Home » Modeling » TMF (Xtext) » Two DSL, single project, Activator&injector issues
Two DSL, single project, Activator&injector issues [message #1755248] Wed, 01 March 2017 10:45 Go to next message
Hi guys,
i merged my two dsl in a single project, where dsl A uses DSL B for expressions.
I Also merged my workflow into a single file like this>
Workflow {
	component = XtextGenerator {
		configuration = {
			project = StandardProjectConfig {
				baseName = "com.mentor.saphirerl"
				rootPath = rootPath
				runtimeTest = {
					enabled = true
				eclipsePlugin = {
					enabled = true
				eclipsePluginTest = {
					enabled = true
				createEclipseMetaData = true
			code = {
				encoding = "windows-1252"
				lineDelimiter = "\r\n"
				fileHeader = "/*\n * generated by Xtext \${version}\n */"
		language = StandardLanguage {
			name = "com.mentor.SaphireExp"
			fileExtensions = "exp"
			serializer = {
				generateStub = false
			validator = {
				// composedCheck = "org.eclipse.xtext.validation.NamesAreUniqueValidator"
			name = "com.mentor.SaphireRL"
			fileExtensions = "srl"
			referencedResource = "platform:/resource/com.mentor.saphirerl/model/generated/SaphireExp.genmodel"
When using the DSLs in my external program i have no problem, but when trying to use the eclipse generated app, i get this error:
(removed).ui.internal.SaphirerlActivator - Failed to create injector for (removed).SaphireRL
saphirerl.ui.internal.SaphirerlActivator - com.google.inject.internal.util.$ComputationException: java.lang.StackOverflowError
at com.google.inject.internal.util.$MapMaker$StrategyImpl.compute(MapMaker.java:553)
at com.google.inject.internal.util.$MapMaker$StrategyImpl.compute(MapMaker.java:419)
at com.google.inject.internal.util.$CustomConcurrentHashMap$ComputingImpl.get(CustomConcurrentHashMap.java:2041)
at com.google.inject.internal.FailableCache.get(FailableCache.java:50)
And then i can't open my files.
Do you have any tip how what's going on and how to fix it?
Thanks and best regards!
Re: Two DSL, single project, Activator&injector issues [message #1755352 is a reply to message #1755248] Thu, 02 March 2017 09:39 Go to previous messageGo to next message
no i have no idea on what. having a minimal reproducible example would be helpful.
(or at least a stacktrace that contains everything)
Re: Two DSL, single project, Activator&injector issues [message #1755645 is a reply to message #1755352] Mon, 06 March 2017 08:58 Go to previous messageGo to next message
thanks for your reply.
I'm attaching the stack trace (it's too large, i omitted some of the repetitions)
I have this grammar A that only handles expressions, since i need to provide expression level validation, i implemented it as a separated project, the initial definition is:
grammar com.mentor.SaphireExp with org.eclipse.xtext.common.Terminals
generate saphireExp "http://www.mentor.com/SaphireExp"
import "http://www.eclipse.org/emf/2002/Ecore" as ecore
ExtExpression:  testExpr=TestExpr | expr=Expression ;
Expression:  OrExpression  ;
TestExpr:
	'?' (var=VarName | alias=ID) '->' (comparators+= Comparator)+ ('default' ':'   defaultExpr=Expression)?
Comparator:
	((alias=ID| string=STRING) ':' expression=Expression ";" )
(etc...)
And then i have grammar B, which handles structural and definition aspects, including many expressions as part of said structure. It is using grammar A:
rammar com.mentor.SaphireRL with com.mentor.SaphireExp
generate saphireRL "http://www.mentor.com/SaphireRL"
import "http://www.mentor.com/SaphireExp" as saphireExp
Model :
   (sections+=Section)*;
(etc...)
I merged both projects just copying the xtext file from grammar A, including the mwe2 file for it, into grammarB.
When i want to generate the code, i first run mew2 for grammar A, then the workflow for grammar B, which is modified as seen in my first post.
Everything works fine, my both extensions are recognized (meaning i can parse and validate expressions and the complex language), but i cannot use the generated eclipse project, because it fails when tryin to open my files with the stack trace attached.
I hope this clarifies a bit more my problem, maybe i'm missing some additional steps when merging the projects, but i wouldn't know where to start looking.
thanks again for your help, it's very appreciated.
Re: Two DSL, single project, Activator&injector issues [message #1755648 is a reply to message #1755645] Mon, 06 March 2017 09:17 Go to previous messageGo to next message
can you share the workflow as well
Re: Two DSL, single project, Activator&injector issues [message #1755651 is a reply to message #1755648] Mon, 06 March 2017 10:12 Go to previous messageGo to next message
Sure!
Here are the .text files (exp is the expression oriented grammar and RL is the complete language)
Regards!
Re: Two DSL, single project, Activator&injector issues [message #1755661 is a reply to message #1755651] Mon, 06 March 2017 11:22 Go to previous messageGo to next message
why two mwe2 files? i thought you want to have only one
Re: Two DSL, single project, Activator&injector issues [message #1755672 is a reply to message #1755661] Mon, 06 March 2017 12:50 Go to previous messageGo to next message
If i don't run the EXP one, the model for it won't be generated, and since it's required by the second grammar it will fail.
I'm pretty sure i don't know how to do things, and that's why the UI is failing
Sad...
Re: Two DSL, single project, Activator&injector issues [message #1755677 is a reply to message #1755672] Mon, 06 March 2017 13:32 Go to previous messageGo to next message
i still cannot reproduce. it might have todo with generated once files.
maybe you can create a fresh project and copy the xtexts there
			serializer = {
			validator = {
			referencedResource = "platform:/resource/org.xtext.example.mydsl/model/generated/SaphireExp.genmodel"
			fileExtensions = "rl"
			serializer = {
			validator = {
Re: Two DSL, single project, Activator&injector issues [message #1755680 is a reply to message #1755677] Mon, 06 March 2017 14:05 Go to previous messageGo to next message
I really appreciate the effort!
This is the actual set of projects, sorry for not posting them before, but since it's not actually mine, it gets complicated.
I tried the new project approach, with a single mwe2, but it still wants the ecore package from the EXP grammar and it's not finding the references.
Maybe with the full set of files you can get a clearer picture (i hope)
Thanks again!
  • Attachment: SRL.zip
    (Size: 2.60MB, Downloaded 102 times)
Re: Two DSL, single project, Activator&injector issues [message #1755681 is a reply to message #1755680] Mon, 06 March 2017 14:07 Go to previous messageGo to next message
this wont work.
one project, one workflow
Re: Two DSL, single project, Activator&injector issues [message #1755685 is a reply to message #1755681] Mon, 06 March 2017 14:30 Go to previous messageGo to next message
hmmm did some cleanup/regen and it works fine.
feel free to diff
  • Attachment: export.zip
    (Size: 2.54MB, Downloaded 122 times)
Re: Two DSL, single project, Activator&injector issues [message #1755693 is a reply to message #1755685] Mon, 06 March 2017 15:19 Go to previous message
That was awesome, thank you very much, i'll study this in detail.
have a nice day!
Previous Topic:Servlet Session ID
Next Topic:Xtext formatting language
Current Time: Sun Jul 20 03:54:52 EDT 2025
Powered by FUDForum. Page generated in 0.26552 seconds
