Home » Modeling » Papyrus » How to customize the palette?
How to customize the palette? [message #1597853] Mon, 02 February 2015 10:55 Go to next message
Good afternoon,
I would like to know if there is a methodological guide to customize the palette because I couldn't find one in the help contents.
In fact, I have made a specific profil and I have created some stereotypes on the classifier metaclass but I can't add them in the palette (Requirement Diagram).
Thank you very much,
Adrien.
Re: How to customize the palette? [message #1755913 is a reply to message #1597853] Thu, 09 March 2017 04:52 Go to previous messageGo to next message
Hi Adrien,
did you come any further? I was able to create a custom palette via externsion point "org.eclipse.papyrus.uml.diagram.common.paletteDefinition".
   <extension
         point="org.eclipse.papyrus.uml.diagram.common.paletteDefinition">
          <paletteDefinition
          		ID="de.oose.papyrus.sysml.sysmod.palette"
        		class="org.eclipse.papyrus.uml.diagram.common.service.PluginPaletteProvider"
        		icon="img/logo.jpg"
        		name="Diagram Elements"
        		path="palette.xml">
        		<Priority name="Medium"/>
        		<editor id="org.eclipse.papyrus.uml.diagram.clazz"/>
			</paletteDefinition>
   </extension>
The defintion of the palette items is done via palette.xml
<?xml version="1.0" encoding="UTF-8" standalone="no"?>
<paletteDefinition>
    <content>
        <drawer iconpath="/img" id="sysmodDrawer" name="SYSMOD">
            <aspectTool description="Create a SYSMOD user (Actor)"
                iconpath="platform:/plugin/SYSMOD41/img/sysmod_user_16_16.png"
                id="clazz.tool.class_sysmod_user"
                name="User (Block)"
                refToolId="clazz.tool.class">
                <postAction id="org.eclipse.papyrus.applystereotypeactionprovider">
                    <stereotypesToApply>
                        <stereotype stereotypeName="SYSMOD41::User" />
                    </stereotypesToApply>
                </postAction>
            </aspectTool>
            <aspectTool description="Create a SYSMOD External System (Actor)"
                iconpath="platform:/plugin/SYSMOD41/img/sysmod_external_system_16_16.png"
                id="clazz.tool.class_sysmod_external_system"
                name="External System (Block)"
                        <stereotype stereotypeName="SYSMOD41::ExternalSystem" />
                </postAction>
            </aspectTool>
        </drawer>
    </content>
Unfortunately the creation of correctly stereotyped model elements does only work for stereotypes, that are derived by generalization-relationship from their SYSML super-stereotype.
Stereotypes, which are created by extension-releationship from a metaclass are not created as the "generalized" ones, if droped in a model diagram. In this case I see this console message:
!MESSAGE impossible to retrieve the stereotype SYSMOD41::User
Any idea?
Bernd
Re: How to customize the palette? [message #1756034 is a reply to message #1755913] Fri, 10 March 2017 04:54 Go to previous messageGo to next message
If fact , thete xas a lack about the palette customization/
The palette is being refactored, the documentation of this customization will be added.
Re: How to customize the palette? [message #1756062 is a reply to message #1756034] Fri, 10 March 2017 08:21 Go to previous messageGo to next message
Thanks Patrick, how can I keep track to get informed about the fix? Is is planned for a specific release?
Re: How to customize the palette? [message #1759061 is a reply to message #1756062] Wed, 05 April 2017 12:32 Go to previous message
I would like to come back to the problem that sterotypes created by extension relationship from a metaclass are not instanciated. Example:
My Profile:
Stereotype <<System>> is created by generalization from SysML Stereotype Block
Stereotype <<User>> is created by extension from UML Metaclass Actor
System appears correctly with stereotype <<system>> when I add it from the palette to my diagram Smile
User comes without stereotype Sad
Now I figured out that all the stereotypes created by extension relationship are not vilible in my profile. Could have realized this earlier Rolling Eyes After this illumination this might not longer be the right stream. Do you know a more appropriate one?
Any idea how to fix this?
Previous Topic:Difference between "Action Execution Specification" and "Behavior Execution Specifica
Next Topic:Applying user defined stereotypes to the model elements in block definition diagram,SysML
Current Time: Sun Jul 20 16:31:00 EDT 2025
Powered by FUDForum. Page generated in 0.04343 seconds
