Home » Newcomers » Newcomers » JVM undetected
JVM undetected [message #175881] Mon, 23 October 2006 08:28 Go to next message
Originally posted by: saum.paul.gmail.com
I have downloaded eclpse 3.1 which requires jvm 1.4.* for running .. now
although i have jre1.4.2 eclipse refuses to start, sayin that java 1.3 is
reqd and it has detected jvm 1.3 ... i suppose that eclipse is not able to
select the jvm, but in that case i tried running eclipse with the -vm
argument and it still doesnt run, stating specifically that no jvm has
been found, how do i fix this ..
Re: JVM undetected [message #175908 is a reply to message #175881] Mon, 23 October 2006 10:36 Go to previous messageGo to next message
Originally posted by: eclipse4.rizzoweb.com
Saumyadeep wrote:
> is reqd and it has detected jvm 1.3 ... i suppose that eclipse is not
> able to select the jvm, but in that case i tried running eclipse with
> the -vm argument and it still doesnt run, stating specifically that no
> jvm has been found, how do i fix this ..
You are correct that you should always use the -vm argument to
explicitly tell Eclipse what JVM to use.
What is the exact command-line you are trying? Most likely there is some
small mistake in it that is keeping you from success.
Hope this helps,
Eric
Re: JVM undetected [message #175957 is a reply to message #175908] Tue, 24 October 2006 05:41 Go to previous messageGo to next message
C:\Program Files\Java\j2re1.4.2_04\bin\client\jvm.dll
Re: JVM undetected [message #175965 is a reply to message #175908] Tue, 24 October 2006 05:44 Go to previous messageGo to next message
The full command that i used to run is with the vm argument :
D:\> eclipse.exe -vm "C:\Program Files\Java\j2re1.4.2_04\bin\client\jvm.dll"
Re: JVM undetected [message #175973 is a reply to message #175965] Tue, 24 October 2006 06:01 Go to previous messageGo to next message
Try this
D:\> eclipse.exe -vm "C:\Program Files\Java\j2re1.4.2_04\bin"
This should work. The -vm path should point to the place where java.exe or
javaw.exe is placed.
Re: JVM undetected [message #175988 is a reply to message #175973] Tue, 24 October 2006 06:40 Go to previous messageGo to next message
MK Samuel wrote:
> Try this
> D:> eclipse.exe -vm "C:Program FilesJavaj2re1.4.2_04bin"
It gave an error ... " D:\eclipse\eclipse.exe not a win32 application "
Re: JVM undetected [message #175998 is a reply to message #175988] Tue, 24 October 2006 08:01 Go to previous messageGo to next message
Can you please mention some of ur folder details.
1. In which folder eclipse is installed?
2. In which folder java is installed?
3. What is the exact text which you have typed to open eclipse using the
-vm runtime option?
Re: JVM undetected [message #176023 is a reply to message #175965] Tue, 24 October 2006 12:42 Go to previous messageGo to next message
You don't specify the DLL, you specify the JVM executable. For example,
"C:\Program Files\Java\j2re1.4.2_04\bin\javaw.exe"
Note that it is recommended you use a JDK, not a JRE, for running Eclipse.
Hope this helps,
Eric
Re: JVM undetected [message #176030 is a reply to message #176023] Tue, 24 October 2006 13:17 Go to previous messageGo to next message
A JRE is ok to run, but I would recommend a JDK to compile against.
Olivier
Re: JVM undetected [message #176052 is a reply to message #175998] Wed, 25 October 2006 00:35 Go to previous messageGo to next message
eclipse is in 'D:\eclipse'
java is in 'C:\Program Files\Java\j2re1.4.2_04'
-vm runtime option?
i went to the folder where eclipse is installed, 'D:\eclipse'>
The exact string that i typed was:
"eclipse -vm "C:\Program Files\Java\j2re1.4.2_04\bin"
Re: JVM undetected [message #176125 is a reply to message #175973] Wed, 25 October 2006 07:26 Go to previous messageGo to next message
MK Samuel wrote:
> Try this
> or javaw.exe is placed.
the path should contain the executable as well (not only the directory),
i.e., -vm "C:\Program Files\Java\j2re1.4.2_04\bin\java.exe"
| Lorenzo Bettini ICQ# lbetto, 16080134 |
| Home Page : http://www.lorenzobettini.it |
| http://tronprog.blogspot.com BLOG |
| http://www.purplesucker.com Deep Purple Cover Band |
| http://www.gnu.org/software/src-highlite |
| http://www.gnu.org/software/gengetopt |
| http://www.lorenzobettini.it/software/gengen |
| http://www.lorenzobettini.it/software/doublecpp |
Re: JVM undetected [message #176575 is a reply to message #175988] Wed, 25 October 2006 12:23 Go to previous messageGo to next message
Originally posted by: nobody.there.127.0.0.1
Saumyadeep wrote:
>> java.exe or javaw.exe is placed.
Is there a chance you downloaded the Windows x86_64 or Windows ia64
install rather than the Windows install? It sounds as if you're not even
getting to the point where the JVM would matter.
Andrew Jr.
IBM Phoenix Labs (OTI)
2929 North Central Avenue
Phoenix, Arizona, USA 85012
Re: JVM undetected [message #176626 is a reply to message #176125] Thu, 26 October 2006 01:29 Go to previous messageGo to next message
> i.e., -vm "C:Program FilesJavaj2re1.4.2_04binjava.exe"
It did fix the problem but is there any way i can configure it to run with
the 1.4 vm by default, i mean is there a way where by i wont have to issue
a cmd line arg always..
Re: JVM undetected [message #177363 is a reply to message #176626] Mon, 30 October 2006 09:40 Go to previous message
>> directory), i.e., -vm "C:Program FilesJavaj2re1.4.2_04binjava.exe"
> with the 1.4 vm by default, i mean is there a way where by i wont have
> to issue a cmd line arg always..
Yes, you have two options:
A) create a Windows shortcut or "batch" file that contains the full
command-line, then you can double-click that shortcut to launch Eclipse.
B) In the same directory as eclipse.exe there should be a file
eclipse.ini - in that file you can specify startup parameters. Just be
careful as the format of the file is very particular and it will fail if
you get it wrong (line breaks are important). Below is a sample of my
eclipse.ini file which you can adapt for your own set-up.
Hope this helps,
Eric
--- Begin eclipse.ini ---
-vm
D:\Java\JDK\1.5.0\bin\javaw.exe
-vmargs
-Xms40m
-Xmx512m
-XX:MaxPermSize=128m
Previous Topic:How do I export a Run Configuration ???
Next Topic:Eclipse 3.2 Won't download
Current Time: Sat Jul 19 11:39:32 EDT 2025
Powered by FUDForum. Page generated in 0.35079 seconds
