Home » Archived » Eclipse SmartHome » Add Options to String Channel Dynamically
Add Options to String Channel Dynamically [message #1759109] Thu, 06 April 2017 10:13 Go to next message
I got a channel with a string type and some options.
I want to add options to the list as the config of the thing updates.
Do I have to create a new ChannelType each time? If so how do I do that?
Where do I need to register the new ChannelType and unregister the old one?
Re: Add Options to String Channel Dynamically [message #1759251 is a reply to message #1759109] Sat, 08 April 2017 08:06 Go to previous message
Yes, you would ideally require different channel types (assuming that the changed options also semantically mean a different functionality).
Assuming you are dealing with a configuration update in "handleConfigurationUpdate", you can call "editThing" and use the returned ThingBuilder to change the structure (i.e. the channels) of your Thing.
See here for details: https://www.eclipse.org/smarthome/documentation/development/bindings/thing-handler.html#updating-the-thing-structure
Previous Topic:ESH Scheduling UI
Next Topic:How to use Trigger-Channels?
Current Time: Sun Jul 20 17:15:16 EDT 2025
Powered by FUDForum. Page generated in 0.04240 seconds
