Home » Eclipse Projects » Lyo » Dynamic @OslcDialog property editing?(Dynamic @OslcDialog property editing?)
Dynamic @OslcDialog property editing? [message #1765028] Mon, 05 June 2017 15:52 Go to next message
The Bugzilla example defines its Delegated UI using the @OslcDialog annotation defined within the services. Is there a way to access those dialogs at run time in order to change a property? For example, the title is hard coded. What If I wanted the title to be based on a Locale? There are other properties I'd like to touch as well.
Re: Dynamic @OslcDialog property editing? [message #1765130 is a reply to message #1765028] Tue, 06 June 2017 17:26 Go to previous messageGo to next message
It should to be very possible.
Have a look at the class BugzillaServiceProviderFactory (in package org.eclipse.lyo.oslc4j.bugzilla.servlet), in particular the method createServiceProvider() .
That's where the ServiceProvider is being instantiated based on the annotations.
Once you have this serviceProvider, you can then call serviceProvider.setTitle() to do what you need.
When is that method called? See the ServiceProviderCatalogSingleton class in the same package.
Re: Dynamic @OslcDialog property editing? [message #1765456 is a reply to message #1765130] Fri, 09 June 2017 13:15 Go to previous message
Great! Thank you!
Previous Topic:Simple OSLC spec?
Next Topic:OSLC resource type generator?
Current Time: Sun Jul 20 08:29:41 EDT 2025
Powered by FUDForum. Page generated in 0.02903 seconds
