Home » Eclipse Projects » Oomph » Setting Enum of String Variable
Setting Enum of String Variable [message #1755942] Thu, 09 March 2017 08:06 Go to next message
I want to have a dropdown variable in my Project.setup file similar to Target Platform option. However don't know what type to set as there are several types:
STRING, TEXT, PASSWORD, PATTERN, URI, FOLDER, RESOURCE, CONTAINER, PROJECT, BOOLEAN, FLOAT, JRE, INTEGER, but there is no Enum-of_string.
Am I missing something?
Velizar
Re: Setting Enum of String Variable [message #1755944 is a reply to message #1755942] Thu, 09 March 2017 08:10 Go to previous messageGo to next message
Providing options in a dropdown is a bit orthogonal to the type of the variable, you can define the values with choice values as children of the variable, see (implicit STRING type):
<setup:VariableTask
    xmi:version="2.0"
    xmlns:setup="http://www.eclipse.org/oomph/setup/1.0"
    name="viatra.repository.url"
    label="VIATRA Update site">
  <choice value="http://download.eclipse.org/viatra/updates/integration"
      label="Integration"/>
  <choice value="https://hudson.eclipse.org/viatra/job/viatra-master/lastSuccessfulBuild/artifact/releng/org.eclipse.viatra.update/target/repository/"
      label="CI"/>
  <description>Select Integration unless you need to check a very recent change</description>
</setup:VariableTask>
Re: Setting Enum of String Variable [message #1755946 is a reply to message #1755944] Thu, 09 March 2017 08:17 Go to previous message
Thank you very much! It works perfectly fine!
Previous Topic:Oomph Setup Configuration Model how to
Next Topic:File reference of a modular target in project profile?
Current Time: Sun Jul 20 03:39:46 EDT 2025
Powered by FUDForum. Page generated in 0.04598 seconds
