Home » Eclipse Projects » Dirigible » Plan Version 3(Major changes in version 3.x)
Plan Version 3 [message #1761084] Sat, 06 May 2017 09:09 Go to next message
Hi Team,
Let's collect the feedback of what is good and what have to be improved in the new major version of Eclipse Dirigible - 3.0. Totally new and crazy ideas and suggestions are welcome as well.
Nedelcho
Re: Plan Version 3 [message #1761089 is a reply to message #1761084] Sat, 06 May 2017 09:34 Go to previous messageGo to next message
What about a non-OSGi AppServer
https://www.eclipse.org/forums/index.php/m/1761088/#msg_1761088
Re: Plan Version 3 [message #1761094 is a reply to message #1761089] Sat, 06 May 2017 10:14 Go to previous messageGo to next message
What about removing Semantic Folders?
https://www.eclipse.org/forums/index.php/m/1761093/#msg_1761093
Re: Plan Version 3 [message #1761095 is a reply to message #1761094] Sat, 06 May 2017 10:15 Go to previous messageGo to next message
What about including Activiti as a built-in Process Engine?
https://www.eclipse.org/forums/index.php/m/1761092/#msg_1761092
Re: Plan Version 3 [message #1761098 is a reply to message #1761095] Sat, 06 May 2017 10:25 Go to previous messageGo to next message
What about V8 migration?
https://www.eclipse.org/forums/index.php/m/1761097/#msg_1761097
Re: Plan Version 3 [message #1761101 is a reply to message #1761098] Sat, 06 May 2017 11:04 Go to previous messageGo to next message
What about Cassandra as underlying Repository?
https://www.eclipse.org/forums/index.php/m/1761100/#msg_1761100
Re: Plan Version 3 [message #1761103 is a reply to message #1761101] Sat, 06 May 2017 11:08 Go to previous messageGo to next message
What about Kafka as underlying Messaging Hub?
https://www.eclipse.org/forums/index.php/m/1761102/#msg_1761102
Re: Plan Version 3 [message #1761105 is a reply to message #1761103] Sat, 06 May 2017 11:13 Go to previous messageGo to next message
What about PostgreSQL as a default RDBMS?
https://www.eclipse.org/forums/index.php/m/1761104/#msg_1761104
Re: Plan Version 3 [message #1761235 is a reply to message #1761105] Tue, 09 May 2017 05:27 Go to previous messageGo to next message
What desktop grade UX for the IDE
https://www.eclipse.org/forums/index.php/t/1086080/
Re: Plan Version 3 [message #1761241 is a reply to message #1761235] Tue, 09 May 2017 06:46 Go to previous messageGo to next message
What about native/natural support for IoT scenarios?
https://www.eclipse.org/forums/index.php/t/1070244/
Re: Plan Version 3 [message #1761244 is a reply to message #1761241] Tue, 09 May 2017 07:02 Go to previous messageGo to next message
What about real, natively supported production readiness:
https://www.eclipse.org/forums/index.php/m/1761243/#msg_1761243
Re: Plan Version 3 [message #1761249 is a reply to message #1761244] Tue, 09 May 2017 07:12 Go to previous messageGo to next message
What about better control on the published artifacts from the designtime
https://www.eclipse.org/forums/index.php/m/1761248/#msg_1761248
Re: Plan Version 3 [message #1761255 is a reply to message #1761249] Tue, 09 May 2017 08:00 Go to previous messageGo to next message
What about improved extensions tracing and management?
https://www.eclipse.org/forums/index.php/m/1761253/#msg_1761253
Re: Plan Version 3 [message #1761257 is a reply to message #1761249] Tue, 09 May 2017 08:03 Go to previous messageGo to next message
What about consider better concept of secured/unsecured URLs?
https://www.eclipse.org/forums/index.php/t/1082457/
Re: Plan Version 3 [message #1761262 is a reply to message #1761257] Tue, 09 May 2017 08:16 Go to previous messageGo to next message
What about improved Git support for SCM and release/dependency management?
https://www.eclipse.org/forums/index.php/m/1761259/#msg_1761259
Re: Plan Version 3 [message #1761263 is a reply to message #1761262] Tue, 09 May 2017 08:19 Go to previous messageGo to next message
What about native NoSql support and Gremlin enterprise js API?
https://www.eclipse.org/forums/index.php/t/1072572/
Re: Plan Version 3 [message #1761267 is a reply to message #1761263] Tue, 09 May 2017 08:26 Go to previous messageGo to next message
What about improved supportability via improved debugging and profiling tools?
https://www.eclipse.org/forums/index.php/m/1761266/#msg_1761266
[Updated on: Tue, 09 May 2017 09:10] by Moderator
Re: Plan Version 3 [message #1761269 is a reply to message #1761267] Tue, 09 May 2017 08:37 Go to previous messageGo to next message
What about support for more authentication types per app?
https://www.eclipse.org/forums/index.php/m/1761268/#msg_1761268
Re: Plan Version 3 [message #1761271 is a reply to message #1761269] Tue, 09 May 2017 08:48 Go to previous messageGo to next message
What about cloud operations as they preach them?
https://www.eclipse.org/forums/index.php/m/1761270/#msg_1761270
Re: Plan Version 3 [message #1761274 is a reply to message #1761271] Tue, 09 May 2017 08:54 Go to previous messageGo to next message
What about ES6 support in JS runtime for Scripting Services?
https://www.eclipse.org/forums/index.php/m/1761273/#msg_1761273
Re: Plan Version 3 [message #1761276 is a reply to message #1761274] Tue, 09 May 2017 09:01 Go to previous messageGo to next message
What about improved support for CommonJS in JS Scripting Services Runtime?
https://www.eclipse.org/forums/index.php/t/1086095/
Re: Plan Version 3 [message #1761278 is a reply to message #1761276] Tue, 09 May 2017 09:09 Go to previous messageGo to next message
Leaving aside licenses as orthogonal constraint that we can't technically influence, what about adoption of NodeJS application like a breeze?
https://www.eclipse.org/forums/index.php/t/1086096/
https://www.eclipse.org/forums/index.php/t/1086094/
Re: Plan Version 3 [message #1761281 is a reply to message #1761278] Tue, 09 May 2017 09:28 Go to previous messageGo to next message
What about Dirigible's support for "realtime" use cases?
https://www.eclipse.org/forums/index.php/t/1086097/
Re: Plan Version 3 [message #1761286 is a reply to message #1761281] Tue, 09 May 2017 09:36 Go to previous messageGo to next message
What about improved improved support (enterprise API) for cache?
https://www.eclipse.org/forums/index.php/t/1086099/
Re: Plan Version 3 [message #1761293 is a reply to message #1761286] Tue, 09 May 2017 09:46 Go to previous messageGo to next message
As automation is key, and tests are key to automated quality control, what about extending the support for test frameworks that would support testing JS Scripting Services to those popular in the NodeJS community now?
https://www.eclipse.org/forums/index.php/t/1086101/
Re: Plan Version 3 [message #1761297 is a reply to message #1761293] Tue, 09 May 2017 09:55 Go to previous messageGo to next message
What about a configurable release service?
https://www.eclipse.org/forums/index.php/t/1086102/
Re: Plan Version 3 [message #1761299 is a reply to message #1761297] Tue, 09 May 2017 09:59 Go to previous messageGo to next message
What about client-side JS testing service?
https://www.eclipse.org/forums/index.php/t/1086103/
Re: Plan Version 3 [message #1763317 is a reply to message #1761299] Fri, 12 May 2017 10:44 Go to previous messageGo to next message
What about new Repository structure?
https://www.eclipse.org/forums/index.php/m/1763315/
Re: Plan Version 3 [message #1763576 is a reply to message #1763317] Wed, 17 May 2017 10:41 Go to previous message
What about Vert.x for reactive apps platform
https://www.eclipse.org/forums/index.php/m/1763575/#msg_1763575
Previous Topic:Vert.x for reactive apps
Next Topic:Node.js vs J2V8
Current Time: Sun Jul 20 10:42:16 EDT 2025
Powered by FUDForum. Page generated in 0.11212 seconds
