Home » Language IDEs » Java Development Tools (JDT) » switch from "lambda expression" to "method reference"
switch from "lambda expression" to "method reference" [message #1758833] Mon, 03 April 2017 11:13 Go to next message
Hello, context assist now always proposes to switch from "lambda expression" to "method reference" when it's possibile, but I think it's wrong because not all conversions are the same thing.
When working with non-final class variables, it shouldn't propose to switch to "method reference".
Below a snippet that produces different results:
public class TestClass {
    static class TestClassInt {
        int value;
        public TestClassInt(int i) {
            value = i;
        public void printMe() {
            System.out.println(String.valueOf(value));
    TestClassInt var1;
    Runnable     r1;
    Runnable     r2;
    public TestClass() {
        var1 = new TestClassInt(1);
        r1 = () -> var1.printMe();
        r2 = var1::printMe;
        var1 = new TestClassInt(2);
    private void print() {
        r1.run();
        r2.run();
        new TestClass().print();
Re: switch from "lambda expression" to "method reference" [message #1760762 is a reply to message #1758833] Tue, 02 May 2017 12:38 Go to previous message
Are you talking about this line of code?
There's no compiler error when this is converted to a method reference. So, I don't see why the conversion can't be offered.
Previous Topic:Is JRE 9 compatibile with Eclipse 3.8 RCP Application?
Next Topic:Dependent Projects and JAR files
Current Time: Sat Jul 19 06:59:24 EDT 2025
Powered by FUDForum. Page generated in 0.03678 seconds
