Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc)  » distinguish between EClasses
distinguish between EClasses [message #1766525] Thu, 22 June 2017 11:36 Go to next message
I create two Ecore EClasses with the same name in my code. Since EClass [name=Column, instanceClassName=null, instanceClass=null, defaultValue=null, instanceTypeName=null, abstract=false, interface=false, ] cannot specifies the difference of these classes, how can I distinguish between these classes?
Re: distinguish between EClasses [message #1766527 is a reply to message #1766525] Thu, 22 June 2017 12:16 Go to previous messageGo to next message
In Java, you can use the qualified name when you want to use classes with same name in some code. Something like...
com.packageA.Class packageAClass = new com.packageA.Class();
com.packageB.Class packageBClass = new com.packageB.Class();
Re: distinguish between EClasses [message #1766528 is a reply to message #1766525] Thu, 22 June 2017 12:16 Go to previous messageGo to next message
No Message Body
[Updated on: Thu, 22 June 2017 12:18] by Moderator
Re: distinguish between EClasses [message #1766530 is a reply to message #1766527] Thu, 22 June 2017 12:46 Go to previous messageGo to next message
Thanks for your reply.
I want to use it in EOL.
Re: distinguish between EClasses [message #1766536 is a reply to message #1766530] Thu, 22 June 2017 14:31 Go to previous messageGo to next message
If the two EClasses are different, they are different and there should be no problem. How do you fail to distinguish?
Of course if they are not different you are in deep trouble and need to rethink.
Ed Willink
Re: distinguish between EClasses [message #1766565 is a reply to message #1766536] Fri, 23 June 2017 02:37 Go to previous messageGo to next message
They are different but with the same name. It seems they don't have an id.
[Updated on: Fri, 23 June 2017 02:39] by Moderator
Re: distinguish between EClasses [message #1766568 is a reply to message #1766565] Fri, 23 June 2017 04:04 Go to previous messageGo to next message
If you try validating your Ecore model, you should see a validation error.
Two classes with the same name (in the same package) is an absolute no-no in EMF (and in UML). Just about as stupid as the parents of twins giving both twins the same name.
Ed Willink
Re: distinguish between EClasses [message #1766603 is a reply to message #1766568] Fri, 23 June 2017 08:11 Go to previous messageGo to next message
Thanks.
However, in transformations we have such things. e.g., in the code below 4 instances of columns is created and we need to distinguish between them.
rule Class2Table
  transform c : OO!Class
  to t : DB!Table, pk : DB!Column {
   if (c.`extends`.isDefined()){
    var childFkCol : new DB!Column;
    var parentFkCol : DB!Column;
rule SingleValuedAttribute2Column
  transform a : OO!Attribute
  to c : DB!Column {
But my question is about EClass, Isn't there any such an id that we can distinguish between them?
Re: distinguish between EClasses [message #1766616 is a reply to message #1766603] Fri, 23 June 2017 09:43 Go to previous message
You can contrive all sorts of things, but until you motivate identical names, you're not going to get much help. EClasses MUST have different names wrt their EPackage. You can have duplicates, but expect to have to produce a modified version of every tool that you use thereafter.
A common approach used in graphical tools is to auto-name as NewClass1, NewClass2, NewClass3, ...
A necessary approach for transformations that must comply with WFRs is to have a name supervisor that fixes duplicates and embarrassing names such as a Java class named "class" or "1£$%".
Ed Willink
Previous Topic:EMF to USE
Next Topic:Distinguishing "logical" Ecore elements from additional "technical" ones
Current Time: Sun Jul 20 12:44:49 EDT 2025
Powered by FUDForum. Page generated in 0.04117 seconds
