Home » Modeling » Papyrus » Reference is displayed incorrectly in Papyrus 2
Reference is displayed incorrectly in Papyrus 2 [message #1752285] Fri, 20 January 2017 10:27 Go to next message
Hello!
In Papyrus 2 properties with complex types (references) are displayed incorrectly. They should be displayed with arrow pointing to referenced class (like associations), but they're not.
This bug is registered in https://bugs.eclipse.org/bugs/show_bug.cgi?id=444605.
I wonder, is there any way of fixing it on papyrus plug-in side with Papyrus 2 new element type framework?
Thanks in advance.
Re: Reference is displayed incorrectly in Papyrus 2 [message #1755140 is a reply to message #1752285] Tue, 28 February 2017 06:39 Go to previous message
For the moment, this display is not planned in Papyrus.
This not a problem of new element type.
It need to specify the graphical behavior, the drop.
For example when you drop a property that references a block, do you want to see this as link or as label in the property compartment...
I have adapted the associated task in the buzilla.
Previous Topic:Stereotype: Default value setting on a multi-valued enumeration
Next Topic:Diagram fragmentation: "Create Submodel" from diagram
Current Time: Sun Jul 20 10:38:19 EDT 2025
Powered by FUDForum. Page generated in 0.45001 seconds
