empty
Next Topic:Device not recognized
Current Time: Sun Jul 20 17:59:56 EDT 2025
Powered by FUDForum. Page generated in 0.07399 seconds
