Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc)  » [Edapt] Creating history from existing metamodel versions(Can you create migration operations for externally maintained metamodels?)
[Edapt] Creating history from existing metamodel versions [message #1760160] Mon, 24 April 2017 02:34 Go to next message
As a pre-beginner in Edapt I have a simple question. From reading the documentation I have the impression that metamodel modifications must be made in the Edapt IDE in order to be properly recorded in the history. In my case however, the metamodel is maintained and exported by a 3rd party tool.
Question: Is Edapt able to construct a history from two different metamodel versions? Or is there support to create the migration operations e.g. using EMF Compare?
As far as I understand, reconstruction is the other way round: It reconstructs an older metamodel by applying the history. What we need is the construction of a history by comparing two metamodel versions.
Thanks for any hint.
Wernke
[Updated on: Mon, 24 April 2017 05:08] by Moderator
Re: [Edapt] Creating history from existing metamodel versions [message #1760174 is a reply to message #1760160] Mon, 24 April 2017 05:31 Go to previous message
The question has been answered before:
https://www.eclipse.org/forums/index.php/t/1068604/0/unread/
https://www.eclipse.org/forums/index.php/t/1070914/0/unread/
In essence, there is no such support in Edapt, which makes a differencing approach more suitable than a change recording one for such use cases.
Previous Topic:TreeViewerSWTFactory drag and drop exceptions
Next Topic:[EMF Forms] - Custom Control Area
Current Time: Sun Jul 20 15:11:45 EDT 2025
Powered by FUDForum. Page generated in 0.03421 seconds
