Home » Eclipse Projects » EGit / JGit » Followed "Automated Developer Setup" instructions and got "Invalid @since 4.8 tag on
Followed "Automated Developer Setup" instructions and got "Invalid @since 4.8 tag on [message #1764993] Mon, 05 June 2017 11:28 Go to next message
To setup EGit development environment, I followed "Automated Developer Setup" instructions on http://wiki.eclipse.org/EGit/Contributor_Guide#Automated_Developer_Setup.
  • OS: Ubuntu Linux 16.04 x86_64
  • JVM: openjdk version "1.8.0_131", OpenJDK Runtime Environment (build 1.8.0_131-8u131-b11-0ubuntu1.16.04.2-b11)
  • Selected "Latest (Oxygen)" for Product Version on Eclipse Installer.
When I finished the instructions, the Problems view on Eclipse showed errors below.
[Project]-[Clean...]-[Clean all projects] did not resolve these errors.
How can I resolve them?
([Window]-[Preferences]-[Java]-[Compiler]-[Javadoc] options are all set to "ignore".)
Description	Resource	Path	Location	Type
Invalid @since 4.8 tag on addLinkFile(RepoProject.LinkFile); expecting @since 4.9	RepoProject.java	/org.eclipse.jgit/src/org/eclipse/jgit/gitrepo	line 398	@since tag problem
Invalid @since 4.8 tag on addLinkFiles(Collection<RepoProject.LinkFile>); expecting @since 4.9	RepoProject.java	/org.eclipse.jgit/src/org/eclipse/jgit/gitrepo	line 408	@since tag problem
Invalid @since 4.8 tag on BundleWriter(ObjectReader); expecting @since 4.9	BundleWriter.java	/org.eclipse.jgit/src/org/eclipse/jgit/transport	line 123	@since tag problem
Invalid @since 4.8 tag on Callback; expecting @since 4.9	CloneCommand.java	/org.eclipse.jgit/src/org/eclipse/jgit/api	line 123	@since tag problem
Invalid @since 4.8 tag on clearLinkFiles(); expecting @since 4.9	RepoProject.java	/org.eclipse.jgit/src/org/eclipse/jgit/gitrepo	line 417	@since tag problem
Invalid @since 4.8 tag on getLinkFiles(); expecting @since 4.9	RepoProject.java	/org.eclipse.jgit/src/org/eclipse/jgit/gitrepo	line 302	@since tag problem
Invalid @since 4.8 tag on LinkFile; expecting @since 4.9	RepoProject.java	/org.eclipse.jgit/src/org/eclipse/jgit/gitrepo	line 155	@since tag problem
Invalid @since 4.8 tag on Merger(ObjectInserter); expecting @since 4.9	Merger.java	/org.eclipse.jgit/src/org/eclipse/jgit/merge	line 133	@since tag problem
Invalid @since 4.8 tag on newMerger(ObjectInserter, Config); expecting @since 4.9	MergeStrategy.java	/org.eclipse.jgit/src/org/eclipse/jgit/merge	line 190	@since tag problem
Invalid @since 4.8 tag on newMerger(ObjectInserter, Config); expecting @since 4.9	StrategyResolve.java	/org.eclipse.jgit/src/org/eclipse/jgit/merge	line 69	@since tag problem
Invalid @since 4.8 tag on newMerger(ObjectInserter, Config); expecting @since 4.9	StrategySimpleTwoWayInCore.java	/org.eclipse.jgit/src/org/eclipse/jgit/merge	line 97	@since tag problem
Invalid @since 4.8 tag on nonNullRepo(); expecting @since 4.9	Merger.java	/org.eclipse.jgit/src/org/eclipse/jgit/merge	line 154	@since tag problem
Invalid @since 4.8 tag on parseCommit(AnyObjectId); expecting @since 4.9	Repository.java	/org.eclipse.jgit/src/org/eclipse/jgit/lib	line 1168	@since tag problem
Invalid @since 4.8 tag on RecursiveMerger(ObjectInserter, Config); expecting @since 4.9	RecursiveMerger.java	/org.eclipse.jgit/src/org/eclipse/jgit/merge	line 122	@since tag problem
Invalid @since 4.8 tag on ReferenceFile; expecting @since 4.9	RepoProject.java	/org.eclipse.jgit/src/org/eclipse/jgit/gitrepo	line 83	@since tag problem
Invalid @since 4.8 tag on relativizeGitPath(String, String); expecting @since 4.9	FileUtils.java	/org.eclipse.jgit/src/org/eclipse/jgit/util	line 527	@since tag problem
Invalid @since 4.8 tag on relativizeNativePath(String, String); expecting @since 4.9	FileUtils.java	/org.eclipse.jgit/src/org/eclipse/jgit/util	line 510	@since tag problem
Invalid @since 4.8 tag on relativizePath(String, String, String, boolean); expecting @since 4.9	FileUtils.java	/org.eclipse.jgit/src/org/eclipse/jgit/util	line 564	@since tag problem
Invalid @since 4.8 tag on ResolveMerger(ObjectInserter, Config); expecting @since 4.9	ResolveMerger.java	/org.eclipse.jgit/src/org/eclipse/jgit/merge	line 314	@since tag problem
Invalid @since 4.8 tag on setCallback(CloneCommand.Callback); expecting @since 4.9	CloneCommand.java	/org.eclipse.jgit/src/org/eclipse/jgit/api	line 616	@since tag problem
Invalid @since 4.8 tag on setCallback(CloneCommand.Callback); expecting @since 4.9	SubmoduleUpdateCommand.java	/org.eclipse.jgit/src/org/eclipse/jgit/api	line 245	@since tag problem
Invalid @since 4.8 tag on setTargetURI(String); expecting @since 4.9	RepoCommand.java	/org.eclipse.jgit/src/org/eclipse/jgit/gitrepo	line 295	@since tag problem
Invalid @since 4.8 tag on shift(int); expecting @since 4.9	Edit.java	/org.eclipse.jgit/src/org/eclipse/jgit/diff	line 180	@since tag problem
Invalid @since 4.8 tag on ThreeWayMerger(ObjectInserter); expecting @since 4.9	ThreeWayMerger.java	/org.eclipse.jgit/src/org/eclipse/jgit/merge	line 95	@since tag problem
Re: Followed "Automated Developer Setup" instructions and got "Invalid @since 4.8 tag [message #1765025 is a reply to message #1764993] Mon, 05 June 2017 15:35 Go to previous messageGo to next message
1.Download https://repo.eclipse.org/content/groups/snapshots/org/eclipse/egit/org.eclipse.egit.repository/4.8.0-SNAPSHOT/org.eclipse.egit.repository-4.8.0-20170531.002236-40.zip
2. Unzip into a directory of your choice
3. In Eclipse, set the unzipped org.eclipse.egit.repository-4.8.0-20170531.002236-40 directory as API baseline (under Preferences->Plugin Development->API Baselines; choose "Existing Eclipse installation")
4. Then define the new baseline as the active one and do a full build.
We'll fix the Oomph setup once EGit 4.8.0 has been released so that it'll then use the official 4.8.0 as API baseline out of the box.
Re: Followed "Automated Developer Setup" instructions and got "Invalid @since 4.8 tag [message #1765353 is a reply to message #1765025] Thu, 08 June 2017 12:15 Go to previous messageGo to next message
Thank you for your advice. I followed your instructions and all errors are resolved.
Re: Followed "Automated Developer Setup" instructions and got "Invalid @since 4.8 tag [message #1765451 is a reply to message #1765353] Fri, 09 June 2017 11:43 Go to previous messageGo to next message
The error "Invalid @since 4.8 tag on ~" had been resolved, but I got another error when right click on the "org.eclipse.egit.ui" project and select Debug As > Eclipse Application.
!SESSION 2017-06-10 00:26:37.282 -----------------------------------------------
eclipse.buildId=unknown
java.version=1.8.0_131
BootLoader constants: OS=linux, ARCH=x86_64, WS=gtk, NL=ja_JP
Framework arguments:  -product org.eclipse.platform.ide
Command-line arguments:  -product org.eclipse.platform.ide -data /home/satob/egit-master/ws/../runtime-egit-github -dev file:/home/satob/egit-master/ws/.metadata/.plugins/org.eclipse.pde.core/egit-github/dev.properties -os linux -ws gtk -arch x86_64 -consoleLog
!ENTRY org.eclipse.compare 4 0 2017-06-10 00:26:41.026
!MESSAGE FrameworkEvent ERROR
!STACK 0
org.osgi.framework.BundleException: Could not resolve module: org.eclipse.compare [16]
  Unresolved requirement: Require-Bundle: org.eclipse.ui.workbench.texteditor; bundle-version="[3.5.0,4.0.0)"
    -> Bundle-SymbolicName: org.eclipse.ui.workbench.texteditor; bundle-version="3.10.1.v20160818-1626"; singleton:="true"
       org.eclipse.ui.workbench.texteditor [171]
         Unresolved requirement: Require-Bundle: org.eclipse.ui; bundle-version="[3.5.0,4.0.0)"
           -> Bundle-SymbolicName: org.eclipse.ui; bundle-version="3.108.1.v20160929-1045"; singleton:="true"
              org.eclipse.ui [154]
                Unresolved requirement: Require-Bundle: org.eclipse.ui.workbench; bundle-version="[3.105.0,4.0.0)"; visibility:="reexport"
                  -> Bundle-SymbolicName: org.eclipse.ui.workbench; bundle-version="3.108.3.v20170216-1539"; singleton:="true"
                     org.eclipse.ui.workbench [170]
                       Unresolved requirement: Import-Package: javax.inject; version="1.0.0"
  Unresolved requirement: Require-Bundle: org.eclipse.ui.forms; bundle-version="[3.2.0,4.0.0)"
    -> Bundle-SymbolicName: org.eclipse.ui.forms; bundle-version="3.7.1.v20161220-1635"; singleton:="true"
       org.eclipse.ui.forms [160]
         Unresolved requirement: Require-Bundle: org.eclipse.e4.ui.css.core; bundle-version="0.10.100"
         Unresolved requirement: Require-Bundle: org.eclipse.ui; bundle-version="[3.105.0,4.0.0)"; resolution:="optional"
  Unresolved requirement: Require-Bundle: org.eclipse.ui.editors; bundle-version="[3.5.0,4.0.0)"
    -> Bundle-SymbolicName: org.eclipse.ui.editors; bundle-version="3.10.1.v20161106-1856"; singleton:="true"
       org.eclipse.ui.editors [158]
         Unresolved requirement: Require-Bundle: org.eclipse.ui.ide; bundle-version="[3.5.0,4.0.0)"
           -> Bundle-SymbolicName: org.eclipse.ui.ide; bundle-version="3.12.3.v20170119-0935"; singleton:="true"
              org.eclipse.ui.ide [161]
                Unresolved requirement: Require-Bundle: org.eclipse.ui; bundle-version="[3.106.0,4.0.0)"
                Unresolved requirement: Require-Bundle: org.eclipse.ui.workbench; bundle-version="[3.7.0,4.0.0)"
  Unresolved requirement: Require-Bundle: org.eclipse.ui.views; bundle-version="[3.2.0,4.0.0)"
    -> Bundle-SymbolicName: org.eclipse.ui.views; bundle-version="3.8.102.v20170111-0801"; singleton:="true"
       org.eclipse.ui.views [168]
  Unresolved requirement: Require-Bundle: org.eclipse.ui.ide; bundle-version="[3.3.0,4.0.0)"
	at org.eclipse.osgi.container.Module.start(Module.java:444)
	at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.incStartLevel(ModuleContainer.java:1620)
	at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.incStartLevel(ModuleContainer.java:1599)
	at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.doContainerStartLevel(ModuleContainer.java:1571)
	at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.dispatchEvent(ModuleContainer.java:1514)
	at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.dispatchEvent(ModuleContainer.java:1)
	at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:230)
	at org.eclipse.osgi.framework.eventmgr.EventManager$EventThread.run(EventManager.java:340)
!ENTRY org.eclipse.debug.ui 4 0 2017-06-10 00:26:41.055
!STACK 0
org.osgi.framework.BundleException: Could not resolve module: org.eclipse.debug.ui [34]
  Unresolved requirement: Require-Bundle: org.eclipse.ui.console; bundle-version="[3.5.300,4.0.0)"
    -> Bundle-SymbolicName: org.eclipse.ui.console; bundle-version="3.6.201.v20161107-0337"; singleton:="true"
       org.eclipse.ui.console [157]
  Unresolved requirement: Import-Package: org.eclipse.ui.forms.widgets
    -> Export-Package: org.eclipse.ui.forms.widgets; bundle-symbolic-name="org.eclipse.ui.forms"; bundle-version="3.7.1.v20161220-1635"; version="0.0.0"
!ENTRY org.eclipse.egit.core 4 0 2017-06-10 00:26:41.061
!STACK 0
org.osgi.framework.BundleException: Could not resolve module: org.eclipse.egit.core [42]
  Unresolved requirement: Import-Package: org.eclipse.jgit.annotations; version="[4.9.0,4.10.0)"
    -> Export-Package: org.eclipse.jgit.annotations; bundle-symbolic-name="org.eclipse.jgit"; bundle-version="4.9.0.qualifier"; version="4.9.0"
       org.eclipse.jgit [107]
         Unresolved requirement: Import-Package: com.googlecode.javaewah; version="[1.1.6,2.0.0)"
  Unresolved requirement: Import-Package: org.eclipse.jgit.api; version="[4.9.0,4.10.0)"
    -> Export-Package: org.eclipse.jgit.api; bundle-symbolic-name="org.eclipse.jgit"; bundle-version="4.9.0.qualifier"; version="4.9.0"; uses:="org.eclipse.jgit.revwalk,  org.eclipse.jgit.treewalk.filter,  org.eclipse.jgit.diff,  org.eclipse.jgit.util,  org.eclipse.jgit.notes,  org.eclipse.jgit.dircache,  org.eclipse.jgit.api.errors,  org.eclipse.jgit.lib,  org.eclipse.jgit.treewalk,  org.eclipse.jgit.blame,  org.eclipse.jgit.submodule,  org.eclipse.jgit.transport,  org.eclipse.jgit.merge"
!ENTRY org.eclipse.egit.doc 4 0 2017-06-10 00:26:41.066
!STACK 0
org.osgi.framework.BundleException: Could not resolve module: org.eclipse.egit.doc [44]
  Unresolved requirement: Require-Bundle: org.eclipse.mylyn.wikitext.core; bundle-version="[2.9.0,3.0.0)"; resolution:="optional"
  Unresolved requirement: Require-Bundle: org.eclipse.mylyn.wikitext.core.ant; bundle-version="[2.9.0,3.0.0)"; resolution:="optional"
  Unresolved requirement: Require-Bundle: org.eclipse.mylyn.wikitext.mediawiki.core.ant; bundle-version="[2.9.0,3.0.0)"; resolution:="optional"
  Unresolved requirement: Require-Bundle: org.eclipse.mylyn.wikitext.mediawiki.core; bundle-version="[2.9.0,3.0.0)"; resolution:="optional"
  Unresolved requirement: Require-Bundle: org.eclipse.ui.cheatsheets; bundle-version="[3.3.0,4.0.0)"
    -> Bundle-SymbolicName: org.eclipse.ui.cheatsheets; bundle-version="3.5.0.v20160504-0839"; singleton:="true"
       org.eclipse.ui.cheatsheets [156]
         Unresolved requirement: Require-Bundle: org.eclipse.help.base; bundle-version="[4.0.0,5.0.0)"; resolution:="optional"
           -> Bundle-SymbolicName: org.eclipse.help.base; bundle-version="4.1.2.v20170301-0400"; singleton:="true"
              org.eclipse.help.base [101]
                Unresolved requirement: Require-Bundle: org.apache.lucene.core; bundle-version="[3.5.0,4.0.0)"
                Unresolved requirement: Import-Package: org.eclipse.equinox.http.jetty; resolution:="optional"
                  -> Export-Package: org.eclipse.equinox.http.jetty; bundle-symbolic-name="org.eclipse.equinox.http.jetty"; bundle-version="3.3.0.v20160324-1850"; version="1.3.0"
                     org.eclipse.equinox.http.jetty [64]
                       Unresolved requirement: Import-Package: org.eclipse.jetty.http; version="[9.0.0,10.0.0)"
                Unresolved requirement: Require-Bundle: org.apache.lucene.analysis; bundle-version="[3.5.0,4.0.0)"
                  -> Bundle-SymbolicName: org.apache.lucene.analysis; bundle-version="3.5.0.v20120725-1805"
                     org.apache.lucene.analysis [14]
         Unresolved requirement: Require-Bundle: org.eclipse.help.ui; bundle-version="[4.0.0,5.0.0)"; resolution:="optional"
           -> Bundle-SymbolicName: org.eclipse.help.ui; bundle-version="4.0.200.v20160510-0758"; singleton:="true"
              org.eclipse.help.ui [102]
                Unresolved requirement: Require-Bundle: org.eclipse.help.base; bundle-version="[4.0.0,5.0.0)"; visibility:="reexport"
         Unresolved requirement: Require-Bundle: org.eclipse.ui; bundle-version="[3.6.0,4.0.0)"
         Unresolved requirement: Require-Bundle: org.eclipse.ui.forms; bundle-version="[3.5.0,4.0.0)"
!ENTRY org.eclipse.egit.gitflow 4 0 2017-06-10 00:26:41.076
!STACK 0
org.osgi.framework.BundleException: Could not resolve module: org.eclipse.egit.gitflow [45]
  Unresolved requirement: Import-Package: org.eclipse.egit.core.internal.job; version="[4.9.0,4.10.0)"
    -> Export-Package: org.eclipse.egit.core.internal.job; bundle-symbolic-name="org.eclipse.egit.core"; bundle-version="4.9.0.qualifier"; version="4.9.0"; x-friends:="org.eclipse.egit.ui,org.eclipse.egit.gitflow.ui,org.eclipse.egit.gitflow"
  Unresolved requirement: Import-Package: org.eclipse.egit.core; version="[4.9.0,4.10.0)"
    -> Export-Package: org.eclipse.egit.core; bundle-symbolic-name="org.eclipse.egit.core"; bundle-version="4.9.0.qualifier"; version="4.9.0"; x-friends:="org.eclipse.egit.ui,  org.eclipse.egit.ui.test,  org.eclipse.egit.mylyn.ui,  org.eclipse.egit.gitflow.test,  org.eclipse.egit.gitflow.ui"
!ENTRY org.eclipse.egit.gitflow.ui 4 0 2017-06-10 00:26:41.078
!STACK 0
org.osgi.framework.BundleException: Could not resolve module: org.eclipse.egit.gitflow.ui [47]
  Unresolved requirement: Import-Package: org.eclipse.egit.core.internal; version="[4.9.0,4.10.0)"
    -> Export-Package: org.eclipse.egit.core.internal; bundle-symbolic-name="org.eclipse.egit.core"; bundle-version="4.9.0.qualifier"; version="4.9.0"; x-friends:="org.eclipse.egit.ui,org.eclipse.egit.import,org.eclipse.egit.gitflow.ui"
!ENTRY org.eclipse.egit.mylyn.ui 4 0 2017-06-10 00:26:41.080
!STACK 0
org.osgi.framework.BundleException: Could not resolve module: org.eclipse.egit.mylyn.ui [50]
  Unresolved requirement: Import-Package: org.eclipse.egit.core.synchronize; version="[4.9.0,4.10.0)"
    -> Export-Package: org.eclipse.egit.core.synchronize; bundle-symbolic-name="org.eclipse.egit.core"; bundle-version="4.9.0.qualifier"; version="4.9.0"; x-friends:="org.eclipse.egit.ui,org.eclipse.egit.ui.test"
!ENTRY org.eclipse.egit.ui 4 0 2017-06-10 00:26:41.081
!STACK 0
org.osgi.framework.BundleException: Could not resolve module: org.eclipse.egit.ui [53]
!ENTRY org.eclipse.equinox.http.jetty 4 0 2017-06-10 00:26:41.084
!STACK 0
org.osgi.framework.BundleException: Could not resolve module: org.eclipse.equinox.http.jetty [64]
!ENTRY org.eclipse.equinox.jsp.jasper 4 0 2017-06-10 00:26:41.084
!STACK 0
org.osgi.framework.BundleException: Could not resolve module: org.eclipse.equinox.jsp.jasper [67]
  Unresolved requirement: Import-Package: org.apache.jasper.servlet; version="[0.0.0,8.0.0)"
  Unresolved requirement: Import-Package: javax.servlet.jsp; version="[2.0.0,2.3.0)"
    -> Export-Package: javax.servlet.jsp; bundle-symbolic-name="javax.servlet.jsp"; bundle-version="2.2.0.v201112011158"; version="2.2.0"
       javax.servlet.jsp [6]
         Unresolved requirement: Import-Package: javax.el; version="2.2.0"
!ENTRY org.eclipse.equinox.jsp.jasper.registry 4 0 2017-06-10 00:26:41.086
!STACK 0
org.osgi.framework.BundleException: Could not resolve module: org.eclipse.equinox.jsp.jasper.registry [68]
  Unresolved requirement: Import-Package: org.eclipse.equinox.jsp.jasper
    -> Export-Package: org.eclipse.equinox.jsp.jasper; bundle-symbolic-name="org.eclipse.equinox.jsp.jasper"; bundle-version="1.0.500.v20150119-1358"; version="1.0.0"
!ENTRY org.eclipse.equinox.p2.artifact.repository 4 0 2017-06-10 00:26:41.092
!STACK 0
org.osgi.framework.BundleException: Could not resolve module: org.eclipse.equinox.p2.artifact.repository [70]
  Unresolved requirement: Require-Bundle: org.tukaani.xz; bundle-version="1.3.0"
!ENTRY org.eclipse.equinox.p2.console 4 0 2017-06-10 00:26:41.094
!STACK 0
org.osgi.framework.BundleException: Could not resolve module: org.eclipse.equinox.p2.console [71]
  Unresolved requirement: Import-Package: org.eclipse.equinox.p2.engine; version="[2.0.0,3.0.0)"
    -> Export-Package: org.eclipse.equinox.p2.engine; bundle-symbolic-name="org.eclipse.equinox.p2.engine"; bundle-version="2.4.100.v20160419-0834"; version="2.2.0"
       org.eclipse.equinox.p2.engine [76]
         Unresolved requirement: Import-Package: org.eclipse.equinox.internal.p2.metadata.repository.io
           -> Export-Package: org.eclipse.equinox.internal.p2.metadata.repository.io; bundle-symbolic-name="org.eclipse.equinox.p2.metadata.repository"; bundle-version="1.2.300.v20160419-0834"; version="0.0.0"; x-friends:="org.eclipse.equinox.p2.engine"
              org.eclipse.equinox.p2.metadata.repository [81]
  Unresolved requirement: Import-Package: org.eclipse.equinox.p2.planner; version="[2.0.0,3.0.0)"
    -> Export-Package: org.eclipse.equinox.p2.planner; bundle-symbolic-name="org.eclipse.equinox.p2.director"; bundle-version="2.3.300.v20160504-1450"; version="2.0.0"
       org.eclipse.equinox.p2.director [73]
         Unresolved requirement: Import-Package: org.eclipse.equinox.p2.engine.query; version="[2.0.0,3.0.0)"
           -> Export-Package: org.eclipse.equinox.p2.engine.query; bundle-symbolic-name="org.eclipse.equinox.p2.engine"; bundle-version="2.4.100.v20160419-0834"; version="2.0.0"
  Unresolved requirement: Import-Package: org.eclipse.equinox.internal.provisional.p2.director
    -> Export-Package: org.eclipse.equinox.internal.provisional.p2.director; bundle-symbolic-name="org.eclipse.equinox.p2.director"; bundle-version="2.3.300.v20160504-1450"; version="0.0.0"; x-friends:="org.eclipse.equinox.p2.console,  org.eclipse.equinox.p2.director.app,  org.eclipse.equinox.p2.operations,  org.eclipse.equinox.p2.ui.admin,  org.eclipse.equinox.p2.installer"
!ENTRY org.eclipse.equinox.p2.director 4 0 2017-06-10 00:26:41.095
!STACK 0
org.osgi.framework.BundleException: Could not resolve module: org.eclipse.equinox.p2.director [73]
!ENTRY org.eclipse.equinox.p2.director.app 4 0 2017-06-10 00:26:41.095
!STACK 0
org.osgi.framework.BundleException: Could not resolve module: org.eclipse.equinox.p2.director.app [74]
  Unresolved requirement: Import-Package: org.eclipse.equinox.internal.p2.director
    -> Export-Package: org.eclipse.equinox.internal.p2.director; bundle-symbolic-name="org.eclipse.equinox.p2.director"; bundle-version="2.3.300.v20160504-1450"; version="0.0.0"; x-friends:="org.eclipse.equinox.p2.operations,  org.eclipse.equinox.p2.repository.tools,  org.eclipse.pde.core,  org.eclipse.equinox.p2.reconciler.dropins,  org.eclipse.equinox.p2.ui,  org.eclipse.equinox.p2.director.app"
  Unresolved requirement: Import-Package: org.eclipse.equinox.internal.p2.engine
    -> Export-Package: org.eclipse.equinox.internal.p2.engine; bundle-symbolic-name="org.eclipse.equinox.p2.engine"; bundle-version="2.4.100.v20160419-0834"; version="0.0.0"; x-friends:="org.eclipse.equinox.p2.garbagecollector,  org.eclipse.equinox.p2.repository.tools,  org.eclipse.equinox.p2.touchpoint.eclipse,  org.eclipse.equinox.p2.touchpoint.natives,  org.eclipse.equinox.p2.ui.sdk.scheduler,  org.eclipse.pde.build,  org.eclipse.equinox.p2.director.app"
!ENTRY org.eclipse.equinox.p2.directorywatcher 4 0 2017-06-10 00:26:41.098
!STACK 0
org.osgi.framework.BundleException: Could not resolve module: org.eclipse.equinox.p2.directorywatcher [75]
  Unresolved requirement: Import-Package: org.eclipse.equinox.internal.p2.update
    -> Export-Package: org.eclipse.equinox.internal.p2.update; bundle-symbolic-name="org.eclipse.equinox.p2.touchpoint.eclipse"; bundle-version="2.1.400.v20160419-0834"; version="2.0.0"; x-friends:="org.eclipse.equinox.p2.reconciler.dropins,org.eclipse.equinox.p2.extensionlocation,org.eclipse.equinox.p2.directorywatcher"
       org.eclipse.equinox.p2.touchpoint.eclipse [87]
         Unresolved requirement: Import-Package: org.eclipse.equinox.p2.publisher.eclipse; resolution:="optional"
         Unresolved requirement: Import-Package: org.eclipse.equinox.p2.engine.spi; version="[2.0.0,3.0.0)"
           -> Export-Package: org.eclipse.equinox.p2.engine.spi; bundle-symbolic-name="org.eclipse.equinox.p2.engine"; bundle-version="2.4.100.v20160419-0834"; version="2.0.0"
         Unresolved requirement: Import-Package: org.eclipse.equinox.p2.publisher; resolution:="optional"
           -> Export-Package: org.eclipse.equinox.p2.publisher; bundle-symbolic-name="org.eclipse.equinox.p2.publisher"; bundle-version="1.4.100.v20160504-1450"; version="0.0.0"; x-friends:="org.eclipse.equinox.p2.directorywatcher,  org.eclipse.equinox.p2.touchpoint.eclipse,  org.eclipse.equinox.p2.updatesite,  org.eclipse.pde.publishing,  org.eclipse.equinox.p2.publisher.eclipse"
              org.eclipse.equinox.p2.publisher [83]
                Unresolved requirement: Import-Package: org.eclipse.equinox.internal.p2.artifact.repository
                  -> Export-Package: org.eclipse.equinox.internal.p2.artifact.repository; bundle-symbolic-name="org.eclipse.equinox.p2.artifact.repository"; bundle-version="1.1.500.v20160419-0834"; version="0.0.0"; x-friends:="org.eclipse.equinox.p2.publisher,  org.eclipse.equinox.p2.reconciler.dropins,  org.eclipse.equinox.p2.ui,  org.eclipse.equinox.p2.directorywatcher,  org.eclipse.equinox.p2.repository.tools,  org.eclipse.equinox.p2.publisher.eclipse"
         Unresolved requirement: Import-Package: org.eclipse.equinox.p2.planner; version="[2.0.0,3.0.0)"; resolution:="optional"
         Unresolved requirement: Import-Package: org.eclipse.equinox.internal.p2.garbagecollector
           -> Export-Package: org.eclipse.equinox.internal.p2.garbagecollector; bundle-symbolic-name="org.eclipse.equinox.p2.garbagecollector"; bundle-version="1.0.300.v20160504-1450"; version="0.0.0"; x-friends:="org.eclipse.equinox.p2.touchpoint.eclipse,org.eclipse.pde.core,org.eclipse.equinox.p2.ui.sdk.scheduler"
              org.eclipse.equinox.p2.garbagecollector [78]
                Unresolved requirement: Require-Bundle: org.eclipse.equinox.p2.engine
                  -> Bundle-SymbolicName: org.eclipse.equinox.p2.engine; bundle-version="2.4.100.v20160419-0834"; singleton:="true"
  Unresolved requirement: Import-Package: org.eclipse.equinox.internal.p2.artifact.repository.simple
    -> Export-Package: org.eclipse.equinox.internal.p2.artifact.repository.simple; bundle-symbolic-name="org.eclipse.equinox.p2.artifact.repository"; bundle-version="1.1.500.v20160419-0834"; version="0.0.0"; x-friends:="org.eclipse.equinox.p2.touchpoint.eclipse,  org.eclipse.equinox.p2.tests,  org.eclipse.equinox.p2.directorywatcher,  org.eclipse.equinox.p2.updatesite,  org.eclipse.equinox.p2.publisher,  org.eclipse.equinox.p2.extensionlocation,  org.eclipse.equinox.p2.repository.tools"
!ENTRY org.eclipse.equinox.p2.engine 4 0 2017-06-10 00:26:41.104
!STACK 0
org.osgi.framework.BundleException: Could not resolve module: org.eclipse.equinox.p2.engine [76]
!ENTRY org.eclipse.equinox.p2.extensionlocation 4 0 2017-06-10 00:26:41.104
!STACK 0
org.osgi.framework.BundleException: Could not resolve module: org.eclipse.equinox.p2.extensionlocation [77]
  Unresolved requirement: Import-Package: org.eclipse.equinox.internal.p2.publisher.eclipse
    -> Export-Package: org.eclipse.equinox.internal.p2.metadata.repository; bundle-symbolic-name="org.eclipse.equinox.p2.metadata.repository"; bundle-version="1.2.300.v20160419-0834"; version="0.0.0"; x-friends:="org.eclipse.equinox.p2.engine,  org.eclipse.equinox.p2.publisher,  org.eclipse.equinox.p2.reconciler.dropins,  org.eclipse.equinox.p2.ui,  org.eclipse.equinox.p2.updatesite,  org.eclipse.equinox.p2.extensionlocation,  org.eclipse.equinox.p2.repository.tools,  org.eclipse.equinox.p2.publisher.eclipse"
!ENTRY org.eclipse.equinox.p2.garbagecollector 4 0 2017-06-10 00:26:41.118
!STACK 0
org.osgi.framework.BundleException: Could not resolve module: org.eclipse.equinox.p2.garbagecollector [78]
!ENTRY org.eclipse.equinox.p2.metadata.repository 4 0 2017-06-10 00:26:41.121
!STACK 0
org.osgi.framework.BundleException: Could not resolve module: org.eclipse.equinox.p2.metadata.repository [81]
!ENTRY org.eclipse.equinox.p2.operations 4 0 2017-06-10 00:26:41.122
!STACK 0
org.osgi.framework.BundleException: Could not resolve module: org.eclipse.equinox.p2.operations [82]
	at org.eclipse.osg
Re: Followed "Automated Developer Setup" instructions and got "Invalid @since 4.8 tag [message #1765476 is a reply to message #1765451] Sat, 10 June 2017 09:30 Go to previous messageGo to next message
What's set as your target platform?
Re: Followed "Automated Developer Setup" instructions and got "Invalid @since 4.8 tag [message #1765593 is a reply to message #1765476] Mon, 12 June 2017 11:45 Go to previous messageGo to next message
[Window]-[Preferences]-[Plug-in Development]-[Target Platform] is set to "Modular Target" (I have not changed this setting).
https://gist.githubusercontent.com/satob/a4bd13bfcbc47617f04b86f8eca863b0/raw/0eed7662e556210be6b8899f6c44908ec56d1238/TargetPlatform.png
Re: Followed "Automated Developer Setup" instructions and got "Invalid @since 4.8 tag [message #1765623 is a reply to message #1765593] Mon, 12 June 2017 16:21 Go to previous messageGo to next message
That "Modular Target" also comes from oomph. Probably it's also not quite right. Try the egit-4.6 (Neon) or the egit-4.7 (Oxygen) target instead.
Re: Followed "Automated Developer Setup" instructions and got "Invalid @since 4.8 tag [message #1765638 is a reply to message #1765623] Mon, 12 June 2017 19:52 Go to previous messageGo to next message
More ideally, it would be used by the developers themselves and maintain to be correct. It's not that big a challenge. For Oomph we generate the *.target with annotations on the targlet, so we only need to maintain one thing and it remains correct.
Re: Followed "Automated Developer Setup" instructions and got "Invalid @since 4.8 tag [message #1765705 is a reply to message #1765638] Tue, 13 June 2017 11:25 Go to previous messageGo to next message
Ed Merks wrote on Mon, 12 June 2017 23:52
Heh :-) See https://git.eclipse.org/r/#/c/99218/ . We use TPD to maintain our target platforms. But it seems to be easy enough to get Oomph to use the target platforms that we do maintain. ;-)
Re: Followed "Automated Developer Setup" instructions and got "Invalid @since 4.8 tag [message #1765707 is a reply to message #1765705] Tue, 13 June 2017 11:44 Go to previous messageGo to next message
Sure, but that's not actually an improvement in behavior. I won't be able to pull EGit's setup into another workspace because *.target files can't be merged, unlike targlets. They don't ensure that workspace requirements are actually resolved, they don't use a shared bundle pool, so you'll have to download all the bundles into each workspace. But to each their own. At least something that works is better than something that doesn't.
Re: Followed "Automated Developer Setup" instructions and got "Invalid @since 4.8 tag [message #1766937 is a reply to message #1765707] Wed, 28 June 2017 17:10 Go to previous messageGo to next message
I see the advantage of targlets, but I want to use the same definition for developing in Eclipse and
running the central Maven build
Re: Followed "Automated Developer Setup" instructions and got "Invalid @since 4.8 tag [message #1766954 is a reply to message #1766937] Thu, 29 June 2017 02:04 Go to previous message
Yes, that's the case for our Oomph build is well, which is why for Oomph's development setup we generate a *.target file when resolving the targlet definition. And we often run our Maven build based on that *.target locally so that we can test the installation of what we've built before committing the changes.
Previous Topic:Problem with update site
Next Topic:Unable to retrieve label for Repository
Current Time: Sun Jul 20 08:39:25 EDT 2025
Powered by FUDForum. Page generated in 0.07758 seconds
