Home » Archived » BIRT » create multiple sheets in Excel report(create multiple sheets in Excel report where only grids are used in .rpt design)
create multiple sheets in Excel report [message #1759304] Mon, 10 April 2017 08:30 Go to next message
How to create multiple sheets excel report?
I'm using only grids in .rptdesign, and the condition given is
if("xls_spudsoft".equalsIgnoreCase(excelRenderOption.getOutputFormat())) {
excelRenderOption.setOption(IRenderOption.EMITTER_ID, "uk.co.spudsoft.birt.emitters.excel.XlsEmitter");
Please explain in detail
Re: create multiple sheets in Excel report [message #1842011 is a reply to message #1759304] Mon, 07 June 2021 04:19 Go to previous message
New sheets are created from Page Breaks, but work best when used as a group on a table. It can work from general elements and page breaking, but you do not have control over the sheet names. You should also make sure that the elements have names (in the general section of properties).
Previous Topic:Problem Deploying Birt Viewer from latest Runtime
Next Topic:Difference between BIRT Designer & Runtime using Excel emitter
Current Time: Sun Jul 20 17:38:34 EDT 2025
Powered by FUDForum. Page generated in 0.03462 seconds
