Home » Eclipse Projects » EclipseLink » Oracle Wallet Configuration (using Oracle Wallet under Eclipselink JPA )
Oracle Wallet Configuration [message #1765879] Wed, 14 June 2017 03:37 Go to next message
I am successfully able to connect to my db using oracle wallet from a jdbc thin driver. When i am trying to do the same using eclipselink it is giving invalid username password.
Here is my configuration
JDBC url : jdbc:oracle:thin:/@orcl
Driver : oracle.jdbc.OracleDriver
i skipped user/password as oracle wallet contains them
Entity manager is not getting created with the following exception
javax.persistence.PersistenceException: Exception [EclipseLink-4002] (Eclipse Persistence Services - 2.5.0.v20130507-3faac2b): org.eclipse.persistence.exceptions.DatabaseException
Internal Exception: java.sql.SQLException: ORA-01017: invalid username/password; logon denied
Error Code: 1017
at org.eclipse.persistence.internal.jpa.EntityManagerSetupImpl.deploy(EntityManagerSetupImpl.java:762)
at org.eclipse.persistence.internal.jpa.EntityManagerFactoryDelegate.getAbstractSession(EntityManagerFactoryDelegate.java:204)
at org.eclipse.persistence.internal.jpa.EntityManagerFactoryDelegate.createEntityManagerImpl(EntityManagerFactoryDelegate.java:304)
at org.eclipse.persistence.internal.jpa.EntityManagerFactoryImpl.createEntityManagerImpl(EntityManagerFactoryImpl.java:336)
at org.eclipse.persistence.internal.jpa.EntityManagerFactoryImpl.createEntityManager(EntityManagerFactoryImpl.java:309)
Re: Oracle Wallet Configuration [message #1765968 is a reply to message #1765879] Wed, 14 June 2017 11:55 Go to previous messageGo to next message
What api do you use to connect when using the wallet manager? Logging in EclipseLInk will show what it is using, but you are better off creating your own datasource and having EclipseLink use that if you want to use a non-standard way of connecting.
Re: Oracle Wallet Configuration [message #1766036 is a reply to message #1765968] Thu, 15 June 2017 00:17 Go to previous messageGo to next message
Thanks!
But Datasources is not of an option here as i am running it standalone.
Oracle Wallet is a secure way of connecting from jdbc application to a oracle database.
When i try from normal jdbc using the following it works without any issue
String url = "jdbc:oracle:thin:/@" + walletId;
Connection conn = null;
Properties props = new Properties();
Class.forName("oracle.jdbc.OracleDriver");
//STEP 3: Open a connection
System.out.println("Connecting to database..." + url);
conn = DriverManager.getConnection(url, props);
Statement stmt = conn.createStatement();
System.out.println("Statement Created");
I dont need of passing username password only wallet id where i have my database information
I think i might need to override the DefaultConnector implementation to handle this kind of implementation..
[Updated on: Thu, 15 June 2017 00:29] by Moderator
Re: Oracle Wallet Configuration [message #1766059 is a reply to message #1766036] Thu, 15 June 2017 05:42 Go to previous messageGo to next message
@Chris Delahunt
I have some how made it run using OracleDatasource
Is there any way to make eclipselink to use OracleDataSource?
[Updated on: Thu, 15 June 2017 05:44] by Moderator
Re: Oracle Wallet Configuration [message #1766106 is a reply to message #1766059] Thu, 15 June 2017 14:17 Go to previous messageGo to next message
See http://onpersistence.blogspot.com/2008/04/eclipselink-and-datasources.html
Re: Oracle Wallet Configuration [message #1766111 is a reply to message #1765879] Thu, 15 June 2017 21:31 Go to previous messageGo to next message
First thing i tried that only but that was pretty old blog and lot of changes in eclipselink from then and that way is not supported.
Re: Oracle Wallet Configuration [message #1766112 is a reply to message #1766111] Thu, 15 June 2017 22:43 Go to previous messageGo to next message
Not sure where you get that impression from, as that is how I do it using EclipseLink version 2.6.4. I'm sure it still works in later versions. What errors are you getting?
Re: Oracle Wallet Configuration [message #1766113 is a reply to message #1766112] Thu, 15 June 2017 23:36 Go to previous messageGo to next message
Sorry it worked,
I was not passing the correct persistence name . Now i am able to create the entity manager without any issue.
Thank you very much and appreciate your time.
Here is the code that worked for me for others reference
public DataSource getDataSource()throws Exception{
String url = "jdbc:oracle:thin:/@orcl"; // orcl is the wallet id i am using here
OracleDataSource source = new OracleDataSource();
source.setDriverType("oracle.jdbc.OracleDriver");
source.setURL( url );
source.setDataSourceName("jdbc/myOracleDatasource");
return source;
// emf & em creation
properties
.put(PersistenceUnitProperties.NON_JTA_DATASOURCE,getDataSource());
emf = Persistence.createEntityManagerFactory("IFX_PERSISTENCE", properties);
EntityManager em = emf.createEntityManager();
[Updated on: Thu, 15 June 2017 23:38] by Moderator
Re: Oracle Wallet Configuration [message #1766115 is a reply to message #1766113] Fri, 16 June 2017 01:46 Go to previous message
Thanks for the help
I have added the full details of Wallet creation and the way to connect to database using eclipselink.
Hope this will help others who want to learn more about Wallet configuration
http://javaperformancetools.blogspot.in/2017/06/oracle-wallet-jdbc-jpa-configuration.html
Madhukar
Previous Topic:eclipselink 2.6.4 STUCK thead
Next Topic:How to define xml name and plural name of a TAG
Current Time: Sat Jul 19 20:45:16 EDT 2025
Powered by FUDForum. Page generated in 0.27915 seconds
