Home » Archived » Orion (Archived) » Cannot execute Orion Server nor Node Server
Cannot execute Orion Server nor Node Server [message #1758077] |
Thu, 23 March 2017 06:25 |
Latest orion.exe (14.2) is complaining about a portion of a file being already locked and the web server is not launched...
Tried on 2 W10 x64 machines with latest JRE (1.8.0_121).
Concerning Node Server, it appears that compiled node-git module cannot be downloaded (403) and an error occurs compiling it...
Thanks for your help!
--Alain
11:06:32,726 |-INFO in ch.qos.logback.classic.LoggerContext[default] - Could NOT find resource [logback.groovy]
11:06:32,726 |-INFO in ch.qos.logback.classic.LoggerContext[default] - Could NOT find resource [logback-test.xml]
11:06:32,727 |-INFO in ch.qos.logback.classic.LoggerContext[default] - Found resource [logback.xml] at [bundleresource://2.fwk550752602:1/logback.xml]
11:06:32,734 |-INFO in ch.qos.logback.core.joran.spi.ConfigurationWatchList@7533d4d5 - URL [bundleresource://2.fwk550752602:1/logback.xml] is not of type file
11:06:32,749 |-INFO in ch.qos.logback.classic.joran.action.ConfigurationAction - debug attribute not set
11:06:32,750 |-INFO in ch.qos.logback.classic.joran.action.LoggerContextListenerAction - Adding LoggerContextListener of type [ch.qos.logback.classic.jul.LevelChangePropagator] to the object stack
11:06:32,776 |-INFO in ch.qos.logback.classic.jul.LevelChangePropagator@63404a2e - Propagating DEBUG level on Logger[ROOT] onto the JUL framework
11:06:32,776 |-INFO in ch.qos.logback.classic.joran.action.LoggerContextListenerAction - Starting LoggerContextListener
11:06:32,776 |-INFO in ch.qos.logback.core.joran.action.AppenderAction - About to instantiate appender of type [ch.qos.logback.core.ConsoleAppender]
11:06:32,778 |-INFO in ch.qos.logback.core.joran.action.AppenderAction - Naming appender as [STDOUT]
11:06:32,860 |-WARN in ch.qos.logback.core.ConsoleAppender[STDOUT] - This appender no longer admits a layout as a sub-component, set an encoder instead.
11:06:32,860 |-WARN in ch.qos.logback.core.ConsoleAppender[STDOUT] - To ensure compatibility, wrapping your layout in LayoutWrappingEncoder.
11:06:32,860 |-WARN in ch.qos.logback.core.ConsoleAppender[STDOUT] - See also http://logback.qos.ch/codes.html#layoutInsteadOfEncoder for details
11:06:32,861 |-INFO in ch.qos.logback.classic.joran.action.LoggerAction - Setting level of logger [org.eclipse.orion.internal.server.search.Indexer] to INFO
11:06:32,861 |-INFO in ch.qos.logback.classic.jul.LevelChangePropagator@63404a2e - Propagating INFO level on Logger[org.eclipse.orion.internal.server.search.Indexer] onto the JUL framework
11:06:32,861 |-INFO in ch.qos.logback.classic.joran.action.LoggerAction - Setting level of logger [org.eclipse.orion.server.login] to INFO
11:06:32,861 |-INFO in ch.qos.logback.classic.jul.LevelChangePropagator@63404a2e - Propagating INFO level on Logger[org.eclipse.orion.server.login] onto the JUL framework
11:06:32,862 |-INFO in ch.qos.logback.classic.joran.action.LoggerAction - Setting level of logger [org.eclipse.orion.server.account] to INFO
11:06:32,862 |-INFO in ch.qos.logback.classic.jul.LevelChangePropagator@63404a2e - Propagating INFO level on Logger[org.eclipse.orion.server.account] onto the JUL framework
11:06:32,862 |-INFO in ch.qos.logback.classic.joran.action.LoggerAction - Setting level of logger [org.eclipse.orion.server.core] to WARN
11:06:32,862 |-INFO in ch.qos.logback.classic.jul.LevelChangePropagator@63404a2e - Propagating WARN level on Logger[org.eclipse.orion.server.core] onto the JUL framework
11:06:32,862 |-INFO in ch.qos.logback.classic.joran.action.LoggerAction - Setting level of logger [org.eclipse.orion.server.config] to INFO
11:06:32,862 |-INFO in ch.qos.logback.classic.jul.LevelChangePropagator@63404a2e - Propagating INFO level on Logger[org.eclipse.orion.server.config] onto the JUL framework
11:06:32,862 |-INFO in ch.qos.logback.classic.joran.action.RootLoggerAction - Setting level of ROOT logger to WARN
11:06:32,862 |-INFO in ch.qos.logback.classic.jul.LevelChangePropagator@63404a2e - Propagating WARN level on Logger[ROOT] onto the JUL framework
11:06:32,862 |-INFO in ch.qos.logback.core.joran.action.AppenderRefAction - Attaching appender named [STDOUT] to Logger[ROOT]
11:06:32,863 |-INFO in ch.qos.logback.classic.joran.action.ConfigurationAction - End of configuration.
11:06:32,864 |-INFO in ch.qos.logback.classic.joran.JoranConfigurator@35fc479f - Registering current configuration as safe fallback point
[2017-03-23 10:06:32.904 Z] [Start Level: Equinox Container: 50865a62-b00f-0017-1ec0-9b20a52cda89] INFO org.eclipse.orion.server.config - Started Orion server authentication successfully.
[2017-03-23 10:06:32.958 Z] [Worker-0] INFO org.eclipse.orion.server.config - No server configuration file found at: C:\eclipse-orion-14.0.0S4-win32.win32.x86_64\eclipse\orion.conf
[2017-03-23 10:06:32.959 Z] [Worker-0] INFO org.eclipse.orion.server.config - No server configuration file found at: C:\eclipse-orion-14.0.0S4-win32.win32.x86_64\eclipse\serverworkspace\orion.conf
[2017-03-23 10:06:32.967 Z] [Worker-0] INFO org.eclipse.orion.server.config - Tasks metadata location is C:\eclipse-orion-14.0.0S4-win32.win32.x86_64\eclipse\serverworkspace\.metadata\.tasks
[2017-03-23 10:06:32.967 Z] [Worker-0] INFO org.eclipse.orion.server.config - Creating tasks folder C:\eclipse-orion-14.0.0S4-win32.win32.x86_64\eclipse\serverworkspace\.metadata\.tasks
[2017-03-23 10:06:33.005 Z] [Worker-0] ERROR org.eclipse.orion.server.config - Meta File Error, file IO error
java.io.IOException: The process cannot access the file because another process has locked a portion of the file
at java.io.FileOutputStream.writeBytes(Native Method) ~[na:1.8.0_121]
at java.io.FileOutputStream.write(Unknown Source) ~[na:1.8.0_121]
at sun.nio.cs.StreamEncoder.writeBytes(Unknown Source) ~[na:1.8.0_121]
at sun.nio.cs.StreamEncoder.implFlushBuffer(Unknown Source) ~[na:1.8.0_121]
at sun.nio.cs.StreamEncoder.implFlush(Unknown Source) ~[na:1.8.0_121]
at sun.nio.cs.StreamEncoder.flush(Unknown Source) ~[na:1.8.0_121]
at java.io.OutputStreamWriter.flush(Unknown Source) ~[na:1.8.0_121]
at org.eclipse.orion.internal.server.core.metastore.SimpleMetaStoreUtil.createMetaFile(SimpleMetaStoreUtil.java:149) ~[org.eclipse.orion.server.core_1.0.0.v20170203-1617.jar:na]
at org.eclipse.orion.internal.server.core.metastore.SimpleMetaStore.initializeMetaStore(SimpleMetaStore.java:566) [org.eclipse.orion.server.core_1.0.0.v20170203-1617.jar:na]
at org.eclipse.orion.internal.server.core.metastore.SimpleMetaStore.<init>(SimpleMetaStore.java:122) [org.eclipse.orion.server.core_1.0.0.v20170203-1617.jar:na]
at org.eclipse.orion.internal.server.core.Activator.initializeMetaStore(Activator.java:135) [org.eclipse.orion.server.core_1.0.0.v20170203-1617.jar:na]
at org.eclipse.orion.internal.server.core.Activator.start(Activator.java:150) [org.eclipse.orion.server.core_1.0.0.v20170203-1617.jar:na]
at org.eclipse.osgi.internal.framework.BundleContextImpl$3.run(BundleContextImpl.java:771) [org.eclipse.osgi_3.10.0.v20140606-1445.jar:na]
at org.eclipse.osgi.internal.framework.BundleContextImpl$3.run(BundleContextImpl.java:1) [org.eclipse.osgi_3.10.0.v20140606-1445.jar:na]
at java.security.AccessController.doPrivileged(Native Method) [na:1.8.0_121]
at org.eclipse.osgi.internal.framework.BundleContextImpl.startActivator(BundleContextImpl.java:764) [org.eclipse.osgi_3.10.0.v20140606-1445.jar:na]
at org.eclipse.osgi.internal.framework.BundleContextImpl.start(BundleContextImpl.java:721) [org.eclipse.osgi_3.10.0.v20140606-1445.jar:na]
at org.eclipse.osgi.internal.framework.EquinoxBundle.startWorker0(EquinoxBundle.java:936) [org.eclipse.osgi_3.10.0.v20140606-1445.jar:na]
at org.eclipse.osgi.internal.framework.EquinoxBundle$EquinoxModule.startWorker(EquinoxBundle.java:319) [org.eclipse.osgi_3.10.0.v20140606-1445.jar:na]
at org.eclipse.osgi.container.Module.doStart(Module.java:571) [org.eclipse.osgi_3.10.0.v20140606-1445.jar:na]
at org.eclipse.osgi.container.Module.start(Module.java:439) [org.eclipse.osgi_3.10.0.v20140606-1445.jar:na]
at org.eclipse.osgi.framework.util.SecureAction.start(SecureAction.java:454) [org.eclipse.osgi_3.10.0.v20140606-1445.jar:na]
at org.eclipse.osgi.internal.hooks.EclipseLazyStarter.postFindLocalClass(EclipseLazyStarter.java:107) [org.eclipse.osgi_3.10.0.v20140606-1445.jar:na]
at org.eclipse.osgi.internal.loader.classpath.ClasspathManager.findLocalClass(ClasspathManager.java:531) [org.eclipse.osgi_3.10.0.v20140606-1445.jar:na]
at org.eclipse.osgi.internal.loader.ModuleClassLoader.findLocalClass(ModuleClassLoader.java:324) [org.eclipse.osgi_3.10.0.v20140606-1445.jar:na]
at org.eclipse.osgi.internal.loader.BundleLoader.findLocalClass(BundleLoader.java:311) [org.eclipse.osgi_3.10.0.v20140606-1445.jar:na]
at org.eclipse.osgi.internal.loader.sources.SingleSourcePackage.loadClass(SingleSourcePackage.java:36) [org.eclipse.osgi_3.10.0.v20140606-1445.jar:na]
at org.eclipse.osgi.internal.loader.BundleLoader.findClassInternal(BundleLoader.java:382) [org.eclipse.osgi_3.10.0.v20140606-1445.jar:na]
at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:336) [org.eclipse.osgi_3.10.0.v20140606-1445.jar:na]
at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:328) [org.eclipse.osgi_3.10.0.v20140606-1445.jar:na]
at org.eclipse.osgi.internal.loader.ModuleClassLoader.loadClass(ModuleClassLoader.java:160) [org.eclipse.osgi_3.10.0.v20140606-1445.jar:na]
at java.lang.ClassLoader.loadClass(Unknown Source) [na:1.8.0_121]
at org.eclipse.orion.server.authentication.Activator$AuthenticationMetaStoreJob.run(Activator.java:75) [org.eclipse.orion.server.authentication_1.0.0.v20170317-1248.jar:na]
at org.eclipse.core.internal.jobs.Worker.run(Worker.java:54) [org.eclipse.core.jobs_3.6.0.v20140424-0053.jar:na]
!SESSION 2017-03-23 11:06:28.597 -----------------------------------------------
eclipse.buildId=14.0.0-v20170317-0901
java.version=1.8.0_121
BootLoader constants: OS=win32, ARCH=x86_64, WS=win32, NL=en_US
Command-line arguments: -os win32 -ws win32 -arch x86_64 -consoleLog -console -data serverworkspace
!ENTRY org.eclipse.osgi 4 0 2017-03-23 11:06:33.022
!MESSAGE An error occurred while automatically activating bundle org.eclipse.orion.server.core (69).
!STACK 0
org.osgi.framework.BundleException: Error loading bundle activator.
at org.eclipse.osgi.internal.framework.BundleContextImpl.start(BundleContextImpl.java:711)
at org.eclipse.orion.server.git.GitActivator.start(GitActivator.java:35)
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.incStartLevel(ModuleContainer.java:1582)
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.incStartLevel(ModuleContainer.java:1562)
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.doContainerStartLevel(ModuleContainer.java:1533)
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.dispatchEvent(ModuleContainer.java:1476)
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.dispatchEvent(ModuleContainer.java:1)
at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:230)
at org.eclipse.osgi.framework.eventmgr.EventManager$EventThread.run(EventManager.java:340)
Caused by: java.lang.ClassNotFoundException: An error occurred while automatically activating bundle org.eclipse.orion.server.core (69).
at org.eclipse.osgi.internal.hooks.EclipseLazyStarter.postFindLocalClass(EclipseLazyStarter.java:116)
Caused by: org.osgi.framework.BundleException: Exception in org.eclipse.orion.internal.server.core.Activator.start() of bundle org.eclipse.orion.server.core.
at org.eclipse.osgi.internal.framework.BundleContextImpl.startActivator(BundleContextImpl.java:792)
... 11 more
Caused by: java.lang.RuntimeException: Meta File Error, file IO error
at org.eclipse.orion.internal.server.core.metastore.SimpleMetaStoreUtil.createMetaFile(SimpleMetaStoreUtil.java:162)
... 18 more
Caused by: java.io.IOException: The process cannot access the file because another process has locked a portion of the file
... 26 more
Root exception:
... 11 more
... 18 more
... 26 more
!ENTRY org.eclipse.osgi 4 0 2017-03-23 11:06:33.041
!STACK 0
... 18 more
... 26 more
Root exception:
... 26 more
!ENTRY org.eclipse.orion.server.git 4 0 2017-03-23 11:06:33.058
!MESSAGE FrameworkEvent ERROR
!STACK 0
org.osgi.framework.BundleException: Exception in org.eclipse.orion.server.git.GitActivator.start() of bundle org.eclipse.orion.server.git.
Caused by: java.lang.NoClassDefFoundError: org/eclipse/orion/server/core/IWebResourceDecorator
... 12 more
... 17 more
Caused by: org.osgi.framework.BundleException: Error loading bundle activator.
... 26 more
... 11 more
... 18 more
... 26 more
Root exception:
... 17 more
... 26 more
... 11 more
... 18 more
... 26 more
!ENTRY org.eclipse.core.jobs 4 2 2017-03-23 11:06:33.076
!MESSAGE An internal error occurred during: "AuthenticationMetaStoreJob".
!STACK 0
java.lang.NoClassDefFoundError: org/eclipse/orion/server/core/OrionConfiguration
... 2 more
... 11 more
... 18 more
... 26 more
!ENTRY org.eclipse.orion.server.servlets 4 0 2017-03-23 11:06:33.095
!STACK 0
org.osgi.framework.BundleException: Exception in org.eclipse.orion.internal.server.servlets.Activator.start() of bundle org.eclipse.orion.server.servlets.
at org.eclipse.orion.internal.server.servlets.Activator.registerServices(Activator.java:107)
at org.eclipse.orion.internal.server.servlets.Activator.start(Activator.java:115)
... 12 more
... 16 more
... 26 more
... 11 more
... 18 more
... 26 more
Root exception:
... 16 more
... 26 more
... 11 more
... 18 more
... 26 more
Current Time: Sat Jul 19 14:53:04 EDT 2025
Powered by FUDForum. Page generated in 0.03992 seconds
