Home » Eclipse Projects » EclipseLink » HistoryPolicy: Remove fields from history table
HistoryPolicy: Remove fields from history table [message #1766767] Tue, 27 June 2017 02:47
I successfully added a HistoryPolicy using a customizer as described in the example in the EclipseLink Wiki.
However, I want to omit some of the fields from the history table.
I tried to fiddle with the descriptor's mappings, but it seems this also affects the original entity and not only the mapping for the history table.
Is there any way to remove fields (field mappings?) before storing the history? I've read that one can query the entity's state at a certain point back in time using query hints, so I see the point why removing partial information isn't a good idea. In our case, this wouldn't matter, as the table would be only consumed by another application.
Thanks for your help!
Previous Topic:Persist vs Merge different exception handling
Next Topic:Use moxy to handle 3rd party interfaces
Current Time: Sun Jul 20 10:37:44 EDT 2025
Powered by FUDForum. Page generated in 0.07947 seconds
