Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc)  » [EMF Forms]Unusual Model element creation
[EMF Forms]Unusual Model element creation [message #1755136] Tue, 28 February 2017 06:25 Go to next message
I have a model in which class A has a association with class B (with cardinality 0..1).
Now i am trying to render this using a View Model. In my View Model, On setting value for reference of Class B in Class A, some other field has to become visible.
Therefore i am using Show Rule set to false with Condition where Value in Class B = Others
Now because of this Show Rule, by default whenever i create Class A, a Class B is automatically created and reference is set.
This is an unusual behaviour, but if i remove the Show Rule, then it doesnt get created.
I have attached sample project for reference.
Any support to understand this behaviour would help.
Saravanakumar
[Updated on: Tue, 28 February 2017 23:56] by Moderator
Re: [EMF Forms]Unusual Model element creation [message #1755220 is a reply to message #1755136] Wed, 01 March 2017 04:41 Go to previous messageGo to next message
I assume that the domain model reference used in the show rule points to something in B. If that is the case, the domain model resolvement will automatically create missing elements. Otherwise it cannot bind to the value in B.
Best regards
Jonas
Get professional Eclipse developer support:
http://eclipsesource.com/en/services/developer-support/
Re: [EMF Forms]Unusual Model element creation [message #1755231 is a reply to message #1755220] Wed, 01 March 2017 06:02 Go to previous messageGo to next message
Thanks Jonas for your response ,
We want to solve this scenario something like as soon as A is created B should not be created. Can we achieve this scenario by having some rule . Is there any approach by which this ECP behaviour can be resolved.
Thanks in advance.
Re: [EMF Forms]Unusual Model element creation [message #1755236 is a reply to message #1755231] Wed, 01 March 2017 06:31 Go to previous messageGo to next message
Thanks for your response Jonas.
Is there any approach to change the behaviour of automatic model element creation?
If i try to remove the model element in reference then it will add another one model element instead of removing the same.
is this the default behaviour of EMF Forms?
Please support me to resolve the same.
Saravanakumar
Re: [EMF Forms]Unusual Model element creation [message #1755722 is a reply to message #1755236] Tue, 07 March 2017 04:01 Go to previous messageGo to next message
Yes, that is the default behavior. EMF Forms will create elements that the view model binds to. Otherwise, there would be UI elements, which bind to missing parts of the domain model.
I do not fully understand your use case. However, it might make sense to adapt this default behavior of EMF Forms and skip the automatic creation of sub elements.
It is actually triggered in the method ViewModelContextImpl#resolveDomainReference
The actual behavior is delegated to a service called EMFFormsDomainExpander. So by adapting or overriding this service, you can adapt the behavior as you wish.
Please note, that missing elements might lead to NPEs or other errors, so you should check which elements are really required.
Best regards
Jonas
Re: [EMF Forms]Unusual Model element creation [message #1756380 is a reply to message #1755722] Thu, 16 March 2017 04:18 Go to previous message
Previous Topic:[EMF Transaction] How to correctly handle changes on the file level in EMF?
Next Topic:EMF Forms: PackageNotFoundException for view proxy model
Current Time: Sun Jul 20 11:55:19 EDT 2025
Powered by FUDForum. Page generated in 0.04192 seconds
