Home » Newcomers » Newcomers » Ecilpse Neon will not Install Windows 10( Java Compatibility Error)
Ecilpse Neon will not Install Windows 10 [message #1751324] Sun, 08 January 2017 13:20 Go to next message
I have tried several times to install Eclipse Neon and have been getting an error stating Eclipse requires Java 1.8. I have installed Java 1.8 and when I run the Java -version command it reports 1.8 is installed. Does anyone know the solution to this problem?
Re: Ecilpse Neon will not Install Windows 10 [message #1751326 is a reply to message #1751324] Sun, 08 January 2017 14:17 Go to previous messageGo to next message
Have you mixed up 32-bit and 64-bit Eclipse and Java installations?
Re: Ecilpse Neon will not Install Windows 10 [message #1756397 is a reply to message #1751324] Thu, 16 March 2017 08:09 Go to previous messageGo to next message
I tried to install Neon 64 on 'doze 10 and the installer advised that I needed to install Java, even provided a link to the Java installs at Oracle.
I installed Java 64 1.8.0. Java thinks it is installed but Neon does not. Attempts to run eclipse-inst-win64.exe take me back to the Eclipse 'Java for Windows Missing' page.
I conclude that at the moment 'Ecilpse Neon will not Install Windows 10'.
Re: Ecilpse Neon will not Install Windows 10 [message #1756408 is a reply to message #1756397] Thu, 16 March 2017 10:24 Go to previous message
If you open a command prompt and run java -version, what does it print? Can you paste the complete file system path where you've installed Java?
Previous Topic:Maven-Jetty Plugin - Bug in resourceBases and baseResource in 9.4.0.RC3 and 9.3.3.vx
Next Topic:Eclipse jee-neon on macOS Sierra
Current Time: Sun Jul 20 18:08:12 EDT 2025
Powered by FUDForum. Page generated in 0.08061 seconds
