Home » Eclipse Projects » GEF » Frame on editor problem
Frame on editor problem [message #170322] Thu, 03 March 2005 11:29 Go to next message
Originally posted by: binti.ksu.edu
Hi all,
I am trying to make changes to the schema diagram editor example to get a
better understanding of gef. I need to add af frame to the editor on which
my figures would appear. I am able to do this by adding a recatngular figure
to the schemafigure. Schemafigure extends FreeformLayer. So the frame
appears on it.
The class schemafigure is as follows:
public class SchemaFigure extends FreeformLayer
public SchemaFigure()
setOpaque(true);
setBorder(new LineBorder(ColorConstants.white, 1));
protected void paintFigure(Graphics g)
Rectangle r = getBounds().getCopy();
r.translate(20, 20);
g.setLineWidth(2);
g.drawRectangle(r.x, r.y, r.width - 40, r.height - 40);
g.drawRectangle(r);
My problem is, when I add figures at the edges, the frame and the editor
expands, which is desired, but my figure intersects the frame. How can I
validate and expand the frame at this point so that the figure lies withing
the frame and not over it.
Re: Frame on editor problem [message #170920 is a reply to message #170322] Mon, 07 March 2005 23:48 Go to previous messageGo to next message
Are the child's constraints being set on the parent? Maybe a screenshot
will help better understand the problem.
The SchemaFigure is your content figure, right? What are you doing in
paintFigure()? Set a border with insets of 20, 20, 20, 20 if you want a
thick border and it will resize correctly.
"Binti Sepaha" <binti@ksu.edu> wrote in message
news:d07f6p$k68$1@www.eclipse.org...
> Hi all,
figure
> appears on it.
> setOpaque(true);
> g.setLineWidth(2);
> g.drawRectangle(r);
withing
Re: Frame on editor problem [message #171263 is a reply to message #170920] Thu, 10 March 2005 17:25 Go to previous messageGo to next message
Yes, The schema figure is the content figure which extends freeformlayout. I
am including the snapshot. But the problem the bounds of the figure increase
only when I drag an element to the extremes but then my frame becomes a
problem, because the frame is just a rectangle on the schema figure. The
user should not be able to select it or delete it. It should be there. It
extends accordingly but the problem is the overlap of figure as shown in the
picture.
Please help me as what to do...
Binti.
"Pratik Shah" <ppshah@us.ibm.com> wrote in message
news:d0jaqf$elb$1@www.eclipse.org...
>> Hi all,
>> which
> figure
>> appears on it.
>> setOpaque(true);
>> g.setLineWidth(2);
>> g.drawRectangle(r);
> withing
  • Attachment: frame.JPG
    (Size: 149.59KB, Downloaded 120 times)
Re: Frame on editor problem [message #171535 is a reply to message #171263] Sun, 13 March 2005 20:29 Go to previous messageGo to next message
Create the frame as a border, instead of a rectangle figure, and you'll be
fine.
news:d0qhgj$45u$1@www.eclipse.org...
I
increase
the
> picture.
> Binti.
> >> Hi all,
a
> >> which
> > figure
> >> appears on it.
> >> setOpaque(true);
> >> g.setLineWidth(2);
> >> g.drawRectangle(r);
editor
I
> > withing
Re: Frame on editor problem [message #174777 is a reply to message #171535] Thu, 31 March 2005 20:19 Go to previous messageGo to next message
Thanks Pratik,
It worked for me. I used a margin border.
Binti.
news:d12pdg$moc$1@www.eclipse.org...
> fine.
>> freeformlayout.
> I
> increase
> the
>> picture.
>> Binti.
>> > screenshot
>> > a
>> >> Hi all,
>> >> get
> a
>> >> which
>> > figure
>> >> appears on it.
>> >> setOpaque(true);
>> >> g.setLineWidth(2);
>> >> g.drawRectangle(r);
> editor
> I
>> > withing
Re: Frame on editor problem [message #175480 is a reply to message #174777] Mon, 04 April 2005 18:33 Go to previous message
A MarginBorder just leaves some empty space so I don't know how you did
this. Did you subclass it? You should use a LineBorder.
news:d2i7mv$ehm$1@news.eclipse.org...
> Thanks Pratik,
> Binti.
be
> > fine.
> >> freeformlayout.
> > I
> > increase
The
It
in
> > the
> >> picture.
> >> Binti.
> >> > screenshot
in
want
> >> > a
> >> >> Hi all,
> >> >> get
> > a
> >> >> which
recatngular
> >> > figure
frame
> >> >> appears on it.
> >> >> setOpaque(true);
> >> >> g.setLineWidth(2);
> >> >> g.drawRectangle(r);
> > editor
can
> > I
> >> > withing
Previous Topic:Creating a container editpart
Next Topic:GEF TreeViewer
Current Time: Sun Jul 20 12:41:57 EDT 2025
Powered by FUDForum. Page generated in 0.08560 seconds
