Home » Modeling » TMF (Xtext) » Compare and merge/mark on Regeneration Xtext-Xtend(Compare and merge/mark on Regeneration Xtext-Xtend)
icon5.gif  Compare and merge/mark on Regeneration Xtext-Xtend [message #1762853] Fri, 12 May 2017 01:44 Go to next message
Hi All,
I recently made Xtext-Xtend app to generate C++ classes.
Some code needs to be typed externally, as for instance the implementation of functions.
However, whenever I regenerate the files all the manually written code is deleted.
Is there a way to Compare and Merge/Mark files when regenerating?
Re: Compare and merge/mark on Regeneration Xtext-Xtend [message #1762860 is a reply to message #1762853] Fri, 12 May 2017 01:47 Go to previous message
you ususally use the generation gap pattern for that. Abstract Generated Superclass, Subclass With Manual Code is Generated once. Xtext supports this by having different OutoutConfigurations.
if you really want protected regions you might need to port https://github.com/danieldietrich/xtext-protected-regions to the current version of xtext
Previous Topic:Cross Reference without additional feature
Next Topic:[SOLVED] Enable Java generation with a partial compilation
Current Time: Sun Jul 20 14:48:31 EDT 2025
Powered by FUDForum. Page generated in 0.28697 seconds
