BatchFetch examples? [message #1758547] |
Wed, 29 March 2017 22:09  |
We're using JPA and Hibernate and are using a repository pattern. At the repo class, we've defined a query to fetch a list of CustomerOrder entities:
@Query("SELECT DISTINCT co FROM CustomerOrder co " +
"INNER JOIN co.customerOrderItems coi " +
"WHERE co.customerOrderTypeId IN (1,3,8) " +
"AND co.customerOrderStatusId IN (2,6) " +
"AND co.customerEmail IS NOT NULL " +
"AND coi.performanceId = :performanceId")
List<CustomerOrder> findAllOrdersWithActiveTicketsForPerformance(@Param("performanceId") BigDecimal performanceId);
Because there can be many thousands of these we need to process, and several relationships (some of which are nested), we'd like to avoid the dread n+1 scenario.
If I can get just one of these relationships to work, I'm pretty sure I can do the rest! Here's what we have to link CustomerOrder to CustomerOrderItem.
In CustomerOrderItem (the child entity):
@Entity
@Table(name = "CUSTOMER_ORDER_ITEM")
public class CustomerOrderItem
@JsonIgnore
@ManyToOne(fetch = FetchType.LAZY)
@JoinColumn(name="CUSTOMER_ORDER_ID")
private CustomerOrder customerOrder;
In CustomerOrder (the parent entity):
@Entity
@Table(name = "CUSTOMER_ORDER")
@OneToMany(mappedBy = "customerOrder", fetch = FetchType.EAGER)
@BatchFetch(BatchFetchType.EXISTS)
private List<CustomerOrderItem> customerOrderItems;
If I leave CustomerOrder.CustomerOrderItems as EAGER I wind up with a bazillion queries, which I would expect if I use EAGER, however I've read answers to questions that swear it must be set to EAGER
If I change to LAZY, I receive a LazyInitializationException. Not sure what I'm doing wrong. Seems like this should be straightforward, but documentation is wrong in some cases, or so sparse that it has one or two lines completely out-of-context and I'm not sure how to apply to our situation.
Anyone have ideas or a snippet of "real world" code I can look at and understand how to make this work?
---Jason
Re: BatchFetch examples? [message #1759056 is a reply to message #1758972] |
Wed, 05 April 2017 12:07  |
Ah, my misunderstanding for how Eclipse fits in -- or doesn't in our case. Thanks for the reply. I used my second choice solution to pre-fetch in the meantime: reworked the entities and queries to fetch everything I need up-front instead of on demand.
Thanks for responding,
---J
FUDForum. Page generated in 0.49954 seconds
