Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc)  » How to add a map with generics?
How to add a map with generics? [message #1764654] Thu, 01 June 2017 04:14 Go to next message
I use Ecoretools and want to add a java.util.Map to my model with the key type java.lang.String and the value type my.ClazzType where my.ClazzType is also part of the same model.
I want to use the map as attribute in one of my classes of this same model.
What steps do I have to follow to add this in the class diagram?
With regards,
Udo
Re: How to add a map with generics? [message #1764660 is a reply to message #1764654] Thu, 01 June 2017 04:46 Go to previous messageGo to next message
Maps are not one of EMF's strongest facilities. I failed to use them for many years but eventually felt guilty and tried again. You can find an example and some of my troubles in
https://bugs.eclipse.org/bugs/show_bug.cgi?id=443021
https://bugs.eclipse.org/bugs/show_bug.cgi?id=443195
To be honest, my recommendation is that if you want non-trivial efficient Maps you consider implementing them by manual coding behind a modeled API in the generated Java classes.
Ed Willink
Re: How to add a map with generics? [message #1764669 is a reply to message #1764660] Thu, 01 June 2017 05:33 Go to previous message
See https://wiki.eclipse.org/EMF/FAQ#How_do_I_create_a_Map_in_EMF.3F for details. You can accomplish the same tasks as described in the FAQ using the Ecore Tools editor. It obviously works because Ecore itself uses it and we have many cases of using it in Oomph's setup models.
Previous Topic:Question Generating from XSD
Next Topic:EMFStore on Tomcat: How to set it up using MongoDB?
Current Time: Sun Jul 20 16:35:59 EDT 2025
Powered by FUDForum. Page generated in 0.05900 seconds
