Home » Newcomers » Newcomers » game doesn't fully load(my game loads a bit and every time its something else)
game doesn't fully load [message #1764951] Sun, 04 June 2017 15:44 Go to next message
so when i run this the screen doesn't load fully. some labels are gone and some appear after a while. I just started with this so my code is a bit weird and i'm from Belgium so if you see a variable that's written in dutch and you can't read it i can translate it.
package fullGame;
import javax.swing.JFrame;
import javax.swing.JButton;
import java.awt.event.ActionListener;
import java.awt.event.ActionEvent;
import java.awt.Color;
import javax.swing.JLabel;
public class AllGame {
	// player gegevens
	int playerLvl = 1;
	int playerMoney = 1000;
	String playerWeapon = "fists";
	int playerHp = 100;
	String playerName;
	int maxPlayerHp;
	int weaponDemage;
	// game gegevens
	String storyLine;
	int aPressed;
	int keuze;
	//enemy gegevens
	int maxEnemyHp;
	int enemyHp;
	//frame gegevens
	JButton RightButton, LeftButton, UpButton, DownButton;
	private JFrame frame = new JFrame();
		AllGame window = new AllGame();
		window.frame.setVisible(true);
		window.Frame();
	public void Frame(){
		frame.setBounds(100, 100, 454, 330);
		frame.setDefaultCloseOperation(JFrame.EXIT_ON_CLOSE);
		frame.getContentPane().setBackground(Color.green);
		frame.getContentPane().setLayout(null);
		DownButton = new JButton("down");
		DownButton.setBounds(324, 245, 77, 25);
		frame.getContentPane().add(DownButton);
		DownButton.setVisible(false);
		UpButton = new JButton("up");
		UpButton.setBounds(324, 191, 77, 25);
		frame.getContentPane().add(UpButton);
		UpButton.setVisible(false);
		RightButton = new JButton("right");
		RightButton.setBounds(370, 219, 66, 25);
		frame.getContentPane().add(RightButton);
		RightButton.setVisible(false);
		LeftButton = new JButton("left");
		LeftButton.setBounds(281, 219, 77, 25);
		frame.getContentPane().add(LeftButton);
		LeftButton.setVisible(false);
		JLabel lblplayerHp = new JLabel(Integer.toString(playerHp));
		lblplayerHp.setBounds(33, 13, 56, 32);
		frame.getContentPane().add(lblplayerHp);
		JLabel lblMoney = new JLabel(Integer.toString(playerMoney));
		lblMoney.setBounds(124, 17, 50, 24);
		frame.getContentPane().add(lblMoney);
		JLabel lblLvl = new JLabel(Integer.toString(playerLvl));
		lblLvl.setBounds(227, 21, 56, 16);
		frame.getContentPane().add(lblLvl);
		JLabel lblWeapon = new JLabel(playerWeapon);
		lblWeapon.setEnabled(true);
		lblWeapon.setBounds(329, 21, 56, 16);
		frame.getContentPane().add(lblWeapon);
		JLabel lblHp = new JLabel("HP:");
		lblHp.setBounds(12, 21, 56, 16);
		frame.getContentPane().add(lblHp);
		JLabel lblMoney_1 = new JLabel("Money:");
		lblMoney_1.setBounds(77, 21, 56, 16);
		frame.getContentPane().add(lblMoney_1);
		JLabel lblLvl_1 = new JLabel("Lvl");
		lblLvl_1.setBounds(206, 21, 56, 16);
		frame.getContentPane().add(lblLvl_1);
		JLabel lblWeapon_1 = new JLabel("Weapon:");
		lblWeapon_1.setBounds(274, 21, 56, 16);
		frame.getContentPane().add(lblWeapon_1);
		JLabel lblStory = new JLabel(storyLine);
		lblStory.setBounds(12, 72, 412, 72);
		frame.getContentPane().add(lblStory);
		JButton AButton = new JButton("A");
		AButton.addActionListener(new ActionListener() {
			public void actionPerformed(ActionEvent e) {
				aPressed = aPressed + 1;
				if(aPressed == 1){
					lblStory.setText("okey this is a simple game where you have a few options to win");
				else if(aPressed == 2){
					lblStory.setText("you have the choice every time to go where you want");
				else if(aPressed == 3){
					lblStory.setText("okey lets start.");
				else if(aPressed == 4){
					lblStory.setText("you can now start to go where you want to go");
					DownButton.setVisible(true);
					UpButton.setVisible(true);
					LeftButton.setVisible(true);
					RightButton.setVisible(true);
		AButton.setBounds(73, 245, 60, 25);
		frame.getContentPane().add(AButton);
		JButton BButton = new JButton("B");
		BButton.setBounds(12, 245, 50, 25);
		frame.getContentPane().add(BButton);
  • Attachment: scherm.png
    (Size: 3.56KB, Downloaded 107 times)
Re: game doesn't fully load [message #1765129 is a reply to message #1764951] Tue, 06 June 2017 17:08 Go to previous message
This forum, in general, is not meant for programming questions--what you're encountering isn't a problem with finding your way around Eclipse. You might find http://javaranch.com/ and https://stackoverflow.com/ to be more responsive audiences.
[Updated on: Tue, 06 June 2017 17:09] by Moderator
Previous Topic:Eclipse files not running
Next Topic:Marketplace missing after update
Current Time: Sun Jul 20 18:47:39 EDT 2025
Powered by FUDForum. Page generated in 0.09693 seconds
