Home » Modeling » TMF (Xtext) » XbaseCompiler exception when compiling simple XExpressions
XbaseCompiler exception when compiling simple XExpressions [message #1758335] Mon, 27 March 2017 15:01 Go to next message
i'm using XbaseCoimpiler in my generator to genetare java code for XExpressions.
i setup the compilet like this:
def compileXExpression(XExpression xExpression) {
		var importManager=new ImportManager()
		val result = new FakeTreeAppendable(importManager)
		xbaseCompiler.toJavaStatement(xExpression, result, true)// xbaseCompiler.toJavaStatement(xExpression, result, false) doesn't work either.
		result
and then call that method every time i need the expression translated to java.
even with simple expressions the compiler is unable to find its type:
if i put as expression:
"".toString
i get this exception
	at org.eclipse.xtext.xbase.compiler.ImportManager.appendType(ImportManager.java:115)
	at org.eclipse.xtext.xbase.compiler.StringBuilderBasedAppendable.appendType(StringBuilderBasedAppendable.java:36)
	at org.eclipse.xtext.xbase.compiler.AbstractStringBuilderBasedAppendable.append(AbstractStringBuilderBasedAppendable.java:49)
	at org.eclipse.xtext.xbase.compiler.output.FakeTreeAppendable.append(FakeTreeAppendable.java:38)
	at org.eclipse.xtext.xbase.compiler.XbaseCompiler.appendConstructedTypeName(XbaseCompiler.java:972)
	at org.eclipse.xtext.xbase.compiler.XbaseCompiler.constructorCallToJavaExpression(XbaseCompiler.java:941)
	at org.eclipse.xtext.xbase.compiler.XbaseCompiler._toJavaExpression(XbaseCompiler.java:996)
	at org.eclipse.xtext.xbase.compiler.XbaseCompiler.internalToConvertedExpression(XbaseCompiler.java:322)
	at org.eclipse.xtext.xbase.compiler.TypeConvertingCompiler.internalToConvertedExpression(TypeConvertingCompiler.java:104)
	at org.eclipse.xtext.xbase.compiler.TypeConvertingCompiler.internalToJavaExpression(TypeConvertingCompiler.java:47)
	at org.eclipse.xtext.xbase.compiler.FeatureCallCompiler.appendReceiver(FeatureCallCompiler.java:783)
	at org.eclipse.xtext.xbase.compiler.FeatureCallCompiler.featureCalltoJavaExpression(FeatureCallCompiler.java:580)
	at org.eclipse.xtext.xbase.compiler.FeatureCallCompiler._toJavaStatement(FeatureCallCompiler.java:162)
	at org.eclipse.xtext.xbase.compiler.FeatureCallCompiler.doInternalToJavaStatement(FeatureCallCompiler.java:111)
	at org.eclipse.xtext.xbase.compiler.XbaseCompiler.doInternalToJavaStatement(XbaseCompiler.java:385)
	at org.eclipse.xtext.xbase.compiler.AbstractXbaseCompiler.internalToJavaStatement(AbstractXbaseCompiler.java:473)
	at org.eclipse.xtext.xbase.compiler.AbstractXbaseCompiler.toJavaStatement(AbstractXbaseCompiler.java:485)
i've changed the arguments to the xbaseCompiler, but it doesn't work. Based on several examples online it seems to be right, but is not working.
Do you have any clue on what i'm doing wrong?
Thanks for your help!
[Updated on: Mon, 27 March 2017 15:04] by Moderator
Re: XbaseCompiler exception when cimpiling simple XExpressions [message #1758336 is a reply to message #1758335] Mon, 27 March 2017 15:07 Go to previous messageGo to next message
you are basically trying to do something you should not do.
this is why i told you that this is a bad idea in the first place ........
i assume you dont implement JvmModelInferrer or did construct the model in a way the itypecomputer was not called.
Re: XbaseCompiler exception when cimpiling simple XExpressions [message #1758337 is a reply to message #1758336] Mon, 27 March 2017 15:14 Go to previous messageGo to next message
oh, i see.
I saw an example by Lorenzo Bettini here
https://github.com/LorenzoBettini/Xtext2-experiments/blob/master/helloxbase/org.xtext.example.helloxbase/src/org/xtext/example/helloxbase/generator/HelloXbaseGenerator.xtend
the article is here
https://dzone.com/articles/xtext-21-using-xbase
I thought it could work, since he mixes a generator and xbasecompiler...
is this not supported anymore?
Re: XbaseCompiler exception when cimpiling simple XExpressions [message #1758338 is a reply to message #1758337] Mon, 27 March 2017 15:23 Go to previous messageGo to next message
well there were some major changes since this. there is a way to get it running but i cannot tell you step by step.
i just can give you the hint about the type computer playing an important role and that this might be the cause for your problem.
(see https://www.eclipse.org/forums/index.php/m/1081654/ which might be exactly on your problem)
but i still dont get your problem with the JvmModelGenerator/Inferrer in the first place since you did not do any further elaboration
Re: XbaseCompiler exception when cimpiling simple XExpressions [message #1758339 is a reply to message #1758338] Mon, 27 March 2017 15:31 Go to previous messageGo to next message
thanks for your help!
Well, i need to generate non valid java classes, so for instance import and reference classes that are not yet on the classpath. Using the inferrer the code won't even get generated, since it's not valid.
With the generator i can put all kinds on non existent references in my generated java files and fix them once they are provided (much later down the process)
I know is weird, but it is mainly to support the development of the plugin itself, since the required classes live in a different project and even a different eclipse installation loaded with the language plugins.
i hope this makes a little more sense.
Thanks again
Re: XbaseCompiler exception when cimpiling simple XExpressions [message #1758340 is a reply to message #1758339] Mon, 27 March 2017 15:34 Go to previous messageGo to next message
hmmmm but how can you verify the code is valid if you import stuff that is not there?
xbase will not even be able to say 1+1 = 2 is the classpath is broken. since you could provide a import that overloads + in a way that 1+1 = 4
Re: XbaseCompiler exception when cimpiling simple XExpressions [message #1758407 is a reply to message #1758340] Tue, 28 March 2017 09:16 Go to previous messageGo to next message
no, i'm only importing non existent java classes, since there's no operator overload in java i think i'm safe.
Those missing classes are hardcoded framework classes that i need to include in the generated code (annotations, services, etc.), so i know exactly where to put them.
As for the Xbase code, i only extended a couple of classes to suit my purposes, all the rest of the validation is there., so in theory the user can't enter invalid code, only my generator can put invalid classes in selected places.
Re: XbaseCompiler exception when cimpiling simple XExpressions [message #1758414 is a reply to message #1758407] Tue, 28 March 2017 09:33 Go to previous messageGo to next message
Yes but why don't you use xbase and inferrer then any simply adapt jvmmodelgenerator to adapt the Imports....
But I still don't get it if no use uses the imports they are unused and you can leave them away.
And I don't understand how you compile the generator code if the missing classes are not on the classpath
Of the generated code you can't compile the generated code
Re: XbaseCompiler exception when cimpiling simple XExpressions [message #1758453 is a reply to message #1758414] Tue, 28 March 2017 15:26 Go to previous messageGo to next message
-Ok, i'm back to my inferrer, but now i need to modify the body of my generated method and i don't know how.
Originally i was doing this in the inferrer:
	def dispatch void infer(Model element, IJvmDeclaredTypeAcceptor acceptor, boolean isPreIndexingPhase) {
		acceptor.accept(element.toClass(element.name)) [
			for (com:element.sections.filter(Command)){
				members += com.toMethod(com.name, typeRef(CommandResponse))[
					for (argument:com.arguments.args){
						parameters+=element.toParameter(argument.name, argument.type)
					body=com.block
and that put in the generated method all that the user entered.
But now i want to put my own autogenerated stuff before that block , something like:
body='''String myId="1"; ''' +com.block
But now i'm affraid this is not possible...
Can you confirm this please?
once again, thank you very much for your help!
Re: XbaseCompiler exception when cimpiling simple XExpressions [message #1758455 is a reply to message #1758453] Tue, 28 March 2017 16:07 Go to previous message
This does not work
You need to infer two methods
One with body = '''...''' and one with body = expression
In the first one you can call the second one
Previous Topic:Missing auto complete and validation in 2.11
Next Topic:deploy xtext language as maven artifact
Current Time: Sun Jul 20 09:37:49 EDT 2025
Powered by FUDForum. Page generated in 0.05136 seconds
