Click 'Help->Help Contents', Eclipse is crashed in Linux [message #1765321] |
Thu, 08 June 2017 08:26  |
To whom it may concern,
When I click 'Help->Help Contents' menu on Linux (Neon 4.6.3). The Eclipse platform always no responding and Crash.
So does there have any one know is it a bug or how to fix it?
Thank you.
Eclipse Version
Eclipse Modeling Tools
Version: Neon.3 Release (4.6.3)
Build id: 20170314-1500
Linux Version
Linux version 2.6.32-431.el6.x86_64 (mockbuild@x86-023.build.eng.bos.redhat.com) (gcc version 4.4.7 20120313 (Red Hat 4.4.7-4) (GCC) ) #1 SMP Sun Nov 10 22:19:54 EST 2013
Java Version
java version "1.8.0_131"
Java(TM) SE Runtime Environment (build 1.8.0_131-b11)
Java HotSpot(TM) 64-Bit Server VM (build 25.131-b11, mixed mode)
==================================Info================================
# A fatal error has been detected by the Java Runtime Environment:
# SIGSEGV (0xb) at pc=0x00007fdcc80bb030, pid=5134, tid=0x00007fddde5be700
# JRE version: Java(TM) SE Runtime Environment (8.0_131-b11) (build 1.8.0_131-b11)
# Java VM: Java HotSpot(TM) 64-Bit Server VM (25.131-b11 mixed mode linux-amd64 compressed oops)
# Problematic frame:
# C 0x00007fdcc80bb030
# Failed to write core dump. Core dumps have been disabled. To enable core dumping, try "ulimit -c unlimited" before starting Java again
# If you would like to submit a bug report, please visit:
# http://bugreport.java.com/bugreport/crash.jsp
# The crash happened outside the Java Virtual Machine in native code.
# See problematic frame for where to report the bug.
[Updated on: Tue, 20 June 2017 21:34] by Moderator
Re: Click 'Help->Help Contents', Eclipse is crashed in Linux [message #1766879 is a reply to message #1766837] |
Wed, 28 June 2017 09:29  |
And I follow your step: (Quick Access > "Web Browser" and select the "Internal Web Browser")
If I do not set the web location (defaule:empty page), the browser works will.
If I point the location to the Help Content Part. such as: http://127.0.0.1:39373/help/nav/15,
the Platform also crash.
Can you try using a different URL instead of your local help on localhost, like www.eclipse.org? Does that crash? That will help isolate whether it's the SWT Browser crashing (my suspicion) or the Help system crashing (seems very unlikely to crash the JVM).
From the .logs it looks like SWT Browser crashing:
Stack: [0x00007f5d7cd6a000,0x00007f5d7ce6b000], sp=0x00007f5d7ce677b0, free space=1013k
Native frames: (J=compiled Java code, j=interpreted, Vv=VM code, C=native code)
C 0x00007f5c7c928000
C [libwebkit-1.0.so.2+0xa8a2c0]
Java frames: (J=compiled Java code, j=interpreted, Vv=VM code)
J 5706 org.eclipse.swt.internal.gtk.OS._g_main_context_iteration(JZ)Z (0 bytes) @ 0x00007f5d691007c4 [0x00007f5d69100780+0x44]
J 10068 C2 org.eclipse.swt.widgets.Display.readAndDispatch()Z (71 bytes) @ 0x00007f5d6a97c154 [0x00007f5d6a97bea0+0x2b4]
j org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$4.run()V+530
j org.eclipse.core.databinding.observable.Realm.runWithDefault(Lorg/eclipse/core/databinding/observable/Realm;Ljava/lang/Runnable;)V+12
I'm not sure what version of version of RHEL you're using. You may well have buggy versions of GTK3 libraries. Perhaps you could try running with SWT_GTK3=0 in your environment (or launch Eclipse with "--launcher.GTK_version 2") and see if that helps.
Brian.
FUDForum. Page generated in 0.03981 seconds
