Home » Newcomers » Newcomers » Import new file to eclipse
Import new file to eclipse [message #1760686] Mon, 01 May 2017 16:18 Go to next message
Hi, I set up Eclipse and Subversion to use version control on my Joomla homepage. I've imported the whole Joomla code into Eclipse. I can edit all the files in Joomla and commit them to the respitory and use version control. But when add a file in the Joomla folder (C:\xampp\htdocs\website) it doesn't appear in Eclipse/Subversion. I tried to update Eclipse but I was not succesful. I added the menu that appears in Eclipse when I click on team. Any ideas how to solve this?
I'm running Eclipse Neon.3 Release (4.6.3) and SVN Team provider 4.0.2 and Subclipse 1.10.13. I've tried both JavaHL and SVNkit as connector.
  • Attachment: update.png
    (Size: 20.16KB, Downloaded 135 times)
Re: Import new file to eclipse [message #1760693 is a reply to message #1760686] Mon, 01 May 2017 22:45 Go to previous messageGo to next message
Refresh the project from the File menu.
Re: Import new file to eclipse [message #1760772 is a reply to message #1760693] Tue, 02 May 2017 15:03 Go to previous message
Thanks for your reply, I've already tried that but the files doesn't appear. Could there be a missing extension causing this problem?
Previous Topic:Eclipse Tutorial: importing
Next Topic:Java Build Order by Dependency or Rebuild based on Dependency
Current Time: Sun Jul 20 05:29:10 EDT 2025
Powered by FUDForum. Page generated in 0.08872 seconds
