Home » Eclipse Projects » Eclipse Scout » [NEON] Table page with detail view
[NEON] Table page with detail view [message #1752855] Sun, 29 January 2017 10:42 Go to next message
I'm using scout with the Neon.2 release. I just tried to create a table page with a detail view form. In my example, I want it south of the table page. No matter what I try, the form takes up the whole page and obscures the table.
I was following the instructions from the Scout 4.0 tutorial, and also checked this against my Mars implementation (which works fine). Has anyone else experienced this issue?
For completeness, my code:
@Data(ProjectActivityTablePageData.class)
public class ProjectActivityTablePage extends ActivityTablePage<Table> {
    private Long projectId;
    protected void execPageActivated() {
        if (getDetailForm() == null) {
            ProjectActivityCalendarForm form = new ProjectActivityCalendarForm();
            form.setProjectId(getProjectId());
            setDetailForm(form);
            form.startView();
@FormData(value = ProjectActivityCalendarFormData.class, sdkCommand = FormData.SdkCommand.CREATE)
public class ProjectActivityCalendarForm extends AbstractForm {
    @FormData
    public Long getProjectId() {
        return projectId;
    @FormData
    public void setProjectId(Long projectId) {
        this.projectId = projectId;
    protected int getConfiguredDisplayHint() {
        return DISPLAY_HINT_VIEW;
    protected String getConfiguredDisplayViewId() {
        return VIEW_ID_S;
    public Object computeExclusiveKey() {
        return projectId;
    public void startView() {
        startInternalExclusive(new ViewHandler());
    @Order(1000)
    public class MainBox extends AbstractGroupBox {
    public class ViewHandler extends AbstractFormHandler {
        protected void execLoad() {
            getOkButton().setVisibleGranted(false);
            getCancelButton().setVisibleGranted(false);
        protected boolean getConfiguredOpenExclusive() {
            return true;
        protected void execStore() {
Re: [NEON] Table page with detail view [message #1755370 is a reply to message #1752855] Thu, 02 March 2017 11:39 Go to previous messageGo to next message
Hi Marco! Since you asked - yes I am experiencing the same issue Smile
Have you solved this already? I am working on this now and will elaborate if I get any solution.
Best,
David
Re: [NEON] Table page with detail view [message #1755396 is a reply to message #1755370] Thu, 02 March 2017 14:08 Go to previous messageGo to next message
Nope. In the end I exhausted my options and gave up, and implemented the view and table as separate pages in a node table page. I didn't see it reported as a bug, either. Perhaps we should report it?
Re: [NEON] Table page with detail view [message #1755413 is a reply to message #1752855] Fri, 03 March 2017 02:34 Go to previous messageGo to next message
Hello
Yes, this behavior has changed with Scout 5 (HTML UI). You can only have a detail table or a detail form at the same time. You can toggle them using the navigation buttons (up/down button at the top right).
There are two ways to get a table view with a detail form at the bottom:
1. Add a custom TableControl to the table, like the search form. To do so, override addDefaultTableControls() in the table page. Advantage: Belongs to the specified table. Disadvantage: Only one table control can be selected at a time.
2. Open a "normal" form with displayHint=DISPLAY_HINT_VIEW and displayViewId=VIEW_ID_S, i.e. do not set it as the detail form of the table page. This will create a new area on the desktop (that can even hold multiple views). Advantage: Form is visible all the time. Disadvantage: Form is not automatically removed when a different page is selected. You have to link it to the table page yourself.
A third possibility would be a detail form with a table field. Advantage: freedom to arrange elements as required. Disadvantage: different styling (e.g. smaller row height), no automatic table page functionality (e.g. "drill down").
Beat
Re: [NEON] Table page with detail view [message #1760197 is a reply to message #1755413] Mon, 24 April 2017 09:36 Go to previous message
For implementing the third possibility, the Widgets demo's FormPage class comes in very handy. I wonder why it is not included in Scout project itself. Are there issues with the FormPage I need to know when using it in my own project?
Previous Topic:How can i integrate jasper reports on scout?
Next Topic:Sidenav widget?
Current Time: Sun Jul 20 14:45:30 EDT 2025
Powered by FUDForum. Page generated in 0.03840 seconds
