Home » Eclipse Projects » Eclipse Platform » WizardPage Refresh
WizardPage Refresh [message #16723] Sat, 26 April 2003 15:21 Go to next message
Originally posted by: a_shishkov.yahoo.com
I have a one page wizard with a Combo control and a Composite below that.
Depending on the selection in the Combo, different content is drawn into the
Composite. My problem is that the initial drawing of the Composite (in the
createControl method) works fine, but subsequent drawing (triggered by the
Combo's SelectionListener) has no effect. I have tried disposing of all the
Composite's children before drawing into it, but that just leaves me with an
empty, gray Composite.
My code is something like this:
class ColorSchemaPage extends WizardPage {
// constructor etc.
public void createControl(Composite parent) {
colorsCombo = new Combo(parent, SWT.SINGLE | SWT.READ_ONLY);
// populate the combo
colorsCombo.addSelectionListener(new SelectionAdapter() {
public void widgetSelected(SelectionEvent e) {
String selection =
colorsCombo.getItem(colorsCombo.getSelectionIndex());
Control[] children = colorControl.getChildren();
for (int c=0; c<children.length; c++)
children[c].dispose();
drawSomeStuff(selection, colorControl);
colorControl = new Composite(parent, SWT.BORDER);
// this works
drawSomeStuff(colorControl);
setControl(parent);
Any ideas why the composite is not getting redrawn when a new Combo
selection is made? All that happens is the Composite gets cleared and stays
gray. I have found an identical question on the group, which was left
unanswered.
Thanks in advance for any help!
Angel
Re: WizardPage Refresh [message #17639 is a reply to message #16723] Sun, 27 April 2003 01:10 Go to previous messageGo to next message
Um, I think you shouldn't need to recreate the widgets in most cases. I think
what you are missing is a call to WizardPage.setPageComplete(boolean) -- give
that a try.
HTH,
Paul K
Angel Shishkov wrote:
> Hello,
> // constructor etc.
> String selection =
> // this works
> setControl(parent);
> unanswered.
> Angel
Re: WizardPage Refresh [message #17666 is a reply to message #17639] Sun, 27 April 2003 13:31 Go to previous messageGo to next message
Thanks, I tried setPageComplete(true) after I update the Composite but it is
still not refreshed. It seems that anything I draw into that Composite after
I am out of the createControl method does not appear there. This is strange
because I can *remove* widgets from the composite, I can change its
background color, but when I add a widget to it, it does not appear.
Angel
"Paul T. Keyser" <rolarenfan@earthlink.net> wrote in message
news:3EAB664D.4B3010E1@earthlink.net...
think
give
> that a try.
> HTH,
> Paul K
> > Hello,
that.
the
the
the
the
with an
> > // constructor etc.
> > String selection =
> > // this works
> > setControl(parent);
stays
> > unanswered.
> > Angel
Re: WizardPage Refresh [message #17678 is a reply to message #16723] Sun, 27 April 2003 14:24 Go to previous messageGo to next message
Fixed it. For those interested, you need to call Composite.layout() whenever
you dynamically add a widget to the composite, outside of the initial
createParts method.
For instance, in my SelectionListener I should be calling
colorControl.layout() after my call to drawSomeStuff.
Angel
"Angel Shishkov" <a_shishkov@yahoo.com> wrote in message
news:b8em4q$2sn$1@rogue.oti.com...
> Hello,
the
the
an
> // constructor etc.
> String selection =
> // this works
> setControl(parent);
stays
> unanswered.
> Angel
Re: WizardPage Refresh [message #19565 is a reply to message #17678] Mon, 28 April 2003 10:43 Go to previous messageGo to next message
Originally posted by: tod_creasey.oti.com
As another note it is usually easier to use setVisible() to get rid of
widgets that you are not currently using but may again (see
TitleAreaDialog).
Tod Creasey
Software Developer
Eclipse Team
news:b8h76p$gbf$1@rogue.oti.com...
whenever
> createParts method.
> Angel
> > Hello,
that.
> the
the
the
> the
with
> an
> > // constructor etc.
> > String selection =
> > // this works
> > setControl(parent);
> stays
> > unanswered.
> > Angel
Re: WizardPage Refresh [message #45425 is a reply to message #17666] Fri, 23 May 2003 08:56 Go to previous message
Originally posted by: anthony.saucet.freesbee.fr
How do you 'remove' widgets from the composite?
thanks
anthony
> Angel
> think
> give
> > that a try.
> > HTH,
> > Paul K
> > > Hello,
> that.
> the
> the
> the
> the
> with an
> > > // constructor etc.
> > > String selection =
> > > // this works
> > > setControl(parent);
> stays
> > > unanswered.
> > > Angel
Previous Topic:Added menuitem doesn't showup
Next Topic:Eclipse built-in CVS and TortoiseCVS again
Current Time: Sat Jul 19 05:30:17 EDT 2025
Powered by FUDForum. Page generated in 0.03133 seconds
