Exception when accessing xtext index [message #1760763] |
Tue, 02 May 2017 12:38  |
My validator uses the reference index in order to omit parsing each recourse in the workspace:
@Inject
IContainer.Manager containerManager;
@Inject
ResourceDescriptionsProvider resourceDescriptionsProvider;
private def Iterable<IReferenceDescription> getReferenceDescriptionsOfType(EObject object, EReference eReference) {
return object.getReferenceDescriptions().filter[it.EReference == eReference]
private def Iterable<IReferenceDescription> getReferenceDescriptions(EObject object) {
return object.getResourceDescriptions().map[referenceDescriptions].flatten()
private def Iterable<IResourceDescription> getResourceDescriptions(EObject object) {
return object.visibleContainers.map[resourceDescriptions].flatten()
private def List<IContainer> getVisibleContainers(EObject object) {
val index = resourceDescriptionsProvider.getResourceDescriptions(object.eResource())
val resourceDescription = index.getResourceDescription(object.eResource().URI)
return containerManager.getVisibleContainers(resourceDescription, index)
It works fine when applied to individual model elements. But when I trigger the workspace rebuild, I get a lot of these weird exceptions, yield when accessing to referenceDescriptions:
1661339 [Worker-1] ERROR org.eclipse.xtext.builder.clustering.CopiedResourceDescription - java.lang.IllegalStateException: getReferenceDescriptions platform:/resource/test/onboardnet/ASP_R.fbdl
at org.eclipse.xtext.builder.clustering.CopiedResourceDescription.getReferenceDescriptions(CopiedResourceDescription.java:84)
at MyValidator.lambda$2(MyValidator.java:77)
at org.eclipse.xtext.xbase.lib.internal.FunctionDelegate.apply(FunctionDelegate.java:42)
at com.google.common.collect.Iterators$8.transform(Iterators.java:794)
at com.google.common.collect.TransformedIterator.next(TransformedIterator.java:48)
at com.google.common.collect.Iterators$5.hasNext(Iterators.java:543)
at com.google.common.collect.Iterators$7.computeNext(Iterators.java:645)
at com.google.common.collect.AbstractIterator.tryToComputeNext(AbstractIterator.java:143)
at com.google.common.collect.AbstractIterator.hasNext(AbstractIterator.java:138)
at com.google.common.collect.Iterators.size(Iterators.java:186)
at com.google.common.collect.Iterables.size(Iterables.java:108)
at org.eclipse.xtext.xbase.lib.IterableExtensions.size(IterableExtensions.java:471)
at MyValidator.lambda$0(MyValidator.java:56)
at java.lang.Iterable.forEach(Iterable.java:75)
at MyValidator.validateModel(MyValidator.java:62)
at MyValidator.checkNormalExtensionValidators(MyValidator.java:133)
at java.lang.reflect.Method.invoke(Method.java:497)
at org.eclipse.xtext.validation.AbstractDeclarativeValidator$MethodWrapper.invoke(AbstractDeclarativeValidator.java:118)
at org.eclipse.xtext.validation.AbstractDeclarativeValidator.internalValidate(AbstractDeclarativeValidator.java:312)
at org.eclipse.xtext.validation.AbstractInjectableValidator.validate(AbstractInjectableValidator.java:71)
at org.eclipse.xtext.validation.CompositeEValidator.validate(CompositeEValidator.java:151)
at org.eclipse.emf.ecore.util.Diagnostician.doValidate(Diagnostician.java:171)
at org.eclipse.emf.ecore.util.Diagnostician.validate(Diagnostician.java:158)
at org.eclipse.emf.ecore.util.Diagnostician.validate(Diagnostician.java:137)
at org.eclipse.xtext.validation.CancelableDiagnostician.validate(CancelableDiagnostician.java:39)
at org.eclipse.emf.ecore.util.Diagnostician.validate(Diagnostician.java:120)
at org.eclipse.xtext.validation.ResourceValidatorImpl.validate(ResourceValidatorImpl.java:146)
at org.eclipse.xtext.validation.ResourceValidatorImpl.validate(ResourceValidatorImpl.java:124)
at org.eclipse.xtext.validation.ResourceValidatorImpl.validate(ResourceValidatorImpl.java:90)
at org.eclipse.xtext.ui.validation.DefaultResourceUIValidatorExtension.addMarkers(DefaultResourceUIValidatorExtension.java:60)
at org.eclipse.xtext.ui.validation.DefaultResourceUIValidatorExtension.updateValidationMarkers(DefaultResourceUIValidatorExtension.java:46)
at org.eclipse.xtext.builder.builderState.MarkerUpdaterImpl.processDelta(MarkerUpdaterImpl.java:93)
at org.eclipse.xtext.builder.builderState.MarkerUpdaterImpl.updateMarkers(MarkerUpdaterImpl.java:63)
at org.eclipse.xtext.builder.builderState.AbstractBuilderState.updateMarkers(AbstractBuilderState.java:82)
at org.eclipse.xtext.builder.clustering.ClusteringBuilderState.doUpdate(ClusteringBuilderState.java:283)
at org.eclipse.xtext.builder.builderState.AbstractBuilderState.update(AbstractBuilderState.java:116)
at org.eclipse.xtext.builder.impl.XtextBuilder.doBuild(XtextBuilder.java:287)
at org.eclipse.xtext.builder.impl.XtextBuilder.fullBuild(XtextBuilder.java:319)
at org.eclipse.xtext.builder.impl.XtextBuilder.build(XtextBuilder.java:155)
at org.eclipse.core.internal.events.BuildManager$2.run(BuildManager.java:735)
at org.eclipse.core.internal.events.BuildManager.basicBuild(BuildManager.java:206)
at org.eclipse.core.internal.events.BuildManager.basicBuild(BuildManager.java:246)
at org.eclipse.core.internal.events.BuildManager$1.run(BuildManager.java:301)
at org.eclipse.core.internal.events.BuildManager.basicBuild(BuildManager.java:304)
at org.eclipse.core.internal.events.BuildManager.basicBuildLoop(BuildManager.java:360)
at org.eclipse.core.internal.events.BuildManager.build(BuildManager.java:383)
at org.eclipse.core.internal.events.AutoBuildJob.doBuild(AutoBuildJob.java:144)
at org.eclipse.core.internal.events.AutoBuildJob.run(AutoBuildJob.java:235)
Why does this happen and how could I fix it?
PS: The Xtext version is 2.10.
Re: Exception when accessing xtext index [message #1760858 is a reply to message #1760851] |
Wed, 03 May 2017 12:35   |
Thanks for reply, Christian!
My settings is: There are elements of type A which may reference to elements of type B. The instances of A'S and B's are wildy distributed over files in the workspace, but one file may not contain both, A and B, because they are defined in separate grammars.
Now the requirement is that at most one A may reference any B. So a naive approach would be to parse all files with A's for each B. I considered this being not really efficient.
My scope is based on imports of resources, but again, a file with A's imports files with B's, not other way around. So I do not know where B is referenced.
You propose to extend ieobjectdescriptions with the references A->B, is that right?
I did not quite got your other proposal to move the validation to the builder participant. Could you explain this in more detail? And will it be still usable as the "normal", FAST validation?
Thanks!
Re: Exception when accessing xtext index [message #1760859 is a reply to message #1760851] |
Thanks!
Re: Exception when accessing xtext index [message #1760860 is a reply to message #1760851] |
Wed, 03 May 2017 12:36   |
Thanks!
Re: Exception when accessing xtext index [message #1760863 is a reply to message #1760862] |
Wed, 03 May 2017 12:57  |
Another thing that comes tommy mind is that you sort the files in the Xtext builder in a way that all A files are built first and the b files second
But that needs patching / subclassing the ClusteringBuilderState
(Please note this is a Xtext global singleton)
FUDForum. Page generated in 0.04347 seconds
