Home » Language IDEs » Java Development Tools (JDT) » Error
Error [message #1765067] Tue, 06 June 2017 07:17 Go to next message
Hi.
I have this error when I start the setup from eclipse and I dont now how to fix it the error will be in the attach file.
If you now any way of fixing it let me now
I also tried to download it from the Canda site but it didnt work.
  • Attachment: setup.log
    (Size: 9.93KB, Downloaded 133 times)
Re: Error [message #1765112 is a reply to message #1765067] Tue, 06 June 2017 14:35 Go to previous messageGo to next message
Appearently the download of javax.xml_1.3.4.v201005080400.jar failed or that file was deleted.
I have no idea, why so.
You may have a better chance to get a useful answer when asking in the forum of the installer, which is called "Oomph".
Re: Error [message #1765135 is a reply to message #1765112] Tue, 06 June 2017 18:18 Go to previous messageGo to next message
How do I do that ??
Re: Error [message #1765143 is a reply to message #1765135] Tue, 06 June 2017 23:29 Go to previous messageGo to next message
Does the file C:\Users\ItzBen\.p2\pool\plugins\javax.xml_1.3.4.v201005080400.jar actually exist on your file system? I suppose not. But it is expected to exist there, from doing a previous installation. So it seems to pool is damaged. That probably means you existing installations are broken as well. Is that the case?
In the worst case, you could delete the C:\Users\ItzBen\.p2 folder (but that will definitely destroy any existing installations you have) and start over. Or you can try to repair the pool using the installer. Via the menu in the upper right, you can use "Bundle Pools...", select the pool folder, and use Analyze Agent... This will analyze the pool and look for damaged artifacts; you can use "Repair Damaged Artifacts" to download the artifact again.
Re: Error [message #1765151 is a reply to message #1765143] Wed, 07 June 2017 01:42 Go to previous messageGo to next message
So I have deletet the p2 file and also the eclipse folder but there is this errror now.
Ps:I can also not update the installer !
Please help quick
ERROR: org.eclipse.equinox.p2.transport.ecf code=1002 HTTP Server 'Bad Gateway' : http://download.eclipse.org/technology/epp/packages/neon/content.xml.xz
ERROR: org.eclipse.ecf.identity code=0 HttpComponents connection error response code 502.
at org.eclipse.ecf.provider.filetransfer.httpclient4.HttpClientRetrieveFileTransfer.openStreams(HttpClientRetrieveFileTransfer.java:667)
at org.eclipse.ecf.provider.filetransfer.retrieve.AbstractRetrieveFileTransfer.sendRetrieveRequest(AbstractRetrieveFileTransfer.java:885)
at org.eclipse.ecf.provider.filetransfer.retrieve.AbstractRetrieveFileTransfer.sendRetrieveRequest(AbstractRetrieveFileTransfer.java:576)
at org.eclipse.ecf.provider.filetransfer.retrieve.MultiProtocolRetrieveAdapter.sendRetrieveRequest(MultiProtocolRetrieveAdapter.java:106)
at org.eclipse.equinox.internal.p2.transport.ecf.FileReader.sendRetrieveRequest(FileReader.java:428)
at org.eclipse.equinox.internal.p2.transport.ecf.FileReader.readInto(FileReader.java:360)
at org.eclipse.equinox.internal.p2.transport.ecf.RepositoryTransport.download(RepositoryTransport.java:101)
at org.eclipse.oomph.p2.internal.core.CachingTransport.download(CachingTransport.java:192)
at org.eclipse.oomph.p2.internal.core.CachingTransport.download(CachingTransport.java:255)
at org.eclipse.equinox.internal.p2.repository.CacheManager.updateCache(CacheManager.java:402)
at org.eclipse.equinox.internal.p2.repository.CacheManager.createCacheFromFile(CacheManager.java:132)
at org.eclipse.equinox.internal.p2.metadata.repository.XZedSimpleMetadataRepositoryFactory.getLocalFile(XZedSimpleMetadataRepositoryFactory.java:56)
at org.eclipse.equinox.internal.p2.metadata.repository.XZedSimpleMetadataRepositoryFactory.load(XZedSimpleMetadataRepositoryFactory.java:78)
at org.eclipse.equinox.internal.p2.metadata.repository.MetadataRepositoryManager.factoryLoad(MetadataRepositoryManager.java:57)
at org.eclipse.equinox.internal.p2.repository.helpers.AbstractRepositoryManager.loadRepository(AbstractRepositoryManager.java:768)
at sun.reflect.GeneratedMethodAccessor9.invoke(Unknown Source)
at org.eclipse.oomph.util.ReflectUtil.invokeMethod(ReflectUtil.java:117)
at org.eclipse.oomph.p2.internal.core.CachingRepositoryManager.loadRepository(CachingRepositoryManager.java:396)
at org.eclipse.oomph.p2.internal.core.CachingRepositoryManager.loadRepository(CachingRepositoryManager.java:199)
at org.eclipse.oomph.p2.internal.core.CachingRepositoryManager$Metadata.loadRepository(CachingRepositoryManager.java:463)
at org.eclipse.equinox.internal.p2.metadata.repository.MetadataRepositoryManager.loadRepository(MetadataRepositoryManager.java:96)
at org.eclipse.equinox.internal.p2.metadata.repository.MetadataRepositoryManager.loadRepository(MetadataRepositoryManager.java:92)
at org.eclipse.oomph.p2.internal.core.ProfileTransactionImpl$RepositoryLoader$Worker.perform(ProfileTransactionImpl.java:1613)
at org.eclipse.oomph.util.WorkerPool$Worker.run(WorkerPool.java:428)
Re: Error [message #1765153 is a reply to message #1765151] Wed, 07 June 2017 01:49 Go to previous messageGo to next message
No Message Body
Re: Error [message #1765154 is a reply to message #1765153] Wed, 07 June 2017 02:11 Go to previous messageGo to next message
That looks like a server problem. I've reopen https://bugs.eclipse.org/bugs/show_bug.cgi?id=515596#c15 with your problem report for the web master to consider. Does this happen repeatedly/reproducibly?
Re: Error [message #1765155 is a reply to message #1765154] Wed, 07 June 2017 02:54 Go to previous messageGo to next message
What do you meen by repeated I just uninstalled eclipse and than it show the error and thats the first time
Re: Error [message #1765161 is a reply to message #1765155] Wed, 07 June 2017 03:34 Go to previous messageGo to next message
Network failures tend to be transient things that come and go at random. So I mean if you try to run the installer again does it fail the same way again?
Re: Error [message #1765289 is a reply to message #1765161] Thu, 08 June 2017 03:53 Go to previous messageGo to next message
Fixed working now !!!!!
Re: Error [message #1765296 is a reply to message #1765289] Thu, 08 June 2017 04:31 Go to previous message
Thanks for letting us know!
Previous Topic:data flow analysis using the JDT infrastructure
Next Topic:Possible to auto-refresh resources in class packages on build & run?
Current Time: Sun Jul 20 14:12:05 EDT 2025
Powered by FUDForum. Page generated in 0.04511 seconds
