Home » Modeling » GMF (Graphical Modeling Framework) » ActiveWorkbenchWindow is null called from thread
ActiveWorkbenchWindow is null called from thread [message #175976] Thu, 06 March 2008 06:20 Go to next message
Originally posted by: novak.igor.gmail.com
Hi!
I'm trying to refresh domain model (I get domain data from external corba
source) from a thread (every few minutes) and I get NullPointerException
PlatformUI.getWorkbench().getActiveWorkbenchWindow();
but if I run it from action (pressing button on gui) everything is ok.
I'm using AbstractTransactionalCommand to manipulate domain model and I
need TransactionalEditingDomain.
I do it like this:
TransactionalEditingDomain editingDomain =
PlatformUI.getWorkbench().getActiveWorkbenchWindow().getActi vePage().getActiveEditor().getDiagramEditPart().getEditingDo main();
AbstractTransactionalCommand command = new
AbstractTransactionalCommand(editingDomain, "Changing domain model", null);
then I execute command and if I do it from gui everything is ok, but if
the above code is called from thread it does not work.
Any suggestions, am I doing something wrong?
Thanks in advance,
Igor Novak
Re: ActiveWorkbenchWindow is null called from thread [message #175986 is a reply to message #175976] Thu, 06 March 2008 06:32 Go to previous message
Hi Igor,
I suggest you use Display.getDefault().syncExec() to run your code.
Dimitrios
Igor Novak wrote:
> Hi!
> corba source) from a thread (every few minutes) and I get
> NullPointerException from:
> I do it like this:
> Thanks in advance, Igor Novak
Previous Topic:problems with semantic changes
Next Topic:how to let a label appear outside of a graphics?
Current Time: Sat Jul 19 12:52:43 EDT 2025
Powered by FUDForum. Page generated in 0.03811 seconds
