Home » Modeling » TMF (Xtext) » Parsing Problem: Colon and negative number
Parsing Problem: Colon and negative number [message #1760653] Sun, 30 April 2017 06:02 Go to next message
Hi together,
I am relatively new to xtext and try to integrate JSONPath syntax elements into an existing grammar.
At the moment, the only problem is that expressions like array[0:-1] (which will return all the elements except the last one) are not parsed correctly. It seems like the parser always uses :- as a token, although only the colon should be one token. The following rules are involved:
Attribute:
	{IndexAttribute} '[' indices+=AttributeIndex (',' indices+=AttributeIndex)* ']';
AttributeIndex:
	{WildcardIndex} '*' |
	{NumberIndex} index=JSONNUMBER (':' to=JSONNUMBER (':' step=JSONNUMBER)?)? |
	{ExpressionIndex} '(' expression=Expression ')' |
	{ConditionIndex} '?' '(' expression=Expression ')';
terminal JSONNUMBER returns ecore::EFloat: // Definition according to JSON standard
	'-'? ('0' | ('1'..'9') DIGIT*) ('.' DIGIT+)? (('E' | 'e') ('+' | '-')? DIGIT+)?;
terminal fragment DIGIT:
	('0'..'9');
Does anybody have an idea what I am doing wrong here? This would really help me.
Many thanks in advance
Philipp
Re: Parsing Problem: Colon and negative number [message #1760683 is a reply to message #1760653] Mon, 01 May 2017 13:47 Go to previous message
hi,
i cannot follow you. whats the problem?
can you please share a complete grammar that shows the problem and a unit test?
maybe you have other tokens involving -
Previous Topic:scoping.ImportURIScopingFragment in new generator?
Next Topic:Strange conflict on xtext grammar
Current Time: Sun Jul 20 03:47:28 EDT 2025
Powered by FUDForum. Page generated in 0.03620 seconds
