Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc)  » [Xcore] Generate code in Tycho build
[Xcore] Generate code in Tycho build [message #1755009] Sun, 26 February 2017 07:17 Go to next message
I am currently trying Tycho again after a long time, and made some progress thanks to Lars Vogel's excellent tutorial on POM-less Tycho builds.
I got it to even compile Scala code out of the box, I just had to add the Scala-IDE p2 repository to my main pom.xml.
However, the Java code for Xcore models is not generated.
Currently, as a workaround, I check my src-gen folder into Git so the generated source is present, but for obvious reasons I don't want this in the future - I want that the code is generated during the Maven run.
About this topic the only thing I found is this thread on tycho-user but I don't fully understand it.
Can anyone guide me how to achieve the Java code being built from an Xcore model using Tycho and Maven?
Re: [Xcore] Generate code in Tycho build [message #1755010 is a reply to message #1755009] Sun, 26 February 2017 07:20 Go to previous messageGo to next message
Likely this blog will help: https://www.nikostotz.de/blog/combine-xcore-xtend-ecore-and-maven/
Note it's better to ask about Xcore on the EMF forum rather than on the EMFT forum.
Re: [Xcore] Generate code in Tycho build [message #1755137 is a reply to message #1755010] Tue, 28 February 2017 06:26 Go to previous message
Unfortunately, it did not help, but I got it to work adapting this example by Holger Schill and the attachment of comment 9 of this bug tracker entry.
Previous Topic:[Xcore] Project does not build anymore after git clean -fdx
Next Topic:Extending ECPReferenceService
Current Time: Sun Jul 20 14:20:54 EDT 2025
Powered by FUDForum. Page generated in 0.24923 seconds
