Home » Modeling » Papyrus » !MESSAGE could not find entry clazz.tool.class
!MESSAGE could not find entry clazz.tool.class [message #1755211] Wed, 01 March 2017 03:32 Go to next message
I try to creata a custom palette for a UML Profile I developed. I add the appropriate extensions for both the UMLProfile and the paletteDefinition in my plugin project (that was converted by clicking the "Configure --> Convert to Plugin Projects..." on my original profile project). When I fire up a new Papyrus instance, my custom profile is shown in the registered profiles and works fine, the palette drawer that I create is created normally however, the drawer is absolutely empty. I reduced my palette.xml file to have just one aspect tool but still the drawer is empty. What I receive in my first Papyrus' console and I believe is related with my problem is the following error:
!ENTRY org.eclipse.papyrus.uml.diagram.common 4 0 2017-03-01 08:22:57.265
!MESSAGE could not find entry clazz.tool.association
I checked the dependencies and the org.eclipse.papyrus.uml.diagram.common plugin is there.
Any idea?
Re: !MESSAGE could not find entry clazz.tool.class [message #1755213 is a reply to message #1755211] Wed, 01 March 2017 03:43 Go to previous messageGo to next message
The entry is defined in org.eclipse.papyrus.uml.diagram.clazz plugin maybe add it as dependency.
otherwise it will be diffuclt to answer without more technical information.
Re: !MESSAGE could not find entry clazz.tool.class [message #1755218 is a reply to message #1755213] Wed, 01 March 2017 04:11 Go to previous messageGo to next message
Thanks for your reply.
Unfortunately, adding the new dependency didn't solve the problem. I will create a minimal example and I will post it.
Thanos
Re: !MESSAGE could not find entry clazz.tool.class [message #1755221 is a reply to message #1755218] Wed, 01 March 2017 04:44 Go to previous message
Trying to create the minimal example I decided to change the priority of the paletteDefinition extension to "Medium" (the default I was getting was "Lowest"). This fixed the problem. With some more experiments, I found that the problem is fixed with priority set to anything but "Lowest".
Any explanation of this behaviour would be more than welcome.
Previous Topic:Display applied stereotype name CSS
Next Topic:Double click on elements in activity diagram
Current Time: Sun Jul 20 05:29:11 EDT 2025
Powered by FUDForum. Page generated in 0.03445 seconds
