Home » Modeling » TMF (Xtext) » Maven not able to find MWE2 file referred by unit tests.
Maven not able to find MWE2 file referred by unit tests. [message #1756029] Fri, 10 March 2017 04:38 Go to next message
I have junit tests referring a workflow of other plugin. It resolves the mwe2 when tests are run from eclipse environment but failed to do so in maven tests.
I have created a tiny project excluding the DSL plugins and keeping only the required plugins to reproduce the problem and attached to the post. Below are the details.
PrintToFile.mwe2 file in project com.mwe2maventest.problem is invoked by tests of PrintMessageTest from com.mwe2maventest.problem.test
Project structure of com.mwe2maventest.problem
    - src
        - com (contains java classes)
        - workflow
            -PrintToFile.mwe2
manifest.mf of com.mwe2maventest.problem
Manifest-Version: 1.0
Bundle-ManifestVersion: 2
Bundle-Name: Problem
Bundle-SymbolicName: com.mwe2maventest.problem
Bundle-Version: 1.0.0.qualifier
Bundle-RequiredExecutionEnvironment: JavaSE-1.8
Require-Bundle: org.eclipse.emf.mwe2.runtime;bundle-version="2.9.0",
 org.eclipse.emf.mwe2.lib;bundle-version="2.9.0",
 org.eclipse.emf.mwe.core,
 org.junit
Export-Package: com.mwe2Maventest.problem.print
manifest.mf of com.mwe2maventest.problem.test
Bundle-Name: Test
Bundle-SymbolicName: com.mwe2maventest.problem.test
Bundle-Vendor: MWE2MAVENTEST
 com.mwe2maventest.problem;bundle-version="1.0.0",
 org.junit;bundle-version="4.11.0",
 org.eclipse.emf.mwe2.launch,
 org.apache.log4j;bundle-version="1.2.15",
 org.eclipse.equinox.common;bundle-version="3.8.0",
 org.eclipse.xtext.xbase;bundle-version="2.10.0",
 org.apache.commons.logging;bundle-version="1.1.1"
when maven tests are run i am getting error complaining about missing workflow "workflow.PrintToFile"
 T E S T S
Running com.mwe2Maventest.problem.print.PrintMessageTest
Tests run: 3, Failures: 0, Errors: 3, Skipped: 0, Time elapsed: 1.03 sec <<< FAILURE! - in com.mwe2Maventest.problem.print.PrintMessageTest
testFileGenM1(com.mwe2Maventest.problem.print.PrintMessageTest)  Time elapsed: 0.928 sec  <<< ERROR!
java.lang.IllegalStateException: Couldn't find module workflow.PrintToFile
        at org.eclipse.emf.mwe2.launch.runtime.Mwe2Runner.run(Mwe2Runner.java:77)
        at org.eclipse.emf.mwe2.launch.runtime.Mwe2Runner.run(Mwe2Runner.java:71)
        at org.eclipse.emf.mwe2.launch.runtime.Mwe2Launcher.run(Mwe2Launcher.java:80)
        at com.mwe2Maventest.problem.print.PrintMessageTest.runner(PrintMessageTest.java:47)
        at com.mwe2Maventest.problem.print.PrintMessageTest.testFileGenM1(PrintMessageTest.java:19)
testFileGenM2(com.mwe2Maventest.problem.print.PrintMessageTest)  Time elapsed: 0.049 sec  <<< ERROR!
        at com.mwe2Maventest.problem.print.PrintMessageTest.testFileGenM2(PrintMessageTest.java:27)
testFileGenM3(com.mwe2Maventest.problem.print.PrintMessageTest)  Time elapsed: 0.03 sec  <<< ERROR!
        at com.mwe2Maventest.problem.print.PrintMessageTest.testFileGenM3(PrintMessageTest.java:35)
[Updated on: Mon, 13 March 2017 09:13] by Moderator
Re: Maven not able to find MWE2 file referred by unit tests. [message #1756092 is a reply to message #1756029] Fri, 10 March 2017 16:13 Go to previous messageGo to next message
- do you run the test in eclipse as plugin test?
- the stuff is not buildable cause of the target platform. can you share something that is buildable?
- is the mwe2 file part of the jar that is built? if yes how is the path?
- how does the claspath look like that the test sees when called from maven?
i assume the classpath is not the same (mwe uses java.class.path, am not sure if surefire sets that correct)
=> i think you have to care about this (or run the test as junit test instead of as plugin test)
=> i do not really have an idea on how to solve this
https://bugs.eclipse.org/bugs/show_bug.cgi?id=318721
especially calling standalonesetups from workflow might be dangerous
you may try the workaround there but i am not sure if it will work in your case and how that could look like.
package com.mwe2Maventest.problem.print;
import java.util.HashMap;
import java.util.Map;
import org.apache.commons.cli.CommandLine;
import org.apache.commons.cli.CommandLineParser;
import org.apache.commons.cli.HelpFormatter;
import org.apache.commons.cli.Option;
import org.apache.commons.cli.OptionBuilder;
import org.apache.commons.cli.Options;
import org.apache.commons.cli.ParseException;
import org.apache.commons.cli.PosixParser;
import org.apache.log4j.Logger;
import org.eclipse.core.runtime.OperationCanceledException;
import org.eclipse.emf.common.util.URI;
import org.eclipse.emf.mwe2.language.Mwe2RuntimeModule;
import org.eclipse.emf.mwe2.language.Mwe2StandaloneSetup;
import org.eclipse.emf.mwe2.launch.runtime.Mwe2Runner;
import org.eclipse.xtext.mwe.RuntimeResourceSetInitializer;
import com.google.inject.Guice;
import com.google.inject.Injector;
public class Mwe2LauncherExtended {
	private static final String PARAM = "p";
	private static final Logger logger = Logger.getLogger(Mwe2LauncherExtended.class);
		try {
			new Mwe2LauncherExtended().run(args);
		} catch(Throwable throwable) {
			logger.error(throwable.getMessage(), throwable);
			System.exit(1);
	public void run(String[] args) {
		Options options = getOptions();
		final CommandLineParser parser = new PosixParser();
		CommandLine line = null;
		try {
			line = parser.parse(options, args);
			if (line.getArgs().length == 0)
				throw new ParseException("No module name specified.");
			if (line.getArgs().length > 1)
				throw new ParseException("Only one module name expected. But " + line.getArgs().length
						+ " were passed (" + line.getArgList() + ")");
			String moduleName = line.getArgs()[0];
			Map<String, String> params = new HashMap<String, String>();
			String[] optionValues = line.getOptionValues(PARAM);
			if (optionValues != null) {
				for (String string : optionValues) {
					int index = string.indexOf('=');
					if (index == -1) {
						throw new ParseException("Incorrect parameter syntax '" + string
								+ "'. It should be 'name=value'");
					String name = string.substring(0, index);
					String value = string.substring(index + 1);
					if (params.put(name, value) != null) {
						throw new ParseException("Duplicate parameter '" + name + "'.");
			// check  OperationCanceledException is accessible
			OperationCanceledException.class.getName();
			Injector injector = new Mwe2StandaloneSetup() {
	            public Injector createInjector() {
	                return Guice.createInjector(new Mwe2RuntimeModule() {
	                    public Class<? extends RuntimeResourceSetInitializer> bindRuntimeResourceSetInitializer() {
	                        return OSGiResourceSetInitializer.class;
	        }.createInjectorAndDoEMFRegistration();
			Mwe2Runner mweRunner = injector.getInstance(Mwe2Runner.class);
			if (moduleName.contains("/")) {
				mweRunner.run(URI.createURI(moduleName), params);
			} else {
				mweRunner.run(moduleName, params);
		} catch(NoClassDefFoundError e) {
			if ("org/eclipse/core/runtime/OperationCanceledException".equals(e.getMessage())){
				System.err.println("Could not load class: org.eclipse.core.runtime.OperationCanceledException");
				System.err.println("Add org.eclipse.equinox.common to the class path.");
			} else {
				throw e;
		} catch (final ParseException exp) {
			final HelpFormatter formatter = new HelpFormatter();
			System.err.println("Parsing arguments failed.  Reason: " + exp.getMessage());
			formatter.printHelp("java " + Mwe2LauncherExtended.class.getName() + " some.mwe2.Module [options]\n", options);
			return;
	@SuppressWarnings("static-access")
	public Options getOptions() {
		final Options options = new Options();
		final Option paramOption = OptionBuilder.withArgName("key=value").withDescription(
				"external property that is handled as workflow property").hasArgs().create(PARAM);
		paramOption.setLongOpt("param");
		options.addOption(paramOption);
		return options;
import java.io.File;
import java.io.IOException;
import java.net.URL;
import java.util.List;
import org.eclipse.core.runtime.FileLocator;
import org.eclipse.core.runtime.Platform;
public class OSGiResourceSetInitializer extends RuntimeResourceSetInitializer {
    public List<String> getClassPathEntries() {
        List<String> classPathEntries = super.getClassPathEntries();
        try {
//maybe you can do this more generic ?!?
File resolved = FileLocator.getBundleFile(Platform.getBundle("com.mwe2maventest.problem"));
			System.out.println(resolved);
			classPathEntries.add(resolved.toString());
		} catch (IOException e) {
			e.printStackTrace();
        return classPathEntries;
Re: Maven not able to find MWE2 file referred by unit tests. [message #1756173 is a reply to message #1756092] Mon, 13 March 2017 09:17 Go to previous messageGo to next message
No, I run as normal tests.
sorry about that, I have corrected the target and replaced the old zip.
Yes, xxx.jar/workflow/PrintToFile.mwe2 is the path of workflow file
No idea, how will I get to see that?
I will try above suggested method and update the results later.
Thanks.
[Updated on: Mon, 13 March 2017 10:58] by Moderator
Re: Maven not able to find MWE2 file referred by unit tests. [message #1756288 is a reply to message #1756173] Wed, 15 March 2017 02:55 Go to previous messageGo to next message
Hi Christian,
After suggested changes (extended mwe2 runner),when I run it from eclipse the tests will fail because I get null from this statement "Platform.getBundle("com.mwe2maventest.problem")",
here are the changes I have done in test reunner.
Mwe2LauncherExtended mwe2launcher = new Mwe2LauncherExtended();
Re: Maven not able to find MWE2 file referred by unit tests. [message #1756289 is a reply to message #1756288] Wed, 15 March 2017 02:59 Go to previous message
are you sure the bundle is on the path of the test path?
if you run it as PLUGIN TEST, which is what maven does, it should work fine
=> either you run both maven and eclipse as plain unit test (use maven surefire instead of tycho surefire - googling might help, dont know excactly how to do this)
=> or you run both maven and eclipse as plugin test (context menu in eclipse)
Previous Topic:XText grammar with lookbehind
Next Topic:Serializing expressions results in an exception
Current Time: Sun Jul 20 11:58:32 EDT 2025
Powered by FUDForum. Page generated in 0.05325 seconds
