Custom SVG shapes uncaught exception [message #1755487] |
Fri, 03 March 2017 12:22  |
I am trying to create custom SVG shapes on a Papyrus profile following the video tutorial on Papyrus youtube channel (sorry but I can't send the link; no idea why).
I have associated an SVG shape with each stereotype in my profile. When I apply the profile to a new Papyrus model I get an error "Uncaught exception in transaction pre-commit task" caused by the org.eclipse.papyrus.infra.core plugin.
Here is the stack trace:
at org.apache.batik.dom.svg.AbstractSVGLength$DefaultContext.getViewportWidth(Unknown Source)
at org.apache.batik.parser.UnitProcessor.percentagesToPixels(Unknown Source)
at org.apache.batik.parser.UnitProcessor.svgToUserSpace(Unknown Source)
at org.apache.batik.dom.svg.AbstractSVGLength.getValue(Unknown Source)
at org.eclipse.papyrus.infra.gmfdiag.common.figure.node.SVGNodePlateFigure.getValueOf(SVGNodePlateFigure.java:197)
at org.eclipse.papyrus.infra.gmfdiag.common.figure.node.SVGNodePlateFigure.getSvgDimension(SVGNodePlateFigure.java:212)
at org.eclipse.papyrus.infra.gmfdiag.common.figure.node.SVGNodePlateFigure.setSVGDocument(SVGNodePlateFigure.java:160)
at org.eclipse.papyrus.infra.gmfdiag.common.editpart.NodeEditPart.refreshSVGPath(NodeEditPart.java:107)
at org.eclipse.papyrus.infra.gmfdiag.common.editpart.NodeEditPart.refreshVisuals(NodeEditPart.java:178)
at org.eclipse.papyrus.uml.diagram.common.editparts.UMLNodeEditPart.refreshVisuals(UMLNodeEditPart.java:254)
at org.eclipse.papyrus.uml.diagram.common.editparts.NamedElementEditPart.refreshVisuals(NamedElementEditPart.java:118)
at org.eclipse.papyrus.uml.diagram.common.editparts.RoundedCompartmentEditPart.refreshVisuals(RoundedCompartmentEditPart.java:181)
at org.eclipse.papyrus.uml.diagram.common.editparts.ClassifierEditPart.refreshVisuals(ClassifierEditPart.java:64)
at org.eclipse.papyrus.uml.diagram.common.editparts.ClassEditPart.refreshVisuals(ClassEditPart.java:42)
at org.eclipse.gef.editparts.AbstractEditPart.refresh(AbstractEditPart.java:725)
at org.eclipse.gef.editparts.AbstractGraphicalEditPart.refresh(AbstractGraphicalEditPart.java:644)
at org.eclipse.gmf.runtime.diagram.ui.editparts.GraphicalEditPart.access$3(GraphicalEditPart.java:1)
at org.eclipse.gmf.runtime.diagram.ui.editparts.GraphicalEditPart$3.run(GraphicalEditPart.java:861)
at org.eclipse.papyrus.infra.emf.readonly.PapyrusROTransactionalEditingDomain.runExclusive(PapyrusROTransactionalEditingDomain.java:271)
at org.eclipse.gmf.runtime.diagram.ui.editparts.GraphicalEditPart.refresh(GraphicalEditPart.java:851)
at org.eclipse.papyrus.uml.diagram.common.editparts.UMLNodeEditPart.refresh(UMLNodeEditPart.java:99)
at org.eclipse.papyrus.uml.diagram.common.editparts.NamedElementEditPart.refresh(NamedElementEditPart.java:108)
at org.eclipse.papyrus.infra.gmfdiag.common.helper.DiagramHelper.refresh(DiagramHelper.java:87)
at org.eclipse.papyrus.infra.gmfdiag.common.helper.DiagramHelper.refresh(DiagramHelper.java:116)
at org.eclipse.papyrus.infra.gmfdiag.common.helper.DiagramHelper$2.run(DiagramHelper.java:181)
at org.eclipse.papyrus.infra.core.utils.TransactionPrecommitExecutor$1.doExecute(TransactionPrecommitExecutor.java:133)
at org.eclipse.emf.transaction.RecordingCommand.execute(RecordingCommand.java:135)
at org.eclipse.emf.transaction.util.TriggerCommand.execute(TriggerCommand.java:113)
at org.eclipse.papyrus.infra.emf.gmf.command.NotifyingWorkspaceCommandStack.executeTriggers(NotifyingWorkspaceCommandStack.java:418)
at org.eclipse.papyrus.infra.core.utils.TransactionPrecommitExecutor.transactionClosing(TransactionPrecommitExecutor.java:164)
at org.eclipse.emf.transaction.impl.TransactionalEditingDomainImpl$LifecycleImpl.fireLifecycleEvent(TransactionalEditingDomainImpl.java:1380)
at org.eclipse.emf.transaction.impl.TransactionalEditingDomainImpl$LifecycleImpl.transactionClosing(TransactionalEditingDomainImpl.java:1406)
at org.eclipse.emf.transaction.impl.TransactionImpl.commit(TransactionImpl.java:398)
at org.eclipse.papyrus.infra.emf.readonly.PapyrusROTransactionalEditingDomain.runExclusive(PapyrusROTransactionalEditingDomain.java:276)
at org.eclipse.emf.transaction.impl.TransactionalEditingDomainImpl.postcommit(TransactionalEditingDomainImpl.java:771)
at org.eclipse.emf.transaction.impl.TransactionalEditingDomainImpl.deactivate(TransactionalEditingDomainImpl.java:543)
at org.eclipse.emf.transaction.impl.TransactionImpl.close(TransactionImpl.java:712)
at org.eclipse.emf.transaction.impl.TransactionImpl.commit(TransactionImpl.java:474)
at org.eclipse.emf.workspace.AbstractEMFOperation.execute(AbstractEMFOperation.java:155)
at org.eclipse.core.commands.operations.DefaultOperationHistory.execute(DefaultOperationHistory.java:488)
at org.eclipse.papyrus.infra.emf.gmf.command.CheckedOperationHistory.doExecute(CheckedOperationHistory.java:206)
at org.eclipse.papyrus.infra.emf.gmf.command.CheckedOperationHistory.execute(CheckedOperationHistory.java:195)
at org.eclipse.papyrus.infra.emf.gmf.command.NotifyingWorkspaceCommandStack.doExecute(NotifyingWorkspaceCommandStack.java:264)
at org.eclipse.emf.transaction.impl.AbstractTransactionalCommandStack.execute(AbstractTransactionalCommandStack.java:165)
at org.eclipse.emf.transaction.impl.AbstractTransactionalCommandStack.execute(AbstractTransactionalCommandStack.java:219)
at org.eclipse.papyrus.infra.emf.gmf.command.NestingNotifyingWorkspaceCommandStack.execute(NestingNotifyingWorkspaceCommandStack.java:130)
at org.eclipse.papyrus.uml.properties.profile.ui.compositesformodel.AppliedStereotypeCompositeOnModel$1$1.run(AppliedStereotypeCompositeOnModel.java:482)
at org.eclipse.swt.widgets.RunnableLock.run(RunnableLock.java:35)
at org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchronizer.java:182)
at org.eclipse.swt.widgets.Display.runAsyncMessages(Display.java:4024)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3700)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$4.run(PartRenderingEngine.java:1121)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.run(PartRenderingEngine.java:1022)
at org.eclipse.e4.ui.internal.workbench.E4Workbench.createAndRunUI(E4Workbench.java:150)
at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:687)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:604)
at org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:138)
at java.lang.reflect.Method.invoke(Method.java:497)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:673)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:610)
at org.eclipse.equinox.launcher.Main.run(Main.java:1519)
Any thoughts why this is happening? Am I missing something or is it a Papyrus bug?
Simos
FUDForum. Page generated in 0.12006 seconds
