Home » Eclipse Projects » Gendoc » Your functional needs
Your functional needs [message #1707224] Thu, 03 September 2015 03:54 Go to next message
We are trying to identify what are the functional features needed for a documentation generation toolset
If you are a user, a potential contributor, or an industrial please complete the wiki with :
- an added entry for interested party
- a new feature which seems interesting for you or your company
The goal of this page is to remain "high level" in terms of features, and please respect the template of the page.
The page of the wiki : https://wiki.eclipse.org/Gendoc/FunctionalFeatures
You can also react on this topic
Re: Your functional needs [message #1756057 is a reply to message #1707224] Fri, 10 March 2017 07:32 Go to previous messageGo to next message
I have need of generate a doc from a data model, but certain data must calculate dynamically, that it to say, I obtain some data from model, operate with them and the result must go to the generated doc. I use M2T (EMF+Xpand) for obtain dynamic data and carry them to plain text.
Is it possible with genDoc?
Re: Your functional needs [message #1756066 is a reply to message #1756057] Fri, 10 March 2017 09:30 Go to previous messageGo to next message
If I understand well your need, you can define services that would calculate the dynamic data, did you try that ?
Re: Your functional needs [message #1756146 is a reply to message #1756066] Mon, 13 March 2017 03:56 Go to previous messageGo to next message
How can I define these services?
Normally, in my framework, to calculate dynamic data I use java functions whose in parameters are data from model
Re: Your functional needs [message #1756230 is a reply to message #1756146] Tue, 14 March 2017 06:26 Go to previous message
how to define services is not yet explained in the documentation,
an introduction is available in this thread : https://www.eclipse.org/forums/index.php?t=msg&th=1065528&goto=1693155&#msg_1693155
Previous Topic:Error when generate doc
Next Topic:Usage of multiple templates
Current Time: Sat Jul 19 20:56:23 EDT 2025
Powered by FUDForum. Page generated in 0.03063 seconds
